Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Refrigerator/freezer is no longer cold
Just vacuumed condenser, it really needed it
  • Ken Bledsoe May 11, 2010
    Is the compressor running? The fan on the inside of the freezer running?
  • 318 Answers
Depending on how old this unit is, it may just need 24 hours to get cold again after it can breathe again. you need to keep the coil clean at least once a year.
if it doesnt start cooling by itself after cleaning, then you might have a burnt out comrpessor relay. it happens alot after the coils are plugged. if it makes a buzzing noise then a click, you have a bad relay. it is easy to replace by taking off the rear lower panel and removing the relay from the compressor and getting a new relay kit.
Posted on Dec 28, 2008
The freezer no longer freezes but is cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a frigidaire side by side refridgerator / freezer. Currently my freezer is about 34 to 40 degrees. The dividing wall between the ref. and freezer is warm to hot depending on when you check it. ...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
May 03, 2011 | Frigidaire FRS26H5AS Side by Side...
I have a Kenmore model # 596:75523400. Both the refrige and freezer is no longer cold. I can hear the fan but it's warm inside. Would cleaning the coils in the back help or is it really dead?
Refrigerator
heatman101
Jan 23, 2011 | Kenmore 53642 / 53644 Side by Side...
The freezer is no longer freezing and the refrigerator part is no longer cold. What could be the problem and how expensive is it to fix?
heatman101
Dec 26, 2010 | Maytag MSD2454G Side by Side Refrigerator
Not cold any longer
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
987ryjh
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Code vacuum condensor
clean your condenser coils. located in the top part of the fridge. unplug the unit before service. vaccum the condenser. if after 2 or 3 weeks the vaccum condenser comeback is really posible that you have an evaporator freon leak. in the fridge side
Mar 29, 2010 | Sub-Zero Bottom Freezer Refrigerator
Freezer not cold, but fridge is
Condenser coil is probably dirty, or the fan isn't running. If the coil is under the refrigerator, it will probably be coated in dust like a blanket. Use a vacuum cleaner with a straight pipe extension wand. I've also seen a dead mouse stuck in a condenser fan blade.
Sep 15, 2009 | Refrigerators
Kenmore Coldspot side by side fridge/freezer no longer cold.
The black thing is the compressor. It should run warm but not hot. This usually indicates it's time to clean the condenser coils under the refrigerator. Try using a long soft brush and your vacuum cleaner.
May 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer won't freeze
is the fan running ion the freezer is the compersser runing and the cond fan >??
May 10, 2008 | Frigidaire FRS3R5EMB Side by Side...
Sub Zero Freezer Vacuum
If your freezer temps are ok, it may just be that your gasket is getting older and it becomes more porus as it ages. The vacume sound doesnt really mean alot except that the difference in the room temp and the cold of the freezer create this vacume.
Mar 08, 2008 | Sub-Zero 650 / O Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
57 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
tootsie mason
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
