Question about Frigidaire Dishwashers
Dishwasher Frigidaire FDB2830CES does not start. All the leds of the pannel work fine but it does not want to start. Seems intermittent.
Check for continuity on both door latch switches (maybe only one on some models) make sure cabinets are not obstructing proper door closure which will prevent the latch switches from working.
Posted on Dec 27, 2008
How do I put the dishwasher into diagnostic mode?
Hello friend, thank you for your inquiry!
From the information you have provided you would like to place your Frigidaire dishwasher into a diagnostic mode. I have reviewed the dishwasher and do not show a diagnostic mode available. Based off the information you have provided you may be experiencing an issue with your timer or knob. I would suggest performing a factory reset on your dishwasher and you can do that by flipping the breaker off for at least ten minutes. Since it could be an issue with either electrical components you may need to seek guidance from a professional technician. I hope this information is helpful to you. -Matt
Apr 27, 2016 | Frigidaire 24 in. FDB126RB Built-in...
Door Gasket keeps coming loose on Frigidaire FGHD2433KF. How Do I keep it in? Glue?
Good Morning friend, thanks for your post!
From the information you have provided the door gasket on your Frigidaire dishwasher continues to come loose. Typically, when your gasket starts coming out you may need to have a replacement gasket installed. I would recommend operating the gasket you need from your manufacturer and replacing it. I hope this information is helpful. -Matt
Feb 28, 2015 | Frigidaire FGHD2433KF Builtin Dishwasher
Frigidaire dishwasher model # FPHD2491KF
It seems like you are experiencing a faulty door latch and control board communication. This would need to be diagnosed by a technician and the correct part(s) replaced.
Aug 29, 2012 | Frigidaire FPHD2491KF Dishwasher
Frigidaire dishwasher is not spraying water from bottom
From what you have described, sounds like the sprayer arms are possibly loose or being held into place and can't rotate, by dishware.
Aug 07, 2012 | Electrolux Frigidaire Professional Series...
My frigidaire dishwasher works intermittently. It'll completely stop mid -cycle, as if the power was shut off - then eventually indicate a power failure on the display. Then it wil work fine for a c
Hello Tom Weiss, There are a couple of things to check.
1. Check connection at the dishwasher. It is possible that the wire nuts came lose. Re-tighten and wrap with electrical tape to secure.
2. Check for a small leak from sink or faucet this has also been the culpret before.
Dec 05, 2011 | Frigidaire Dishwashers
Please help! I just moved into a new house where the Frigidaire dishwasher worked great for 2 weeks. Now, it's leaving hard salt-like granules all over my dishes and not rinsing all the food off. ...
Your dishwasher has clogged water ports.
Start the dishwasher with NO dishes in it.
Once it starts the wash cycle,open the door and pour in 1 quart of WHITE vinegar and resume the wash cycle.
That should clear out the residue.
Change your dishwasher soap to the FINISH brand name for happy clean dishes.
Apr 28, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Jan 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
KUDS24SEB3 - can't start cycle properly
I just had the same problem. I finally pressed Rinse Only and it started to fill. Without canceling, I depressed Normal, and it seems to be going through the proper cycle now.
Sep 17, 2008 | KitchenAid KUDS24SE Built-in Dishwasher
Dishwasher er error code
I have a similar problem with my Frigidaire FDB4050LHS1. My Owner's Manual says to contact the Customer Care Center if the display shows "Er", "uF", or "CE". When I called them, Maria didn't have a clue what the codes meant - all she could do was give me phone numbers to authorized service centers in my area.
I managed to get ahold of a "SERVICE DATASHEET" P/N: 154718601. The error code "ER/ER" means there is a "switch failure"; "ER/CE" denotes a "Configuration Error"; "ER/uo" means "Vent will not close"; and "ER/UF" means "Fan not running".
The schematic only labels three switches - labeled "USER INTERFACE SWITCH", "DOOR SWITCH", and "FLOAT SWITCH". There is also a switch in the pump motor assembly. If either the door or user interface switch is faulty, then you probably won't be able to do anything other than call a repair service - unless you know how to replace these switches yourself.
If the float switch is causing the error, you might be able to run the "Water/Service Test". From "PF" (denoting a Power Failure) or idle mode (with no lights on whatsoever), press and hold the "DRY/AIRDRY" and "START/CANCEL" buttons at the same time for 3 seconds. This will start an 8-stage test that runs for about 7 and 1/2 minutes. The display will show which step the test is in until it shows an error code. Step 1 tests the water valve, which is where the float switch is located. If that switch is bad, you will likely see "Uo" displayed within the first minute of the test.
Aug 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
215 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
