Question about Zanussi 24 in. DA6153 Free-standing Dishwasher
My d-washer washes full cycle only on cold water without drying
Zanussi Progress freestanding ZFS 6150: only from time to time we get clean dishes (hot water, rinse, dry) but mostly any programme does only cold washing full cycle and no drying. Repair man refused to come as full cycle is finished so he fears it might be in eletronic board. Machine is only 25mth old, therefore no guarantee. Please, please come with an advice. Many thanks Irik
5 Suggested Answers
SOURCE: zanussi zdt6252 stops on 'Rinse & Hold' midway thru Wash Cycle consistently...
The problem here is being caused by Blocked Filters in the Water suppoly In line/pipe. There are two(2) filters in this line, at the water connection point and at the Washer connect point(one at each end). If these filters become blocked, then the result will be a restricted water In-Flow and hence the Rinse & Hold Status. Disconnect the Water-Supply pipe and remove the plastic filters giving them a thorough cleaning before replacing them. All will be rectified by this action. Peter...
Posted on Mar 18, 2007
murdozzz2
  • 75 Answers
SOURCE: zanussi dishwasher
hi there sounds like a possible dry joint on the pcb repair and try first
Posted on Jan 11, 2008
SOURCE: Zanussi DCE 5655 dish washer
There's a water leak inside, causing the anti[ flood micro switch to activate. Even a couple of tea spoonfuls of water will cause this. Remove the cover and check the polystyrene float at the bottom. A very small amount of water there will cause the problem. Check for any water leaks or even a slight water surge when the machine starts.
Posted on Aug 02, 2009
Daniel S
  • 4323 Answers
SOURCE: I have a built in
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it.Hope this helps...please post back for further assistance.
Daniel
Posted on Jun 06, 2011
The dishwasher runs through it's cycle but does not clean the dishes properly and leaves a cloudy film and smears on the inside of the machine and the dishes
    Common Problem
  1. Confirm the wash water is hot
    1. Try heated wash(sani wash) if available
    2. Run hot water in sink to warm up before starting
    3. At least 120 degree Fahrenheit water temperature
  2. Open door check wash arm position start washer for a minute
    1. Confirm wash arm has rotated
    2. Check for plugged spray tips at either end of wash arm.
    3. Use small tweezers to remove
    4. Check for rack and dishes interfering with arm rotation
  3. Place cup in upper rack with opening up cycle washer.
    1. Confirm that cup quickly fills with water
    2. Not washing check water level in tub mim 1 1/2 inch
  4. Discontinue use of rinse/dry liquid additive.
    1. Confirm rinse/dry additive not leaking from dispenser into tub
    2. Washer detergent contains sparkle additive and too much sparkle/rinses/dry additive will coat dishes
    3. Try alternative wash detergent that contains minimal rinse/dry additive and use without liquid rinse/dry additive.
  5. It will take several wash cycles after the elimination of rinse/dry to purge the oily film from dishes and machine..
  6. If success "joy" is achieved with no additives then cautiously add back wash detergent with additives. Additives are important to facilitate drying and protecting the glassware china from leaching. The leaching process permanently etches the surface of glassware leaving a cloudy appearance.
Jan 03, 2016 | Dishwashers
Dishwasher not cleaning very well.
Hello do it heat up ok is the water Hot please
Nov 13, 2015 | Siemens Dishwashers
Dishes not cleaning after full cycle running
Your screens are plugged with food residue in the bottom of the unit. clean it out. You can use 1 gallon of white vinegar for your wash after you clean the screens. Start your washer to fill with water but after the water starts, open your door and pore all of the gallon in the unit. Let it now run for 4 minutes and stop it by opening the door. Leave the door slightly open for 1 hour. close the door and let the cycle continue for 4 more minutes. open the door and repeat it a couple of more times. Let it sit all night with the vinegar in it and in the morning - close the door and let the cycle continue to the end. This should help soften and clean out the food particles in the unit. You can repeat the process and get a better cleaning then too. All the scale should be off your dishes now.
Jan 08, 2014 | Frigidaire Professional Series 24 in....
The dish washer washes ok, but often does not dry the dishes. I have descaled and cleaned it but still hit and miss. can i fix it my self. thank you Chris
You didn't state the precise model, but if it's a cold-fill only machine (most Zanussi models are) and if it uses condensation drying like most, then a cold water supply is essential for the latter to work.
