Question about LG RZ-37LZ55 37 in. HD-Ready LCD Television
Toshiba WLT56B stuck in standby. Please can anyone help?
No other problems with TV recently. New batteries in remote, Top of set buttons don't work either.
3 Suggested Answers
SOURCE: tv switches itself on and off no picture
Just had this happen to me. It's caused by a failure of the power supply board. Replacing the power supply should fix this issue.
This appears to be a very comon problem.
http://www.reviewcentre.com/reviews110919.html
Cr1spy.
Posted on Apr 06, 2009
  • 68 Answers
SOURCE: remote does not work
Did you drop the remote lately my dog loves the plastic and knarls and slobers on them. Go buy a cheap replacement and try it
Posted on Mar 25, 2010
My toshiba tv 32kc500b is not starting at all with remote or without remote
KV suggests it is a Sony and not a Toshiba?
general answer:
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.
Apr 01, 2012 | Televison & Video
No Picture on Toshiba 42RV530U
I had a similar problem to this yesterday. Tv is same Toshiba model as you mentioned about 4 months old. In my case, after the TV working perfectly following installation, the standby LED on the front (the one that is red on standby and green when on) went to a flashing orange (after switching on from standby) and the picture disappeared although the sound remained OK. I was unable to get any response from the setup or menu on the remote, otherwise I would have tried resetting the TV. Regardless of how much switching off/on (including disconnecting the powerlead and leaving for few minutes), disconnecting all peripherals, etc., nothing helped. I looked up Toshiba's web site and under support they basically suggest switching off the TV and restarting using the onset buttons (not the remote) and pressing the menu button (again the one on the set (not the remote) and if you could get the menu box to appear then reset to default settings. I tried this but the results were the same. I therefore thought the TV was defective. However, after much frustration I did the following (I think): 1) Disconnect everything from the TV 2) Powered up from the mains switch whilst keeping BOTH the startup and menu buttons on the side of the TV pressed down. The result in my case was that the standby led and one of the two beside it flashed green simultaneously. However, when the buttons were released, the TV started up the same (flashing LED orange and sound no picture). 3) Pretty well defeated at this point, after doing the procedure at (2) several times with the same results, I somehow thought of pressing the standby button on the remote either whilst the two buttons on the set were depressed or just after they were released. I am afraid I cannot remember which and cannot replicate the problem as I don't know what caused it in the first place. 4) The TV then started normally ( no reception as I had not aerial connected, etc.,) but I was able to gain access to the screen menu/setup buttons via the remote which were in French rather than English. However, after reconnecting everyrthing the TV has worked fine (obviously after resetting the language via the menu). I am sorry I cannot be more precise but I hope this might be of help to someone with a similar problem.
Oct 04, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I have a toshiba tv with a broken power button
Generally the power button has to be on first to put the TV in standby mode. If you cant do this no remote can ever work. Remotes are not capable of turning on a set that has no power mechanically turned off. and that is what the master switch does. once that standby light is off it is not live and consuming power and not under the control of a remote anymore
please rate our help++++Y=Thanks for using FIXYA
Sep 25, 2009 | Sharp 27N-S100 27" TV
My tenplus year old Toshiba 32" TV is stuck in standby mode
You have an old tv so the best problems are bad capacitors and bad grounds. Have someone pull the board and search for high voltage caps [160volts or 250 volts] with 1 to 4.7 microfarads. Should be two or maybe three and check all grounds. If the 4 amp fuse is good than the above will save your TV.
Sep 24, 2009 | Toshiba 32A33 32" TV
Toshiba 14DLV75, stuck in game mode, buttons on TV & remote
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Sep 03, 2017 | Toshiba 14DLV75 14 in. TV/DVD Combo
TOSHIBA 35 TV 35A44
don`t know if this will work for yours but I have heard of menu coming up all by itself randomly and the fix was to remove the batteries from the cable boxes remote and the tv`s remote, partially stuck on buttons were the cause, replaced the remote end of problem, hope this helps on yours.
Nov 29, 2007 | Toshiba 35A44 35" TV
Problem with my TV 32 Inches Phillips
I need a manual in a remote to work my 32 inch phillips tv so I can view the tele prompt screen to wide need to minimize
Oct 31, 2007 | Toshiba 32A41 32" TV
Remote sensor
Bad connects at sensor inside TV or bad sensor.......
Toshiba part # 23009490............T.
Sep 21, 2007 | Toshiba 36A60 36" TV
Remote control problems
Answering my own question,Switch on recorder manually then hold down SETUP KEY and No 2 key at the same time.As this is a common fault with this recorder would advise taking note of this solution.
Oct 21, 2006 | Toshiba RD-XS34 DVD Player/HDD Recorder
Tv stuck in standby
If you can not turn on TV set with the power button on the TV its not a standby problem as this would by pass the standby. Theres most likly, on a set of this age, top have a poiwer regulator problem and is going to need a trained tech to assist you in this repair.
Sep 10, 2006 | Sony KV-32S42 32" TV
LG RZ-37LZ55 37 in. HD-Ready LCD Television Logo
