Question about PANDIGITAL (DPF802) Digital Picture Frame
SD Memory Card in frame-no pictures
I installed batteries & pluged my pandigital 3.5 photo frame in all night.
Today I put my SD memory card in my pandigital & waited another hour & still no pictures on my pandigital.
Box sayes Simple, Plug in & play but does not work for me.
Ruth
  • 45 Answers
1st: Make sure the SD card is in working order and not damaged.
2nd: Make sure you're using the right file type (.jpg, .png, .gif, etc) and size.
Posted on Jan 14, 2018
frcs68
  • 1605 Answers
SOURCE: I NEED A INSTRUCTION MANAL
go to http://www.pandigital.net/support
Posted on Oct 29, 2008
  • 6 Answers
SOURCE: Inserted camera memory card into
Try another memory card. Sometimes one memory card will work and not another. They really dont support cards larger than 1 GB in size.
Posted on Dec 11, 2008
  • 3 Answers
SOURCE: Not all jpeg images will load on 7'' Pandigital Photo Frame
I was having a problem too with my Smartparts frame. All the pics were from the same camera but some of the vertical (portrait) orientation shots wouldn't show right. Just a bunch of thin colored lines. After some phone calls I did try to "resize" the photos to the "resolution" of my frame (had to look that up too). My frame is 640 width by 480 high. So I took a shot and changed all the goofy photos to 480 width (since they were vertical) and let Photoshop change the the other number. Low and behold the buggers are showing up fine now. Well on to my next problem - focusing with the new D90. I think that one is going to be more challenging yet. Hope this helps you out.
Posted on Dec 30, 2008
SOURCE: PANDIGITAL DIGITAL PHOTO FRAME SNOW GLOBE
Once you have the box connected with the usb cable to the computer, you have to tilt it towards connect to pc. You might have to do this a couple of times the picture on the display should change to a usb cable. Now if you go to my computer you will see where it says pan digital. Here is where you can add the pictures. I just did add pictures. If you want the pictures in a certain order you will have to name them otherwise there are displayed in alphabetical order. I found this after I loaded everything and wanted them in a specific order. Right now I am trying to add sound. I see that there is a speaker but not sure how to add sound.
Posted on Feb 11, 2009
robmcd27
  • 423 Answers
SOURCE: Need PANDIGITAL PanDigital 8.0" Digital
I don't like pasting information, but this is the link to the manual.
http://akamaipix.crutchfield.com/Manuals/692/692PAN902B.PDF
Don't forget to rate my solution, and thanks for coming to FixYa.
Rob
Posted on Feb 21, 2009
Pandigital Photo Frame will not read MMC card
The new card is not compatible with your photo frame. Only thing you can do is to make sure that what you use is compatible. Your manual or website will tell you the largest memory card you can use.
Aug 27, 2016 | PANDIGITAL 7" Digital Photo Frame With...
I received a 7" pandigital
If the photo frame has a slot for an SD card, you can drag and drop the images you want to the card and then insert it into the frame. Connecting the card to the computer can be accomplished by using a card reader or, if the computer has a built-in SD slot, just insert the card.
Jan 21, 2011 | Cameras
How can I get my pictures from computer to the picture??
put them on a memory card. it is most likely a SD secure digital card
check what kind of card the frame takes. if there is not a card slot then you would use a USB cable to connect to the frame's internal memory
Jan 05, 2010 | PANDIGITAL 7" Digital Photo Frame With...
Pictures on card (can see on computer) but not on frame
Make sure the memory card is not UDMA if a compact flash memory card or SDHC if an SD memory card. Neither of those are going to be compatible. You will need smaller cards like 1gb SD or CF variety.
Sep 22, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
Downloading photos from computer to phillips 8ff2fpb photoframe
Your PhotoFrame does not have internal memory acording to the Phillips data sheet, therefore you need to load your pictures directly onto a memory card (one from your camera will proabably work.) If that isn't convenient, you can generally get a good price on a SD memory card which is supported by your PhotoFrame.
If you wnat to transfer pictures from your PC to the memory card and have a card reader, you can transfer the pictures in Windows Explorier from your PC to the memory card and then plug the card into your PhotoFrame. If you do not have a card reader, plug the memory card into the PhotoFrame and connect it to your PC using a USB cable (you may have to buy one as acording to the Phillips data sheet it is not supplied.) When the PhotoFrame is pluged in it will appear in Windows Explorier as a new hard drive, and you can copy your pictures to it.
I hope this helps,
Mike
Jan 03, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
How do I load my photos on a pandigital picture frame?
I could not load my directly directly from PC. I had to put them on my camera memory card, then insert memory card into frame. worked well but took more time.
Dec 29, 2008 | PANDIGITAL 6.0-Inch Digital Picture Frame...
I cant transfer pictures from my PC to a Digital Frame
either transfer to a usb pen or a standard digital card and then insert in photo frame good luck
Dec 20, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
Unshuffling photos
Hi JudyCrab,
I've found I need to plug a separate SD card into the frame and copy my pictures to that to get them to stay sorted chronologically like I want. The internal memory in the frame puts the pictures out of order every time but the SD card has been keeping them sorted fine.
Hope this helped.
Dec 14, 2008 | PANDIGITAL 7" Digital Photo Frame With...
I lost instructions to my Optimus 7" Digital Photo Fram
You can change out your pictures by having an XD or SD Memory cards if you have a card reader for your computer plug in the memory card put the photos on to it that u want on ur pic frame and plug it in to the xd/sd card slot on the left hand side of the photo frame and there u go. If you want ur pics off the internal memory u can transfer them from the frame to the card via the options button or menu button that is.
Nov 30, 2008 | PANDIGITAL 7-Inch Digital Photo Frame with...
PANDIGITAL (DPF802) Digital Picture Frame Logo
132 people viewed this question
Top PANDIGITAL Photography Experts
LP
Andrew Taylor
Andrew Taylor
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
