Question about Fuji FinePix F460 Digital Camera
Unable to access menu
Just tried taking photos, normally the photos are visible for a short time. This no longer happens. I tried to access the menu, but to no avail. I am unable to turn on camera with right arrow button on rear of camera next to f button. Disp/Back button doesn't work either. I can turn flash, macro and redeye on and off when camera is on Auto. When it is on SP no buttons work except the shutter. When camera is on SP the macro, flash off symbols are on and there is also a symbol of a film cartridge with a C ( I haven't noticed this before). Video also works, but also unable to view it
Screen on Auto and SP also shows 5M N 373 in top right corner
Battery is fully charged
I am able to download photos to my Laptop without problems
  • johnbyrne316 Dec 27, 2008
    Battery is absolutely fine and tried your suggestion. No luck, but thanks anyway
    Previous comment relates to classyexpert's unsuccessful suggestion
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, it would appear that all the hardware perform nominally. This would then indicate that it is the software half that has some glitch. The software/firmware normally could be re-flashed or updated but would require specialize equipment/interface which are not readily available to most user(s).
This then would require the services of an authorized service center for Fuji digital cameras capable of handling your camera's specific requirement. If the cost of repairs and downtime would be factored in, then you may have to re-evaluate your options of having it repaired and/or consider a replacement.
Good luck and Thank you for using FixYa. Happy New Year.
Posted on Jan 01, 2009
    Genius:
  • 1,239 Answers
Hi
Use an eyeglass screwdriver to remove the back half of the case. (6 screws, 2 screws each on sides and bottom) When you remove it, the ribbon cable for its buttons comes out just by pulling. You now see the LCD (which is fine), its cable connection (lower right), its power connection (two wires on right). Either these wires have come unsoldered (easy to fix without microsoldering capability) or some part of the power supply for the LCD backlight is bad (very hard to fix, you probably need a new motherboard). When you put the case back on, first you have to plug in the ribbon cable - first open the tiny black plug lock out and around to the left, put the cable all the way in, then lock the black part back right and in. Screw the case back on and you're fine.
Posted on Dec 27, 2008
  • 837 Answers
Try removing the batteries from the unit for 30 minutes and try again
    Sergeant:
    Novelist:
  • 327 Answers
Let the battery be charged but if the battery is old it is unable to hold charge and stops functioning so try replacing the battery.also try removing the memory card and reinserting after 2 minutes sometimes this helps.
    Novelist:
  • 121 Answers
First, can you please describe this strange icon a bit more? I can't find any icon that matches your description of a "symbol of a film cartridge with a C". Is this one of the symbols shown in your manual on page 9? If not, where does this display - compare its location with one of the symbols shown on page 9.
If you don't have your manual handy, you can download it here.
There are 2 possible problems. One is a physical malfunction with the camera, the other is a software malfunction. If it is software, it should reset when you remove and replace the battery. If that solves your problem, great! If not, please reply with the information I asked for above, and I'll keep working with you to help solve this problem. There may be a hidden battery (stores the date/time), and there may be a way to load a firmware update from the memory card. I'm going to look for more information on these items now.
No image shows when I take picture
Usually the photo is displayed for a short period of time. Try the setup in the menu. There should be an option for previewing recent pictures.
Jun 20, 2012 | Fuji FinePix S2 Pro Digital Camera
I installed The Print Shop Photo Workshop a number of years ago & no longer use it. However, I find I am unable to uninstall it.
there is usually an uninstall icon on the menu when you access the program through the all programs menu. windows also has an uninstall utility in the control panel area under the title "programs" sub "uninstall"
Jul 15, 2011 | Computers & Internet
LCD display full of lines. unable to view the object or take picture. not fallen any where. suddenly it happens. camera placed near a live TV then it happend visible
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Feb 09, 2011 | Nikon COOLPIX L20 Digital Camera
All of the icons are still visible, but otherwise, the screen of my t99 is showing up blank. The camera still takes pictures, but the photos are black and so is the display. Please help! No temperature...
This may be due to the CCD Image Sensor failure in the Camera.
To confirm the issue, please check if the previously captured images are displaying normally. The previously captured images and icons will get displayed normally if the CCD image sensor issue is there in the Camera.
If this happens only with the live view, then try Initializing the Camera.
The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETTINGS-->MAIN SETTINGS-->INITIALIZE-->OK.
You may also try power resetting the camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally.
If the issue is not resolved after resetting, service may be required.
Thanks for using FixYa.
Jan 18, 2011 | Sony DSCT99 Digital Camera
Intermittently unable to review photos taken with Sony A100. Also at the same time unable to access the menu
Is the CF card a slow or counterfeit one? There are lots of cards on auction sites that are branded, but copies with poor quality components. try a known good High speed card. Also check if you have any bent pins in the camera CF slot.
Jun 02, 2010 | Sony Cameras
Unable to take photos. F stop flashing and r05 message shows.
do a reset in custom menu and you will be back to out of the box set up
Apr 13, 2009 | Nikon D80 Digital Camera with 18-135mm...
Menu Problem
Did you try calling Canon tech support or returning to retailer if the camera is really not functioning properly this soon after purchase, I'd try returning it once all troubleshooting issues have not resolved the issue.
Hope this helps!
Feb 16, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Convergence Problems
If you did not use heat sink compound then you probably have not hurt the new IC's yet but you should remove them and add the heat sink compound NOW. If the convergence IC's are bad then you will have access to the convergence menu but the adjustments will have no effect. The fact that you switched the IC's and got the same results shows that the IC's are good. If your red convergence is still way out when the new IC's are installed then the old IC probably burned out the low value resistor associated with the Red Vertical (RV) channel.
Jul 02, 2007 | JVC AV-48WP30 48" Rear Projection...
Fuji FinePix F460 Digital Camera Logo
217 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
