Question about Proscan PS27600 27" TV
Want to re-set to default setting on ProScan 1998 model PS27600
Can no longer program channels. Nothing comes in any more, just snow screen and I think I accidiently changed something and now I don't get any channels. I am hoping there a re-set somehow???? HELP!
Sherri : on front of TV there is a menu button, press that and go through setting boxes til you get to Picture settings, arrow down past autocolor to Picture reset. My diagram page says press <> button, guess either will do "resets the picture back to original setting" This might not work because I don't know where you actually were when you were "adjusting". Worth a try. If you fail, I'll buy your remote. patdeuel001@verizon.net
Posted on Jan 05, 2009
My tv after 10 min be on my pic start to dark slowly
Posted on Dec 27, 2008
Cable won't work
Channel tuning capability to your set might be 98. If so, nothing can be done.
Mar 21, 2013 | Proscan PS27500 27" TV
Proscan 47LB45H tv turns on , has sound , no video
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jun 19, 2017 | Proscan 47LB45H 47 in. LCD TV
Unable to get channels 14 through 98.
Make sure in the menu that you have the tuner set to Cable Mode, then auto program again. Hope this helps.
Feb 26, 2009 | Proscan 19LB30QD 19 in. LCD HDTV/DVD Combo
VCR doesn't record since Comcast installed digital box
Try this..Run cable line into VCR in, cable from VCR out to box, then cable from box to TV..this might work...I have done this for YEARS and it is never failed. You can then watch and record 2 things at once.
Feb 12, 2009 | Proscan PSVR72 VHS VCR
TV turns on and I get sound, but no picture.
Try to see if it is on CHNL 3 for cable, that could very well cause it.
Let me know how it goes
Thanks
Justin
Please Rate Me
Jan 07, 2009 | Proscan PS27600 27" TV
Proscan (RCA) PS52652
Also, the proscan ps52652 has the ctc-169 chassis. This set is a 52" manufactured in 93.
Mar 30, 2008 | RCA P52926 52" Rear Projection Television
Channels will not change
Do a auto program from the menu. If the set has lost its memory from a power loss or other situation it will loss it memory of what channels you have and unless you put the channel in from the remote it will default to ch 2
Mar 07, 2008 | Proscan 32LA30Q Television
My big screen tv show snow on all channels.
ok.
if you see only snow on the regular screen, might as well check the connecting antenna at the back since you mean all snow on all channels.
hope this helps.
Jan 17, 2008 | Akai PT4298HD Rear Projection Television
Channel changing on PROSCAN 32LA25Q
I had the same problem, what fixed it for me was to set auto scan to setup all the channels for me again. Another thing to check would be whether it is set up to use CATV or AIR.
Dec 26, 2007 | Televison & Video
Proscan will not turn on
i had the same issues.. i took the TV into a repair shop and they replaced a peice for $40.00 (Canadian)
Dec 01, 2007 | Proscan PS27600 27" TV
Proscan PS27600 27" TV Logo
155 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
