Question about Canon PowerShot S1 IS Digital Camera
No luck... My problem persists. I tried slapping it gently as I don't have a washing machine but that didn't help. I guess that's off to the nearest service centre then. Thank you so much for your help.
  • 944 Answers
You're welcome Good luck :)
Posted on Apr 23, 2007
Lights flashing during cycle
This should take 30 minutes: Remove the panel that is located below the front door, there are 3 small screws located at the bottom that hold this... you will see the water pump, which has a access screw plug. Unscrew this, its like a filter, you may see stuff, like coins, socks, etc, remove and clean out, then put everything back... this should fix the issue.
Before you re-fit the filter check to see that the blades of the pump further inside are turning well - no blocks. If the prob still persists you must examine pump.
http://www.youtube.com/watch?NR=1&v=4IBvHbQ_3pA&feature=endscreen
If helped click helped.
Apr 27, 2013 | Kenmore HE2t 3.7 cu. ft. Front Load Washer
Unable to perform bluetooth operation
Hi try this as your first Aid...Restore all the setting to default.Open Menu>>Setting>>Device management>>and select restore factory setting>>Restore Setting Only and enter security code 12345 or what you have made.Or type *#7780# when the phone is in standby mode.After all this your phone will automatically reboot by itself.If the problem persist,for further examination contact nearest mobile repairing shop.Good luck
Oct 18, 2012 | Nokia X6 16GB Cell Phone
NTW5400TQ
I just had that problem. The repairman pulled the front off the machine and found a small nail that had fallen through the holes in the washer tub. I didn't watch him do this, so I don't know where inside the machine it was, but he found it right away. Hope this helps.
Oct 14, 2012 | Amana NTW5400TQ Top Load Washer
What does f-05 on the screen mean
It means it's not draining correctly. You'll have to open it up to see if the drain hose is blocked, or just call a professional F05 on an Indesit washing machine means "Pressure switch jammed on trip"
As is often the case, knowing the error code is one thing, but findng the cause is another because error codes often have several possible causes. The wording of the error code explanation suggests the pressure switch clicked on to register a water level, but when the water was drained away it remained on instead of turning off. I would guess there could be a blockage in the pressure system, or the pressure switch could be faulty. Also, if the water didn't drain properly it would cause the pressure switch to stay on too. Finally, the Indesit washing machines PCB's can give erroneous errors where the fault turns out to be with the pcb itself. This makes things very difficult if you don't have access to replacement PCB's to try.
Basically, I would keep an eye on the washing machine and try it again. If it reoccurrs then clearly it needs sorting, but if it doesn't it might have just been one of those things.
Apr 30, 2011 | Washing Machines
My model is Intello washer 7 kg WD-80130F. The problem is that after putting it on, and want to start washing by pressing the button to start washing, it switches off by it's self i tkink that water do...
See if your washer is still under warranty ( perhaps an extended warranty?), if not unplug and remove hoses from faucets, remove back of machine, and carefully try to move the tub of washer back and forth a bit. BE GENTLE, you don't want to do any further damage. Sounds like something loosened up, you'll need some hand tools to tighten up a screw or bolt, and a good flashlight and an extra pair of hands to help with this.
Don't over tighten, if that is what has to happen.
If you are not able to repair it yourself, call a repair person so you don't damage it,
but get 5 estimates before choosing who to have repair it.
To often we pick the first one and it costs way to much $$.
If machine is still under warranty, don't attempt any repairs as that will negate your warranty.
Water not coming inside the washing machine
Water not coming inside solutions:
1. Make sure the inlet has water or the faucet going into the washing machine inlet has free flowing water.
2. Did you turn on the machine on?. This is required specially for heavy duty 10kg Whirlpool industrial grade washing machines..
3. If the two above didnt work. Try rotating the knob to NORMAL and pull it.
4. Contact the nearest Whirlpool service center for repair if problem persists.
Hope this helps
levibit
Dec 13, 2010 | Whirlpool Washing Machines
Samsung P1053S error code UE
The UE is an onbalanced load fault code.. Unplug the machine to clear the code.. leave it unplugged for about 10 mins and try to run it empty.  If it persists you would be advised to contact a service technician.  Bust of luck
May 26, 2008 | Samsung WF203ANW Front Load Washer
LE Code
Sorry I missed the LE code in the book.. Too much fun lastnight I guess.. AT any rate.. The Le fault code is a Motor overload warning.  Unplug it for 2 hours and try the machine again with a test wash.  if it persists you need to get a technician out for it.  Hope this helps :)
May 26, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Canon PowerShot S1 IS Digital Camera Logo
21 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
