Question about Xerox DocuColor 12 Printer
Can not print from computer "error out of paper message"
I have went and conduced everything in the manuel and still can not print...I can however faxe (send and receive) and copy other documents. But I can not print from the computor. The priner being a HP L7680 series does not have IP numbers in the networking, mask or gateway. I can type them in but they will not stay. anyone with any help will be appreciated. The hp techs don't seem to be able too.
  • 79 Answers
Hi pls check ur paper try paper detecting sensores.
Posted on Jan 24, 2009
Brother hl-3045 jam inside
Had the same problem, called help center and fixed it!!!
Problem occurred when i tried to print colour labels from Word.
Black cartridge printing worked fine.
When using manual feed (pull down black panel in front which says 'brother'- you'll get the message for this if printing labels
you must open the back door of the printer.
got 'paper jam inside' error message.
Here's what I did and somewhere along the way, something worked.
Turn and unplug machine
take out all drum cartridges (all 4)
Take out the black belt (everything you can remove has a green arrow or tab- easy)
check to see if there's any paper in there- there was no paper in my case.
separate the drum from the cartridge for each colour and check the colour roller and the fuser film roller- don't touch them- no paper stuck that i could see
put them back together carefully.
Put the belt in and then the 4 cartridges
do a test run- mine still showed error message- paper jam inside
switch black with each cartridge and do a test run for each. When i switched with yellow - didn't work, magenta- didn't work- cyan- WORKED!!!- the colours were messed up on the document but it went through and printed without the error message.
Here's the sequence of what colour cartridge went in which spot.
Yellow in black slot
magenta in yellow slot
cyan in magenta slot
black in cyan slot.
then i switched them back to the way they are supposed to be and tried to print again and it worked!
the colour is amazing on this printer- i had the trouble right from the beginning after installation.
hope this helps.
Nov 21, 2012 | Brother HL-3045CN Laser Printer
Error Number : 1003 No paper. Load the paper in the cassette correctly and press the OK button on the printer. Plain paper of A4, Letter, B5, and A5 sizes will be fed from the cassette because...
Another possible reason for getting this error is a dusty printer. I don't dust very often so dust piles on everything, including my printer. My daughter wanted me to print something for her and the first page went through just fine. But the second never started and I got error 1003. I had plenty of paper loaded and my settings for the size of paper were correct. I dusted out my printer and everything else printed just fine. My theory is the top paper had dust bunnies on it that were pulled into the printer when it pulled the first page in. Maybe the dust got caught on a sensor that told the computer there wasn't any paper. Regardless of what happened, a quick cleaning fixed the problem. I just wanted to throw in my two cents for anyone out there that may have a dusty printer and run into this error.
Sep 08, 2011 | Canon PIXMA iP1500 InkJet Photo Printer
When i print ,I get this error 'Manual Feeder Paper Empty
You are most likely getting this message because of a paper size mis-match. For example, you are sending a print job as letter size but your printer is set to or has a4 size installed. When the printer sees that the print job is not a matched size to the paper in the tray, it will look to the manual feed tray for paper to print on, hopefully the correct size. Make sure your paper setting in printer properties on your computer match the paper in the printer and the print job "page setup" is also the same size/
Oct 06, 2010 | Samsung SCX4623F Laser All-in-One Printer
Pixma 610. Won't print - error message is "Paper Output Slot - Paper is jammed. Clear paper and press OK. On my computer, it calls this an error 1300. There is definitely no paper jammed! I checked...
i had the same problem. i went to the settings and did all roller cleaning, head cleaning and still got the same messages. finally i made a copy which worked, after that it would print from my pc. try that.
Mar 03, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Error message reads "34 short paper". What does this code mean and what can I do to correct it? Thanks
This error means that the type of paper that is configured in the printer is different from the one you have chosen in your computer to send for printing. Make sure that the paper size is the same in both places the computer program you are using and the printer. For example if I have a Letter size word document that I want to print but the printer has A4 configured then I will get the 34 short paper error but If I change the paper in the printer and the setting to letter size then everything should print fine.
Nov 13, 2009 | Lexmark C510 Laser Printer
Error Message: No Paper, Load Organizer....................
Opened "Control panel>printers/faxes>Printing preferences>Basic>Paper source, and selected Tray 1 for all pages. Then went into the print menu in Adobe Reader, wich is where I was trying to print from originally, and deselected "choose paper source by PDF page size. It seemed to work.
Jul 18, 2009 | Brother HL-4070CDW Printer
Error - carriage jam message
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Mar 20, 2008 | HP Officejet 6310 All-In-One InkJet...
My printer
sounds quite compelling
Mar 08, 2008 | Epson Stylus C60 InkJet Printer
Xerox DocuColor 12 Printer Logo
80 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
