Question about Onkyo HTR500 Receiver
I have a onkyo HT-R500 receiver and it keeps blowing fuses.
  • 1 more comment
  • Tammy
    Tammy Jan 01, 2009
    Thank you for your reply! Yes...I used the correct type/size of fuse BUT No...I did not have the speakers connected. As soon as I replaced the fuse and turned it on, it blew the fuse immediately.
  • Tammy
    Tammy Jan 01, 2009
    Thank you petraman7.
  • Scott Frye
    Scott Frye May 11, 2010
    Hi..
    Are you putting in the size and type that Onkyo has spec'd out for it?
    Are the speakers all connected?
    If so , either the power transformer or AC rectifier has shorted.
    You can get it serviced if you dont mind putting in $100-150 on it
    Sergeant:
  • 349 Answers
Anyone that replaces a blown fuse without investigating what caused the fuse to blow is only asking for an existing problem to be made worse. A fuse is a safety link that only normally breaks down when something in the circuit reaches failure point.
By just replacing a fuse it's like you are saying to the equipment.........."Now go on and fry yourself some more like you just did !"
And guess what.........99/100 that is what it will do. This means the repair that may have been minor has now been made major......and may even result in fire or injury to the user...thanks to the user's ignorance and laiise affaire. This is really a safety issue as much as anything else, and in my opinion, shops should not be allowed to sell fuses to other than people who are qualified to inspect equipment for causal fuse failure first prior to replacing them. But then.......we have tried to stop selling cans of paint to minors haven't we?
Oh well !.......... back to the drawing board!
Posted on Oct 30, 2011
Onkyo HT-R500 5.1 home theater receiver. I have had a recent problem with this receiver. The volume does not come out clearly on all speakers, and it does not increase gradually like it should. I have tried different speaker wire and speakers and nothing else seems to be the problem. The receiver turns on an off fine, and you are still able to hear the sound from the source selected, but it just doesn't sound balanced and you don't have the fine control on the volume. Has this problem occured with any one and what is the correction to this problem.
Posted on Jan 08, 2011
    Genius:
  • 1,175 Answers
A receiver that recent usually has a detect circuit that keeps the outputs off until speakers are connected . So, if it bows fuses right away , it's really a power supply issue.
Probably the AC rectifier bridge.
Tech service only.
Posted on Jan 01, 2009
How to setup
http://www.manualslib.com/manual/302221/Onkyo-Ht-R500.html
Jan 10, 2015 | Onkyo Ht-r500 5.1 Channels Receiver A/v...
Av receiver HT-R500 just keeps shutting itself off?
Too much voltage going in the receiver or you have the wrong size fuse in it.
Aug 24, 2012 | Onkyo Audio Players & Recorders
Onkyo AV Receiver HT-R500 No power whatsoever, no illumination of any display options and no activation clicks upon pressing the power button! We inspected the receiver via dust cover removal and found no...
If that is true the power transformer is probably open at the primary, the secondary voltages feed the receiver and power various parts. I suggest getting it checked, my worry is the power transformer may not be available from the parts manufacture.
Mar 28, 2012 | Onkyo Audio Players & Recorders
How much did the onkyo ht-r500 cost new
I've seen one person claim that they paid $799 quite a few years ago when it was sold as new at the now defunct Circuit City.
Jul 01, 2010 | Onkyo HTR500 Receiver
Connecting Sirus audio to Onkyo HT-R500
Carl- If you are sending a Line Level Audio signal to your ONKYO RECEVER, from your Sirus RCA cable Output, IE, the CD input, the VCR input, the AUX in, ETC. No Need to have the RECEIVER in the FM mode, you are just needing amplificaton of the sound signal or Sirus signal sound.
Feb 28, 2009 | Onkyo HTR500 Receiver
Losing memory settings
On remote control before you shut off yor receiver press "TEST" button to save the memory. It will save every setting. Make sure to do that all the time after you change the setings.
Nov 23, 2008 | Onkyo HTR500 Receiver
Onkyo ht-r500
I found the manual sometime back...try 3Xdouble-u dot eserviceinfo dot com
Aug 06, 2008 | Onkyo HTR500 Receiver
Onkyo HT-R500
Unit has circuitry problems, take in for service
Mar 14, 2008 | Onkyo HTR500 Receiver
Wireing
Consult HT-R500 operations manual for hook up
Feb 08, 2008 | Onkyo HTR500 Receiver
Blown Fuse, needs fix'n
You CAN open the unit (keep in mind that even unpluged there is still voltage runing through the system, so.... dont fry) and you will notice, if the face of the unit is towards you you will see on the left hand side a power supply board, the fuse is on that board, and it is a tube fuse, 125V 8A. Most stores do not carry the 125V version anymore, but will carry a 250V. This is okay to use where the voltage is not the main purpose of the fuse.
Oct 19, 2007 | Onkyo HTR500 Receiver
Onkyo HTR500 Receiver Logo
351 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
