CRT Computer monitor
How to disassemble a DAYTEK 755DF 17" computer monitor? I have a problem with and suspect a cold solder on the card/
  • michel47167 Dec 31, 2008
    Thanks for the help!
    Sergeant:
  • 279 Answers
Unless you're hell-bent on doing this, I'd say just dump it and get a new, cheap LCD. CRTs are not really user-servicable (as the labels and manuals clearly state.)
If you must, check out this site with a how-to...
http://www.instructables.com/id/How_to_safely_disassemble_a_CRT_monitor/
Good luck. A new LCD would probably be less troublesome and time-consuming.
Posted on Dec 28, 2008
When switch on the monitor,display will be full of black or white blurr ,when hitted it will be in good condition
Hello
The problem is with some loose solder points inside the circuit board of the set. Just resolder all the suspected solder points by applying a little more solder, without making any solder bridge short in between adjecent solder points. Note the solder points of components, that will heat up while working. Resolder these solder points as I stated earlier.
Oct 19, 2011 | LG Studioworks 700S 17" CRT Monitor
Display probelem - white rasters
Hi, have you experienced tapping your monitor and display changes? try to re-solder cold solder electronic components in the mother board and neck board.
Jun 21, 2011 | HP S7540 17" CRT Monitor
My philips 104E 15" monitor is not displaying red colour at all.other two colours are perfectly OK.What could be the cause? is the red gun gone?
Yes, or the RED driver circuits is bad, check soldering joints on the CRT PCB. Simple thing to do is to check the VGA cable connection first, check the video card (reseating the card).
Apr 21, 2010 | Philips 107E61 17" CRT Monitor
Hello My PC monitor/CRT 17 inch. not getting
check the signal cable bend it in on condition and look what difference in color occurs if so then replace the cable if not that fault then ther is a dry solder on the base of monitor find out and clear it
Apr 05, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
LG 37lc2 no red
open your monitor and resolder the CRT board. CRT board is a board that attach to picture tube .
Feb 20, 2010 | LG Flatron F700P 17" CRT Monitor
I have a similar problem, please let me know if you have the fix
Hello
This is RGB issues the problem is in the CRT Board where the RGB is, this need to re solder the RGB board or CRT Board maybe you have cold solder...
Angel
Thanks...
Aug 02, 2009 | LG Studioworks 775N 17" CRT Monitor
LG 505G problem
it can be a cold soldering..
Jun 25, 2009 | LG Studioworks 700S 17" CRT Monitor
My moniter wont boot its on standby mode
it is the cold solder problem.pls solder the board careefully
Mar 10, 2009 | LG Studioworks 700S 17" CRT Monitor
Light blue color
look for cold solder joints on the crt neck (color circuit) board!
Nov 02, 2007 | CTX PL7 (Black) 17 in.CRT Conventional...
My monitors turn off after a minute
maybe you have a "cold solder", if unit keep turning on when it's cold, is it... If you have the skill to open it and you have a solder iron, maybe you can try to fix it, if you don't leave it to the repairman.
Sep 17, 2007 | Compaq CV 7500 17" CRT Monitor
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
