Question about Akai LCT2715 27 in. LCD Television
Need Power Supply for AKAI LCT2715 Repaired
I read this post after experiencing the same popping and LED blinking on my AKAI. I have removed the power supply and see the bulging caps. I would like to have you repair the power supply. Please reply to JHTXTU84@GMAIL.COM with details on payment options and shipping info.
Thank you,
Jeff Horka
  • 2,337 Answers
I repair these power supplies.
If you require further assistance you can write to jah2mil@hotmail.com
Posted on Dec 29, 2008
Fault finding
1.not much info here.
>> please leave a model number <<
2. more info on issue would help (wont power on, boots to bios but not windows) ill assume the word dead means the system wont power on.
3. if the system will not power up then the led is likely communicating a POST message. POST messages can be referenced on the e machines support site.
4. typically one would remove all non-essential hardware and try to boot (ram is pretty much the only essential hardware {depends on the model})
\/ if no info on POST messages is found or is not helpful \/
5. Power supply can be tested with a multi meter if you have a multi meter see here: http://pcsupport.about.com/od/toolsofthetrade/ht/power-supply-test-multimeter.htm
6. (WARNING there is a slight chance that you could harm the donor supply try this at your own risk) you can try swapping power supplies if you have one that is compatible (from an old machine or from a different machine for testing purposes). if it boots with diff PSU then that's the problem.
\/ for the brave \/
(de-soldering \ soldering can be difficult without the proper equipment and technique read up first)
7. look for bulging capacitors on the motherboard if caps are bulging they can be replaced with caps that are exactly the same.
Oct 22, 2013 | E-Machines Computers & Internet
Dark Screen, unreadable. Power Led Lights. No noticle sounds.
If you are going to DIY repair, please read below and look at the pictures of failed SAMSUNG monitors (bad caps with bulging tops)
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 10, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
My Akia 27" lcd tv wont come on, all I am getting is a flashing red light and a popping sound. What could be wrong with it?
Ur power supply board is dead.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 21, 2010 | Akai LCT2715 27 in. LCD Television
ON OFF LED BLINKS TWO TIMES
Hi!
Sounds like you have a bad power supply board! This is not hard to do yourself, as long as you are somewhat handy! Take the case apart (back side), and look for some bad caps (capacitors) on the power supply board. They will look bulged on the top an may be a little leaky (brownish stain).
If you see this problem, you can buy a new power supply at www.shopjimmy.com or ebay. You will need the make and model, of your tv to order! Good luck, I hope this is helpful!!
Mar 12, 2009 | Televison & Video
AKAI LCT26Z4AD wont power up.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 10, 2017 | Televison & Video
Power supply
Its possible that it is the power supply. If you wanted me to take a loot at it I could but you would need to remove the power supply from the TV and ship it to me. The power supply has been a common fail point of TV's, VCR's and other home electronics in the past several years. Let me know if this is something you would like to discuss further. I just need contact info.
Dec 29, 2008 | Akai LCT3201TD 32 in. LCD Television
Will not turn on, only blinking green light
Ok, your on the right track... Check the main fet or fets that is located right by the caps. Normally if the fet is short, it will pop the fuse, but if your caps poped instead, it could have prevented this. With the set unplugged, you can take a meter set to ohms (lowest setting possible) and if you read a value across any of the 3 pins on the fet (short), then it shot.. If that checks out ok, then take a peek at all the other smaller caps that are on the hot side of the board (the bottom of the board will be labled hot and cold. If one of these was out, it would prevent any of the other voltages from being present. The 5v is a standard test signal, it will normally notify the rest of board to power up when there is a draw on it (kind of like a computer power supply). But I highly recommend replacing all the caps on the hot side of the board and it should fix your problems.
Apr 06, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai 2662
I have to assume that your post is some question concerning the SMPS on the Akai TV and then further assume that you're dealing with a dead condition??? That given, you probably need to replace several caps on the SMPS that can be ordered as a kit. The kit supplies 19 caps in-all (4) 3300/35v, (8) 2200/25v, (6) 1000/10v and (1) 1000/16v the last seven 1000uf caps can all be 16v if you order the smaller style.
That is assuming you are experiencing a dead condition on your set. It is best if you can give a tech a little more to go on than "power suply" if you're actually wanting any real help.
Bill
Mar 27, 2008 | Akai LCT2662 Television
Akai LCT2715 Led blinking orange and set won't turn on
There are about 16 to 17 capacitors that are a common fail point on this TV. I can repair your power supply board with new high quality capacitors and recondition the board to work like new for $100 + S/H, you simply have to send me the power supply module and turn around is approx 2 days from the time I receive the package to the time its out the door. Approx 8 business days according to the delivery carrier you use.
Apr 09, 2007 | Akai LCT2716 27 in. LCD Television
Akai LCT2715 27 in. LCD Television Logo
94 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
