Question about RCA HD52W59 HDTV Projection Television
Replaced flyback replaced the flyback just like u said, now the power button lights up green and flashes on and off twice, no picture, no nothing
  • 2 more comments
  • hammer77_03 Dec 29, 2008
    ok i looked and cp150 looks fine but cp120 looks to be domed on the top
  • hammer77_03 Jan 07, 2009
    ok i replaced cp120 and still the same result, green light flashes twice, nothing else. is this some kind of code? The new flyback i put on appears to hav three spots for the two red wires, i assumed that the smaller red wire goes into the hole (where it says focus)closest to the bigger red wire??
  • hammer77_03 Jan 08, 2009
    flyback 259296
  • hammer77_03 Jan 13, 2009
    yea cp114 is fine
  • RCA Master
  • 8,617 Answers
Often the old flyback will cause CP150 and CP120 to dome on top when the old flyback goes out. Check the tops of those two capacitors for doming. They are located on the same board as the flyback.
Posted on Dec 29, 2008
  • Sonny Berry
    Sonny Berry Jan 08, 2009
    what was the flyback part number that you installed?
  • Sonny Berry
    Have you also checked CP114 which is right next to CP120? The 259296 is the right flyback.
SOURCE:
RCA 52 INCH D52W20B WON'T COME ON
A 1995 60 inch rca good picture and sound. Then it started a cracking noise and a hissing sound, then the picture went blurry. then it was nice picture and sound, then it died. took the back off and turned out the lights. Plugged the tv in and out from the wall socket and there was a sparking noise and a small arc when i plugged it in and out a few times ,at the part that the power plug plugs into.The white part that is beside the white power plug part has thick red wire coming out of it and goes into another plug that has more red wires in it. but the big white part beside the power plug part looks burnt and has black powder on it. that part is probably the problem but maybe not, what it the name of that part and how much would it cost and is it plugged in or soldered.
Oct 18, 2008 | RCA P52937 52" Rear Projection Television
RCA d52w20 will not come on
sounds likje the flyback those sets are famous for the flybacks needing replacement.They dont always blink 3 times when the flyback fails, often they justrefuse to power up.
Sep 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RFA D52W19 need some help/advice
3 blinks is the flyback not the picture tubes. You need flyback number 259296 you can get a replacement at the following link with free installation instructions on how to replace the flyback step by step. Heres the link.
http://servicemanuals.vstore.ca/
Aug 24, 2008 | RCA D52W19 52" Rear Projection Television
Reply
sounds like the flyback is whats causing the problem, as the light flashes 3 times when you press power. You can get a replacemnet flback at the following link with free tech support to explain how to install it. You ned flyback 259296. here is the link.
Aug 12, 2008 | Televison & Video
RCA TV Will Not Power On - Powered Off Suddenly
Theses sets had 2 problems pip mod or most of the time Flyback Transfomer bad.
Jul 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Grey static then flashing button
Could be your flyback transformer or these caps 2200 mf16v 22035v 33035v. Check the caps for bulging.
Jul 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No Picture when I turn it on
changed the flyback? why ...did u check the horizontal ouput transistor. usally they go hand and hand with flyback
Nov 21, 2007 | RCA Scenium D40W20 40" Rear Projection...
TV Power on - No Picture
Bad IHVT ( aka flyback transfomer) replace with 257805 ? or
Asti 2078.....................confirm service # F36650 YX01
Please rate this solution..............................
Nov 13, 2007 | RCA F36650 36" TV
Black screen no sound
What is the model or chassel number it be a few thing H.O.T Resistor Caps etc..most likely horizontal output transistor.
Nov 12, 2007 | Televison & Video
No picture at power on
Replace IHVT aka flyback xformer #257805 or Asti #2078.
Nov 29, 2006 | RCA F32650 32" TV
RCA HD52W59 HDTV Projection Television Logo
140 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
