Question about Logitech Z-5300 Computer Speakers
Need replacement speaker wires from the sub to the computer.
Box did not have the speaker wires from the sub to the computer, is there a place to get the wire connection?
  • Anonymous Mar 30, 2009
    i have 15 year old computer speakers made by air wave and they work fine but while moving to a new place i lost one of the wires to connect the sub to the computer where can i find a replacement
    President:
  • 1,179 Answers
Thise store: http://www.cablestogo.com/ usually has about any type of replacement cable you could ever want or need. Hope this helps & please remember to rate my answer.
Posted on Dec 27, 2008
Wire 2 sub 4ohm
I am assuming these are subs, you didnt say, but that is my guess. do you want bass, or do you want to take it easy on your amp? do you have a terminal cup on your sub box, or just wires going into the box to the speakers? take it easy route: wire positive from amp to positive of one speaker, negative of amp to negative of the other speaker, with a jumper wire connecting the negative of the first speaker, to the positive of the second.
more bass route: run seperate positive and negative wires to each speaker, making sure to maintain proper polarity.
Oct 21, 2013 | Jl Audio 500/1 Car Audio Amplifier
I need to see a wiring diagram of an MPX 210 speaker box. My brother-in-law bought one from a friend and someone completely jacked the wiring. I just need to see how it should be wired. Pictures would be...
It really depends on what subs you are mounting in the box. If you are mounting single voice coil subs, it's easy. positive of the sub goes to positive on the inside of the box and the negative of the sub goes to the negative of the box. Then you would repeat the process for the other sub. Then wire the box to the amp using the push or screw terminals.
Now if you have dual voice coil subs, that's where it can get tricky. You really have to know what amp your using and what ohm load it can handle, and how many channels you will be using.
I'm going to give you an example that has two dual 4 ohm voice coil subs. Let's assume you will be hooking them to a 2 channel amplifier that is 2 ohm stable.
wire the positive of both voice coils to the positive post of the box. then wire both negatives of the voice coils to the negative of the box. Repeat the process with the other sub. This is called a parallel set up. Two 4 ohm voice coils wired this way will produce a 2 ohm load. since your amp is 2 channel, you will hook the positive and negative to the positive and negative of one side of the box, then repeat with the other channel to the other side. This will allow the most power to come out of a 2 ohm stable amplifier.
If you have something other than the equipment I gave you an example of, repost with your equipment specs and I will walk you through it.
Sep 09, 2011 | Dual QPower 10" Square Slot-Vented...
I have two wires coming from amp and my sub box only has one possitive and one negative for two subs how do I make this work
Your subs are set to connect as one channel... One Speaker, even though as a SET.
You can either hook them up as is. meaning to the rear amp channel or the front. which ever option your amp offers.
OR
Open the sub box, disconnect the one speaker from the other and fish the new wire through the box so you can connect them to the Amp separately.
I suggest going with the first option and connecting them on the AMPS, rear channel...
Good luck
Respectfully
Jun 10, 2011 | Car Audio & Video
The power light is on but the sub not playing at is also a kicker product. A 12 inch sub all wires are in the right place a audio shop did the work for me. Can you please tell me what is going on.
Is your sub in a box? the power light is on your amp? try to connect a car speaker to the port you have the sub plugged into, if the speaker works its not your speaker terminal on your amp it's the sub. Check the wiring on the connectors of the back of the sub itself and the wire terminals inside the box (if sub in bass box)
Please let me know if this was any help and let me know if it solves your problem
Mar 05, 2011 | Kicker Car Audio & Video
I was given a Sharp HT-DP3000 reciever and all the speakers that go with it.. but I don't know how plug in the speakers into the wire there is a box for the two surround and a separate box for the right...
Do you have speaker wire if not you will need some, the wire is cheap about $5 bucks a roll your local department store will have it. You see a red and black tabs on the back of the unit and on the back of each speakers you push down and stick one wire in the hole. red will be your + and black will be - The two surround go on the back wall behind your seat.The center will sit on top of TV and the sattalite speakes go beside the left and right side of TV. and the sub sits on the floor in hidding behind something or under a table. (P.S, Make sure the wire is shaved about 1/4 of inch before you stick in the wire DO NOT plug the power cord in, intill you hook up all the speakers this could damage the unit. You do not need a sub woofer, if you have one great If not don't worry that will not damage the unit it has a internal switch to turn on/off the sub woofer The sub woofer offers extra deep bass that you can't get from the sattalite speakers.)
Aug 31, 2009 | Sharp HT-DP3000 System
I don't know where to hook up the wires running from subs
the r+ and r- are for the right sub and the l+ and l- are for the left sub
Jun 14, 2009 | Jensen LXA300 Car Audio Amplifier
Popping sound! please help - jl 500/1 and two jl w3v3 2ohm subs
no connection are good + to + -to - thats all that matters. either the speakers are blown or you need a stronger amp. since you already tried speakers probably need bigger amp. definitley not the box. no such thing as a break in period, are the subs 10 12 inch or what. you could try to bridge them too that means hook both up to the same +-terminals, 2 wires per screw. it usually isnt the way they hook them up, its the wires fuses etc that cause problems. what guage wires is the speaker wire, the power line etc. if you give me these guages i might be able to get somewere
Feb 24, 2009 | Jl Audio 12W3 Car Subwoofer
ONLY ONE SUB IS WORKING
did you try to switch channels with the subs and see if it is the channel on the amp. if it works then its the sub and it will need replaced
Apr 01, 2008 | Jl Audio 12W3 Car Subwoofer
Ampflier only pushing one speaker
the wire on the back of the sub box is not fully connected prolly so get access to the back of the sub box n adjust the positive n negative wires n move them around until u get the right place n it will push both
Feb 19, 2007 | Kenwood KAC-7202 Car Audio Amplifier
Logitech Z-5300 Computer Speakers Logo
985 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
