Question about Linksys (WI-FI LAPTOP KIT) 802.11b Wireless Access Point
No wireless main computer has internet laptop does not.
  • Pat Batta
    Pat Batta May 11, 2010
    Is Laptop using same WLAN protocol? as Main computer? 802.11 B?
You need to be a little clear on the spec of the laptop, operating system and the wireless router whether the PC is connected wirelessly or directly with a Ethernet cable. (sorry if this is embedded elsewhere - new to this forum).
If you are using a WEP key remove it temporarily and allow the laptop to find the network then see it if connects. There can sometimes be problems with the WEP key association / firmware of the router.
Also ensure that MAC Address filtering is turned off while trying to connect. Some laptops also have a wireless switch - ensure this is activated (sometimes a dedicated button, function key combo or even deactivated in the BIOS) There are so many things that need to be checked.
Posted on Dec 28, 2008
Laptop says no internet connection
First you need to ensure proper connection and filtering. Make sure the source cable is plugged into the Linksys router first. Direct connections must be made to the router, meaning the cable to your main computer should come from the router, not the main source.
Next make sure that the connection is made. You should see a light on the router indicating proper internet connection. Once this is accomplished, connect your main computer and you should have access to the internet on it.
Now comes the easy but somewhat tricky part (tricky only because icons can vary a little). If you haven't already done so, run the setup disk for Linksys. It's has simple, easy-to-follow instructions to set up your network. Now for the laptop. On the blue bar at the bottom of the laptop screen there should be an icon indicating internet connection. Click on that icon to show available wireless networks. Most likely your Linksys router will show up as a secure network. When you click on that connection it will ask you for a WEP key. That key is usually a 10 digit alpha-numeric key written on the back of the router. Sometimes it's on the box the router came in. Sometimes it requests a 12 digit WEP key, in which case simply add two zeros to the front of that same key. If you set up a password for your wireless network you will need that as well.
NOTE: if you have neighbors close, you should always secure your network with a password.
You may need to shut down and restart the laptop in order for the changes to take place.
It sounds confusing, but once you start you'll find that it's actually fairly straight forward. I hope this helps. Good luck!
Jan 12, 2010 | Linksys Wireless-G WRT54GS Router...
Can you hook up the ps 3 to the internet router to get online with out using a computer
do you have a wireless router?
depends on how your internet is set up
but if your internet is set up like this
internet plug on wall>>>wireless router>>>>main computer
then you can connect to the wireless router without having the computer to be on
if you can use the wireless internet using a laptop then i dont see why it wount work for the ps3
if you dont have a wirekless router and your internet router has several eithernet ports then you can run a either net cable from the router to the ps3
Dec 27, 2009 | Sony Playstation 3 (PS3) Console
Short connection and then no connection
This is a problem with the firmware of the router, so the best way to resolve this is to flash or update the firmware of this router then after that reset the router by pressing the reset button for about 15 seconds so the firmware update will take effect....
Nov 12, 2008 | D-Link DI 514 Wireless Router (DI-514)
Main computer hooked up but laptop isn'y
Right-click on the network icon is the sys tray (bottom right) and select Repair..." Also make sure your laptop wireless card has broacasting set to on (usually Alt-F1 or F2 will turn on/off).
May 27, 2008 | Computers & Internet
I have internet service with you. I want to know how do I get service for ny laptop
You can purchase a wireless home router and share your current internet connection between both computers. Most routers will cost less than $100, and will provide both wireless and wired connections on one device, so there would be no need to convert one of your computers.
All you have to do is connect your modem into the router's internet port, then plug your main computer into one of the other available ports. Setup your laptop to access via wireless, following the instructions in the user manual of the router, and you will be all set.
If you have anymore questions, please ask.
May 04, 2008 | Computers & Internet
Wireless connection
open control panel, wireless or network connections..make sure they are enabled..then go to front screen, and observe signal strength.
Mar 22, 2008 | Dell 1470 (W9284) 802.11a/g/b Wireless...
Wireless computer won't connect to internet
Somewhere in the network connections settings I recall seeing a checkbox to tell the laptop to automatically determine the IP address when connecting (as opposed to using the same one every time). Sorry I don't recall more specific directions ....
Jan 01, 2008 | Belkin (F5D7230-4) Router (587009)
You are connected to access point but the internet cannot be found.
Do you have a connection wizard that you can run on your computer? Linksys offers them for downloading at their website. Try that -
have you named your home network so your wireless connection can "find" it? You don't mention how your main computer is networked in. A wireless adapter for a notebook will need to have a Linksys connection wizard run on the laptop.
If you have a Linksys router connected to your main computer, it should already have the piece of software you need. Most likely, you'll need to put it on a flash drive and install it from that onto your laptop. the wizard helps also to diagnose the right settings.
If you want to post what you are using for your main network (linksys router?) and which operating systems you are using, that will help.
For example, in Vista, you'll need to enable the option for "network discovery" under your laptop's control panel/network and sharing center.
You also need to have certain settings on your main computer for the wireless to work - there are two main types of wireless connections - B and G. Most of today's routers and cards will do both, but if you have an older router, it might not be set up to handle the newer or combined types. They run on different frequencies, so your laptop might not be "reading" your router's frequency.Also, if you have other wireless/radio frequency equipment near your laptop, it can interfere with the signal being received right.
You also need to be sure that your firewall allows the linksys system to access your computer (allowed programs).
Dec 10, 2007 | Linksys WPC54G Wireless-G Notebook Adapter...
I cannot connect my laptop computor to my main computor
Bluetooth is not WiFi,   they are two seperate technologies.
you need a Wireless adapter 802.11b/g for your laptop,
you would connect the two to each other using an adhoc connection,
If you had a wireless router for your internet you could connect directly to the router, (and then you would not have to have your main computer on for you to access the internet.
BTW if your Main machine is near your phone point (for internet connection) you would not need a wireless card for your pc, as you could connect via LAN cable to the wireless router (make sure you get one with lan ports)
Oct 15, 2007 | NetGear - WG311 - 54Mbps 802.11g/b...
Linksys (WI-FI LAPTOP KIT) 802.11b Wireless Access Point Logo
73 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
