Some information appear on the screen but i could not understand because it is written in japanese. The cartridge does'nt move properly. An error always occur.
Please check if there is some error code appear in printer display. If you don't understand japanese then find someone who understand. No one can troubleshoot it without knowing the error message :).
Find the printer solution at Printer Clinic
OR
Download Service Manual
error 5110 occur. what does it mean? and another problem is during photo copying. it takes i think more than a minute to finish a single page.
Error Code 5110 indicates that Carriage Lift Mechanism Error occurs. This mechanical problem of Carriage Unit and sometimes Auto Sheet Feeder can make the same problem. It's so long to explain it here. I will post it on my blog: www.printerclinic.com next chance.
SOURCE: will not print - ink cartridges not recognised, not installed properly etc
On my Cannon Pixma, I pressed the stop/reset for 5 seconds to ignore the warning. Then,
I was able to make a copy. However, better solutions to this scenario are welcome.
Cheers - Peter
[email protected]
SOURCE: Canon Pixma MP500 error
ok I figured out what to do. Open the over take out all your ink cartriages. Then flip the print head level on the left hand side up and squeeze the top of the print head (where all your ink sits on) and lift it up. You may want to blow off any dust that may be in there and put the peint head back and replace al your ink put the level down and you should be good to go if not you may have to replace the head.
SOURCE: mp780 wrong cartridge error
Try to reset to factory .
Remove ink cartridges and print head.
Power off machine and unplug for 10-15 minutes.
Restart machine and install head and cartridges.
SOURCE: Canon MP510 wont print. Error message B300 or
May I know the exact error messages in the printer screen. If it's green and yellow lights that are flashing you need to push more the two cartridges that you replace....also try to clean it using the printer program installed in your computer....good luck and hope it will help....
the error that appear on the screen is 5100 ang not 5110. what wiil i do?
