Question about Kenmore 22422 Top Load Washer
How do I replace the water pump?
The pump froze and water leaked out of the bottom of the machine. I need to replace the pump.
  • 640 Answers
Replacing pump,,theres two screws on either side of console..phillps head remove end console caps if equipted,,with hand..if earlier mobel there right behind console..flip console back dont remove..disconnect lid switch,,the small harness that has the brown and gray ,,wires with a green groun,,always unplug unit first...remove 2 brass clips on booth ends,,now just pull the cabnit toward you and leave on side,,look straight down at your feet theres your pump,,the plastic part with the 2 hose leading out it..pry punp clips up with a smal screw driver,,twist a little and there off,,remove drain hose,,and tub to pump hose ..reverse to put together
Posted on Dec 27, 2008
2 Suggested Answers
  • 185 Answers
SOURCE: Leaky machine
check the pump and your hoses
Posted on Mar 31, 2008
Washing machine top load leaking water bottom model # LXR7244JQ1
The pump is near the front, bottom of the machine. You need to unplug and unhook it from the water supply. Then get a wet and dry vacuum and remove all the water from the machine by using the vacuum on the drain hose. Then you can lay the machine down to get to the bottom of it and you can replace the pump. http://www.partselect.com/ModelSections.aspx?ModelID=709279&ModelNum=LXR7244JQ1&mfgModelNum=&ManufactureID=3&Selected=TVCOCCCE&Position=6&mfg=Whirlpool&Type=Washer&Mark=4
Jul 10, 2014 | LG WM-2277HW Front Load Washer
Water coming out of the bottom of the machine
Sometimes, what may seem like a washing machine leaking from bottom locations is actually one that leaks slowly from other spots. Slow leaks can accumulate beneath your washing machine making it seem like you have a bottom leak. For more help identifying the exact point of the leak, see Washing machine leaking.
Bottom leaks may be better identified using a newspaper. Just dry the floor and lay the newspaper beneath the washing machine before you test for leaks. Darkened sections map out your water leak. This method is not always foolproof, however. The best diagnosis will come from a qualified service professional inspecting your machine.
If your washing machine is leaking from bottom in the rear, you may need a replacement pump and professional installation. The leak could also be caused by a faulty air dome seal or a hole in the tub. For more troubleshooting steps to tackle that leak, see Washing machine leaking from bottom. I hope that helps!
Sep 27, 2012 | KitchenAid KHWS01PMT Front Load Washer
Whirlpool duet water pump leaking froze and busted
these drain pumps are $150 with tax remove bottom access panel and drain pump has 3 screws "BEWARE IF WATER IS STILL IN DRUMP IT WILL END UP ON YOUR FLOOR" On the back of the drain pump there is a plastic cover that kindof opens like a trunk lid, unplug and remove the bolts some have rubber grommets that hold the drain screen its is very easy.
Sep 23, 2011 | Whirlpool GHW9150 Front Load Washer
Water leaks from machine during use. Have checked filter on right near base is clear.
Sounds like the water pump is going bad or a hose is leaking. Replace the water pump which in most cases are not, too costly. Most water pumps can be replaced from the bottom of the machine. If you can not find the part # on the water pump, look it up by the model # of the machine.
Aug 22, 2011 | Washing Machines
WHEN I TURN ON WASHER WATER LEAKS FROM BOTTOM OF WASHER
Hello there and thank you for choosing fixya
This can be a fairly easy repair normaly the problem is that the hoses at the bottom of the machine will wear out or loosen up over time and will need to be re tightened or replaced so what you will need to do is to pull the machine out about 4 to 5 ft from the wall and lean the machine back so you can inspect the hoses annd the drain pump you will be able to see where the water has been leaking from cause there will be residue on the parts that are leaking and on the floor where it has been leaking
Then all you have to do is to repair the leak meaning tighten up the hose clamp or remove and replace the hose if needed ok now if the pump iself is leaking then you may have to remove the pump and see if any thing on the pump is broken and replace that part as needed ok?
Hope this helps
Best regards Mike
May 16, 2011 | Washing Machines
I just moved and the washer froze while in transport. There is a small leak which means a line froze? If not a line what could it be? Thanks
If your line is not frozen and cracked then it's the water control on the back of your washer where your main water hoses screw into the washer. Check this water control because it is plastic.
Feb 11, 2011 | Whirlpool Inglis IP4400 Washer
Wahser is leaking water from the bottom.
the pump may be leaking, or a crack in the hose ,
Apr 12, 2010 | Roper RTW4300SQ Top Load Washer
Bosch washing machine leaks at right bottom
The part that you removed, was the pump filter, the pump is located behind the filter, possibly, the pump itself is leaking, or the filter cover is not fastened in tight enough, pr the filter seal is defective, if after tightening, it still leaks, suggest you replace the pump.
Please rate my solution.
Thanks.
May 26, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing machine is leaking water
hi there,
possible leaks can came from mehcanical shaft seal,of agitator shaft and pulley.if worn out
water leak on bottom of machine.
also on water pump inside machine,there is
also mechanical shaft seal within pulley and shaft of impeller blade.worn out also can cause leak at bottom.
maybe on inlet valve of hot and cold water
improper mounting or loosen lock cap on valve
leak can appear.
replacement of shaft seal are lots of work to do in pulling this out,but can be repair depend now on you.how you do it,this should be done by washing machine technician.have a nice day.don;t forget to rate me.thanks a lot
Apr 29, 2009 | Washing Machines
Washing machine leaks after pipes froze in room
The problem is most likely the water pump and supply hoses.
If your system froze up where the washer was located then it is possible that the pump or supply lines also froze because they always have water in them.
The repair price will vary with whoever you call to fix it.
Jan 29, 2009 | LG WM1814CW Front Load Washer
Kenmore 22422 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
