Question about Ricoh Aficio 2018D All-In-One Laser Printer
Set Key Counter error
The printer will not work it only says set key counter what do we do?
  • 15 Answers
Press the user tools button, press the copier button on the screen then go into the administrator tools button in there you should see some option for turning the key counter off.
Posted on Mar 01, 2009
  • clau1235 Sep 21, 2011
    it shows up highlight "level 2" ,but I can't enter in.
    New Friend:
Sc 230
Posted on Jan 19, 2013
Unable to clean 46. this error display in lcd of brother dcp585cw printer. how to solve me this problem.
Machine Error 46 - Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An "initial purge", for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an "Unable to Clean" external message and will be unable to use the printer. The "Unable to Clean" external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter MFC620CN/420CN/410CN/210C and FAX2440C
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Jun 26, 2011 | Brother DCP585cw AllInOne InkJet Printer
It says "unable to clean"
Dec 20, 2010 | Brother MFC-5840CN All-In-One InkJet...
Completed instruction to set Purge counter to zero. Done. Hasnt solved the problem. Machine stil reports "Unable to Clean" & "Machine Error 48" How do I empty the "Ink...
Dec 20, 2010 | Brother MFC 210C All-In-One InkJet Printer
Error 46 what is it
Here is the answer to your MFC code 46
Nov 24, 2010 | Brother MFC-5840CN All-In-One InkJet...
Unable to clean code error 46
All you need to do is to reset the purge counter
To reset purge counter
1) Enter machine maintenance mode (on MFC240C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine’s log information list (function code 80).
Feb 03, 2010 | Brother Office Equipment & Supplies
Printer unable to clean
the printer has a counter for the supposed amount of ink the absorber pad can absorb.
i have reset the counter using the following and now it works. In theory you need to get a replacement pad but i haven't been able to find one yet. My printer is now working fine
following is the solution to reset the counter for the old fault
> Brother DCP110c Reset Counter
> 1. unplug at side of unit, switch on while pressin menu2. Enter 8 press
> set enter 0 press set
> " by using the up arrow key & SET keys."
> 3. press the mono start key several times untill the purge count appears
> on the LCD.
> 4. enter 2 7 8 & 3 by using the up arrow key & set keys to reset the
> purge count to zero (like in 1)
> 5. press the stop/exit key to return to the initial stage of the
> maintanance mode.
> 6. enter 9 twice by using the up arrow & set key’s to exit from
> maintenance mode
Michael
Mar 06, 2009 | Brother DCP 115C All-In-One InkJet Printer
Need to reset purge counter due to error 46
MFC-5440CN saved from the tip!
"Unable to Clean" message - found TrickyDicky's sltn 4 for various printers.
Went into maint mode as per sltn 4 - verified error 46.
"The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed."
Keyed in 80 - stepped through the items with "down" key and located Purge Counter.
"Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero
Press the 9 key twice to return to the standby state."
This worked brilliantly - no need to tamper with any parts of the printer. Purge Counter reset did it all. Fully functional printer.
Thanks TrickyDicky for info on verifying the error code and purge reset
Mar 27, 2007 | Brother MFC 210C All-In-One InkJet Printer
Ricoh Aficio 2018D All-In-One Laser Printer Logo
4,590 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
