Question about Harman Kardon AVR 130 Receiver
My Harman Kardon receiver ( AVR 225) displays "protect" and shuts off when I try to play anything (tape, CD, FM/AM). I unplugged receiver and reset it several times. The sam "protect" comes again.
  • Superfreak08 Jan 25, 2009
    I have the Harmon kardon avr 146 receiver and it keeps shutting off saying protect. What do I do to fix this???
I used the live chat and the problem was resolved.
Usually the problem are strands of speaker wires which cause shorting and protection shuts off the receiver in order to prevent damage. There was one speaker that I repositioned recently which was causing shorting. I twisted the wires and tightened them in place and my receiver has been working w/o a glitch. I was lucky that I did not have to check all the wire strands on the receiver and all the speakers.
Problem solved and I learned valuable lesson.
Posted on Dec 28, 2008
Harmankardon avr 65 reciber ** protect** on my avr 65 reciber display
It's a DC couplage problem ... you can't do any one if you're not professional electronician ... and this is want to schemas and experience.
So you wanna take help from Harman/Kardon technic services... :S
Oct 31, 2015 | Harman Kardon AVR 65 Receiver
Hi. We have a Harman Kardon DVD and AVR and a Proline TV. When playing DVDs the sound from the AVR is not playing all tracks (usually the voice track is missing) - just background music and the odd door...
Your HK DVD probably has outputs for left and right audio and video (possibly color coded red, white, and yellow). These should connect to the corresponding DVD (or VCR) inputs on the rear of your AVR. When you play a DVD with your AVR set for DVD/VCR input, you should hear all of the stereo audio (there are no "missing tracks"). Next, review your speaker connections. They should be connected + terminal to the corresponding + terminal on the AVR, etc. One or more speakers may be connected backwards. If your AVR has speaker system A B provisions, be sure that speaker (system) A only has been selected.
Dec 23, 2013 | Harman Kardon AVR 225 Receiver
My harman kardon avr 110 will not play thru the fm. what do I need to hook up to make it work?
It's a RECEIVER, meaning the FM tuner is built-in. That's the only source you don't have to 'hook up'. But you DO have to make sure NO OTHER source is selected.
You don't say if it actually TUNES a station or not. Try an antenna.
Register and download the manual for free audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/harmonkardan/avr_110.html
Feb 27, 2011 | Harman Kardon AVR 110 Receiver
No Memory Stotred in Harman Kardon AVR 65
You have a memory cap ,usally located on the front display,that is most likely defective.measure voltage on cap with unit off should measure at least 3-5 volts
Apr 10, 2010 | Harman Kardon AVR 35 Receiver
No audio from Harman Kardon AVR 7000
Incorrect polarity between receiver and speaker will not damage receiver however unmatched impedance speakers can damage amplifier section of receiver.
Please check connection cables in receiver and if receiver does not shut off in protection mode then it could be connection cable broken or some dry / cold solder joints on circuit boards in receiver.
Re-soldering of cold solder joints is job of qualified tech.
Sep 14, 2009 | Harman Kardon AVR 7000
Harman kardon avr 140 - all displays work but no sound
I have an HK AVR140 all of the displays work, even shows when a digital connection from the Blu-Ray player is connected but no audio comes from the speakers! I found some information that HK does not have DC protection so when there is a problem muting Circuit is initiated on the main Amp. I called HK and they want me to send it in to a service dept that is not close at all. Any ideas? Or is there a way to by-pass the muting circuit somehow?
Sep 08, 2009 | Harman Kardon AVR 140 Receiver
Shuts off intermittently when only watching DVD's.
http://wzpo.ask.com/r?t=p&d=cap&s=fwpus&c=a&l=zr&o=sb&sv=0a300516&ip=29b28a2c&id=9C081BFE154A69ACB38D55982924AB2E&q=manual+of+harman+kardon+avr+120&p=1&qs=121&ac=29&g=33c8zcdlUuHiRw&en=te&io=0&ep=&eo=&b=alg&bc=&br=&tp=d&ec=10&pt=Harman%20Kardon%20AVR%20120%20Receiver%20Owner's%20Manual&ex=tsrc%3Dtxtx&url=&u=http://www.manualnguide.com/download/manual-guide/harman-kardon-avr-120-receiver-owners-manual.html. look in manual above page 42.
Sep 02, 2008 | Harman Kardon AVR 120 Receiver
Was using the harmon kardon avr 225 receiver and the front panel went out. .... screen display of the channel number, volume, or menu item does not work. ...
Try hooking up a yellow video wire from the back of the AVR 225 Monitor out. Should be at the end of the 7 or 8 yellow video ports on the back of the stereo. Next plug the other end into a yellow video in on a t.v. Get your remote, (Harmon/Kardon) and make sure the t.v. is on the correct video input and hit the OSD(on screen display) button on your harmon remote. There should be a setting in there that says VFD under ADVANCED menu option that allows for turning the front of your stereo lights on and off and dimming them half way also. OFF/HALF/FULL are the 3 options I believe.
If this doesnt solve it your display may have crapped out on you.
Jan 22, 2008 | Harman Kardon AVR 225 Receiver
HK AVR 225 front display not working
thats not good power transformers in it went bad do u have it on a nice power strip or direct to wall
Jan 19, 2008 | Harman Kardon AVR 225 Receiver
Harman Kardon AVR 130 Receiver Logo
767 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
