Question about Dynex 32 in. LCD Flat-Panel HDTV
Can't get the picture to be wide screen
The TV only shows a picture in the center of the screen. Please help.
  • Anonymous Dec 27, 2008
    Im having the same problem and want to know how to fix it.
On your dynex t.v remote there is a button labeled "zoom" at the bottom of the remote. There are 4 or 5 different options you can choose between to view the picture. Press the button each time to view the different picture.
Posted on Dec 27, 2008
Power light but no picture or sound
Hi!
My name is Chris.
I have this Phillips Wide Screen TV that didn't have or come with a remote, so I had to go out and buy a universal remote for it today from a BIG W Store. I'm having some technical difficulties & problems with switching and turning it on, but as I use the universal remote to turn on the TV, I'm having a bit of a slight problem with it turning it on, Ok, Yes, it works and Powers on, but there is nothing showing or giving me the indication that there is no picture or sound showing up on this Wide Screen Phillips TV, But there is a little red & green light at the bottome right hand corner that keeps on flashing red when ever I use the universal remote to switch the power on. Is there a possibility, that i can get some help on here, to help me out with any suggestions, is to why I'm not getting any picture or sound showing up on this TV with this universal remote ? Is there anyway that i can maybe get some help with this to help me out with solving my issue with the Phillips Wide Screen TV ?
Nov 17, 2013 | Philips 42PF7320A 42 in. Plasma HDTV
When I turn it on there is just a horizenal line. This is on a Mitsubishi cs 35 ax 1 35" from 1992
hi there, it seems you have problem with your VERTICAL IC, this is similar to all CRT I have repaired. horizontal lines in the middle huh! well the picture is deflected in the center of the screen. it shows your TV is oscillating. means it is good. the problem is that you cannot adjust the picture to occupy the whole monitor. By replacing the Vertical IC it will remedy the picture to view widely. the vertical IC has these many 8-10 pins and mounted on heat sink. Usually mine is serial with LA 7837. good luck on your troubleshooting, hope this help, please rate and vote.
Mar 22, 2011 | Televison & Video
How to get an undistorted picture without cropping. This is an Olevia, and it is not listed below.
I assume you have a wide screen tv? most TV show are broadcast in a square (4:3) format, on a wide screen television the screen is rectangular, so to fit the square picture on the rectangle screen you have to either crop the top and bottom, or stretch and distort the image. the only real solutions are either to watch everything in the 4:3 format (leaving the sides of your screen blank), or subscribe to HD which will broadcast most programs in a wide screen format with out distortion.
Sep 14, 2010 | Televison & Video
How to center a screen?
Horizontal centering is performed in the service menu. Beware! You can mess up a lot of stuff in this menu.
Aug 02, 2009 | Toshiba Televison & Video
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
Half screen showing
ok
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
Jan 13, 2009 | Samsung TXG2746 27" TV
Sanyo 42" 1080p, picture doesn't fit on screen
this is normal and this feature is for wide screen programs! normal shows and games will lose part of the top of the screen sides and bottem because it zooms in on whats in the middle of screen! hope this helps
Dec 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sylvania 27 in tv picture
It sounds like your vertical has shrunk, causing the picture to look squashed. Most likely a bad component in the vertical output stage.
Dec 19, 2007 | Sylvania 6413TC 13" TV
Toshiba 46h83 tv projection not full orizontal pic
if you go to the menu on your tv it should show picture you may need to snoop around for it but its there and when you do find it adjust it untill you got a nice picture about the tv not being full on the screen try buying wide sceen movies it should help but the adjustments should help the most
Jul 30, 2007 | Toshiba 46H83 46" Rear Projection...
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Dynex 32 in. LCD Flat-Panel HDTV Logo
145 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
