Question about Arris Touchstone 450a (CM450) Modem
I cant get out to the internet when I connect the netgear router.
To an Arris Cable modem.
  • Anonymous Jan 20, 2009
    I have the same problem
    President:
  • 1,865 Answers
Be sure that your cable company has enabled your internet. Power down the cable modem, power down any routers and computers. Start cable modem first, after internet connectivity is indicated, power up the router (if you have one) and then power upi the pc
Posted on Apr 15, 2009
2 Suggested Answers
  • 31 Answers
SOURCE: i have an arris tm602gct and cannot connect thru my netgear
Can you connect if you are directly wired into the router?
You may want to try using a ball point pen and pressing the reset button on the back of the arris. Let it reboot and try again.
Some netgear routers come with the wireless disabled out of the box, so you need to be hard wired when you run the CD or if you try to connect through your browser 192.168.1.1
Posted on Apr 09, 2009
There is no internet connection to the laptop. The arris modem gives internet acess to the PC computer, though. The manual for the Airlink 101 router says to connect the router and MODEM to each other by a...
What you're missing is that ALL the PCs will be connecting THROUGH the router to the Modem. Unplug the PC network Cable from the modem, then plug a network cable from the router's INTERNET port into the modem (where you removed the PC's network cable). Now, plug the PC's network cable into one of the ports on the router (usually 4 or more, marked 1,2,3,4. Think of a Router as a "splitter". It connects to the Modem, then several devices connect to the Router, some of them by wire and some by Wi-Fi. So your desktop PC is connected by wire to the router and your laptop PC is probably connected by Wi-Fi (wire is an option, as well). The Router sorts out all those signals and communicates with the Modem. Sound reasonable?
May 02, 2017 | Arris Comcast Touchstone Telephony VOIP...
How to connect netgear fs108 to cable modem
leeb..... switches cannot be connected to the Cable modem.... because NAT will not be enabled in cable modem....so there wont be any DHCP server present in the cable modem....
Nat will be enabled only in DSL modem like AT&T verizon etc....So DHCP server will be present inside DSL modem...that is the reason why switches can be connected only to the DSL modem....
With NAT enabled modem, switch will work as a switch.... With NAT disabled modem, switch will work as a hub.... This is the difference....
Any doubts further ? please clarify with me.... I am ready to help you....
May 09, 2010 | NetGear FS108 8-Port Ethernet Switch
I have my main computer set yp with arris router
  • You can use both Ethernet and USB interface to connect two PCs simultaneously with one cable modem.
  • If you plan to go wireless (and maybe connect more computers), you have to purchase a router to split/share the internet connection coming from the modem.
Apr 07, 2010 | Arris Touchstone 450a (CM450) Modem
I have a arris tm602 modem, HOW DO I CONFIGURE MY NET GEAR ROUTER FOR INTERNET CONNECTION
Cable modems bond to what they are plugged into, so you have the modem plugged into a computer and it is working fine. Then you want to unplug the ethernet cable from the computer and plug it into another device such as a netgear router. Then you find no matter what you do it will not work.
Now normally to break this bond to the computer so that it will bond with the router you would simply unplug the electrical power from the cable modem, wait for it to sync back up with your ISP's CMTS, power up your router which you would have connected via the internet or wan port, and you would be up and running.
You may have even did this with your Arris TM602. Why isn't your router pulling an IP address? The reason is simple, pulling the power cord did not really remove power since the modem has battery back up.
In order to make it release its bond to your computer, so it can bond with the router you need to either push the reset button on the back of the modem while still powered up or remove its battery pack while unplugged from power.
So try again, this time push reset on the modem. This question was posted in January so I am sure buttercup is all fine by now but maybe this will help someone else.
Jan 08, 2010 | Arris Touchstone 300a (CM300) Modem
We have just signed up for cable TV/high speed internet/cable telephone. The modem provided is an "Arris" version 1.5. The cable tech said I could connect my Belkin G router so that more than one computer...
Plug the ethernet net cord into the arris ethernet port. plug the other end into the router where it says "internet"
Plug a ethernet cable from one of the router ports to the computer.
First start up the arris modem, then power up the router, then start the computer.
Oct 22, 2009 | Belkin 802.11g Wireless Desktop Network...
Getting error message: Invalid Ip address
This would normally mean that you have assigned the IP address manually but have also given that same IP to another computer and they are fighting about it.
If this is the case then just check your IP allocations and find out which computer is using the same IP and change it to one that is not in use.
It may also mean that your router is trying to use the same IP as your modem
With just your modem connected to the computer
go to the START MENU / RUN then type CMD and press enter.
Now in the black screen type IPCONFIG /ALL
Take note of the numbers esp in the default gateway, that is your modem)
Now with just the router connected by wire do the same thing.
This time the default gateway is your router if it is the same as your modem then you need to alter it in your router,
You haven't given a model so you will have to work this bit out yourself but your are looking for a setting on your router that starts with the same number you got.
If your default router gateway was lets say 192.168.1.1 then that is what you would be looking for. Change the third block so now it reads 192.168.2.1 and save the settings. This would clear any conflict between modem and router.
If you have assigned IP's to computers they would need to be changed to reflect the routers new IP and again you would just change the third block in the allocated IP to a 2
If in doubt read this a couple of times or print it out.
If this information was of any use please click below
Aug 18, 2009 | NetGear Computers & Internet
Router cannot connect to the internet.
Turn everything off:
Cable modem unplug the power to the modem if it has a battery remove it.
Router unplug the power to the router
Shutdown any and all computers connected to the router
Turn everything on in this order:
Cable modem wait until all the lights are on but the internet act light
Router wait until the lights goes through it's test cycle and the internet light (wan) is on.
Boot up the computers one at a time after the first computer is fully loaded go to the next computer
Hope this helps
Terry
Feb 27, 2009 | Arris Touchstone 450a (CM450) Modem
I have an arris tm602gct and cannot connect thru my netgear
Feb 15, 2009 | Arris Touchstone 450a (CM450) Modem
WGR614-netgear-54 mbps-Plus wireless plug=in
Only real trouble shooting I can suggest is power cycle the modem and router. If you have the Comcast Digital Voice modem make sure you push the reset button on the back as there is a battery in the unit and unplugging won't do anything.
May 28, 2008 | NetGear WGR614 54Mbps Wireless Router...
Arris Touchstone 450a (CM450) Modem Logo
443 people viewed this question
Top Arris Computers & Internet Experts
jimmy Leo
Greg Ulan
Chris Larocque
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