Many owners connect such machines to the hot supply in the mistaken belief that it will make the machine cheaper to run, but unless they have free hot water (solar heating?) then it's usually a falsehood and the trade-off is incomplete or non-existent drying.
Jul 16, 2011 | Zanussi Dishwashers
My Bosch Dishwasher is not drying my dishes now. The model number is SHE44C05UC.
Unfortunately, it seems that the heating element has failed. The dishwasher uses steam to heat the tub to dry the dishes. I suspect your dishes are also being washed in cold water.
To check this, please run a regular full wash cycle. Allow the washer to fill with water and run for about 10 minutes, then open the door and feel the water temperature in the bottom of the washer. If the water is cold, it's more than likely the heating element has failed.
There are other possible faults which would cause the element not to heat, but these often prevent the dishwasher from completing the cycle. If the water is cold but the dishwasher still drains the water at the end - and completes the cycle - the heating element has probably failed.
Please try this simple test for water temperature and let me know if you need further assistance.
Regards,
BElectric
Feb 18, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
Can I take the bottom part of the dishwaher apart
Mkae sure you are running kitchen hot water faucet before starting dish washer. If not you are getting mostly a cold water wash thru out the cycle. Also make sure the jet dry dispenser is full. Always use the liquid jet dry as the small cubes you can get do not work nearly as well.
Jan 31, 2010 | Kenmore 15762 Dishwasher
Model # dwu7702aae has heat delay light coming on during cycle. Why?
Heater is used to both heat water during clean cycle and dry dishes after wash cycle. Most washers have either a separate switch for Heat or Dry for optional use, or some have the water heat and dish dry options built into cycle set options.
You can save money by turning off the Dish Dry option since it is a very in-efficient way to dry dishes. Instead, open the wishwasher door after washing cycle completes, just enough so fresh air can get into, and humid air can escape, dishwasher.
Water Heat option is only needed for dried food on dishes, and is never needed if dishes are either rised off before putting them in the dishwasher, or rinsed off inside the dishwaser with a Rinse cycle, if they are to stand for a time waiting for a full dishwasher for wash.
Feb 22, 2009 | Maytag Dishwashers
Dishes not dry enough & leak of water at sink vent device
HEATED DRY.Turns the drying heater on for fast drying.
ENERGY SAVER (no heat boost). Turns the drying heater off to save energy. Dishes will dry naturally over a longer period such as overnight. lf you need your dishes sooner, open the dishwasher door after the cycle is complete to reduce the natural drying time. Use of this option reduces the electrical energy used by this model approximately 7%. A rinse agent makes water flow off dishes quicker than usual. This lessens water spotting and makes drying faster, too.
Make sure inlet water temperature is correct.(SeePage6.)
Unload the bottom rack first.Water from dishes in the top rack may be spilling in to the
bottom rack.
Check for improper loading.Dishes shouldn’t nest together. Avoid overloading. Check the rinse agent dispenser to see that it’s not empty.
Inlet temperature....Good Dish washing starts with hot water, To get dishes clean and dry,you will need hot water.To help you get
water of the proper temperature, your dish washer automatically heats the water in the wash cycle. For good washing and drying , the entering water must be at least 120°E To prevent dish damage,
inlet water should not exceed 150”F. How to test water temperature: Check the water temperature inside your dishwasher with a candy or meat thermometer. Let the dishwasher run through
one fill and pump out cycle, then let the dishwasher fill with water
the second time. When you hear the water stop filling, unlatch the door and slowly open it. Measure the temperature of the water in the bottom of the tub this way: Remove the silverware basket and
place a candy or meat thermometer in the water towards the middle of the tub. If the temperature is less than 120”F,you will not get good washing results. Higher water temperature is needed to dissolve grease and activate powder detergents. If the unit is a long way from the DW you may need to let the water run in the sink until hot before starting the DW....or if is a cold day and water has not been used in a while the pipes could be cold....also if you have just used the hot water ( washer, shower...etc) give it time to recover first before using DW....All of the above mentioned material is straight out of the Users guide...but you may have an element that is going out also...so check the temp of your water and open it during the drying cycle to see if it is hot or at least warm inside...if not your element may need to be replaced...
I hope this helps...have a great day & good luck...please rate my effort.... the Fang.
Jan 06, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Zanussi dishwasher
Nov 26, 2007 | Zanussi ZT485 Built-in Dishwasher
Long time to dry
Check drain filter on front of machine and check machine is doing full spin. Regards Advisor
Aug 20, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi 24 in. DA6153 Free-standing Dishwasher Logo
47 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
