Question about Sanyo DS24425 24" TV
Volume buttons stuck inside
Hi there, hope you can help.. recently i pushed the volume buttons too hard and they became stuck inside the tv, we called a tv repair man and he took the case off and pushed them back out.. this cost £40. The same thing has just happened again.. is there any way i could repair this problem myself? Both buttons are stuck inside the tv. Many Thanks
  • 68 Answers
Hi , first i want to say that the tv is not a game it is hazard set very high voltage inside so if you don't have any experience please dn't try to , but you can do it your self just took outlet off and took case off and try to draw the chasses towards you to behind then look inside to the place of the buttons you will see aplastic tips which will push the volume switches that are soldered on the chasses and with your fingures try to push out the plastic tips to relocate it to the original state it is too easy and the please try to be away from the cable that is fixed to the screen cause high voltage is it, refix chasses and cover and give me high rate insted of £40:) regards
Posted on May 07, 2007
TV volume goes to loudest on it's own
It sounds like you may have a stuck micro button (volume button on tv) . You might try to push the up volume button on the tv several time and try to get it unstuck (if in fact that is the problem). Also sometime I have had situtions where the board holding these switches on the inside of the t was broke and had to be soldered and repaired.
If I can be of any more help, please email me at wyoed1@aol.com. "Original Radio Man" Ed
Feb 12, 2013 | Sharp 25R-S100 25" TV
Magnavox TV
Please provide the model number of the tv ?
The main reason for malfunction is due the main board is defective you need to replace the main board..................
May 27, 2008 | Televison & Video
NU-Tec 21"/51cm model NU2101N
It sounds like the main board is malfunctioning and needs to be replaced. Depending on the age of the tv, you may just want to replace it. Please post the make and model to help us better assist you.
Thank you for using Fixya and good luck
Apr 15, 2008 | Hotpoint RVM1625 Microwave Oven
The volume up button on the remote and the tv are not working at all and the volume down button works but it does not turn the volume down instead it cycles through what seems to be different modes of...
SEEMS TO BE STUCK IN MENU MODE ,TRY PUSHING THE MENU KEY ON YOUR REMOTE AND THEN PUSH IT AGAIN,,HOPE THIS HELPS.YOU CAN ALSO HIT THE MENU BUTTON ON THE TV ITS ON THE LEFTHAND LAST BUTTON....
Jul 15, 2011 | Samsung CXD1342 13 in. Combo
TV won't stop changing channels
Main board needs replaced !
Jul 03, 2009 | Televison & Video
Soyo Flat Screen TV Sound or Volume control is stuck
Hi deborah card, Lets first make sure your remote is not causing your problem, Look at the light (led) on the remote, is it lit and pulsing? If not you are having a problem with the control panel,  Have you recently cleaned your tv with a liquid? If so you will need to dry the panel with a hairdryer, unplug the power from the tv, put it on low heat and hold it about 6 inches from the panel for a few minutes. With the tv still unpluged press all buttons on the panel a few times then plug back in and try it.  Let me know if this helps and please rate this solution.   lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 11, 2009 | Soyo DYLT032D 32 in. LCD Television
Tv volume goes down of its own accord
Some dust in the button to lower the volume on your TV or on your remote control might be causing it to think it's being pressed. Try playing around with it, pressing it hard so as to relieve it of any pressure on the inside.
Jan 09, 2008 | Televison & Video
How to use Toshiba 32D46 32" TV with Comcast 3 in 1 Universal Remote Control
Most univ. remotes have a search mode if code entry won't work-
Do you have the comcast instructions ? Something like.....
1) Tv power on
2) Push set-up or program on remote
3)Touch tv button on remote
4) Point remote at TV and push power off. Repeat until TV turns off.............then
5)Push enter to save....
Hope I helped you........T.
Nov 07, 2007 | Toshiba 32D46 32" TV
Sony 36' TV Volume Goes up on own/Stuck on Video 2
There's a setting in the menu. I think it's called "smart audio". It's supposed to adjust the volume automatically for commercials. But I don't think it works that well. Give that a try.
Jan 09, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Volume of the tv goes up by itself and no other buttons are working on the remote or the Tv
sounds like theres a problem with the front panel push button for the volume; In most cases it gets pushed too hard or just too week to stand up to multible presses and so the button cracks and de[resses the switch. If one switch is depressed none of the others will work as well . Simply open cabinet and pull back the chassis and relese the stuck button
Mar 29, 2006 | Apex Digital AT2008S 20" TV
Sanyo DS24425 24" TV Logo
150 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
