Question about JVC DT-V20L1U 20 in. LCD TV
E2 stays in the top corner of the tv screen
I have a slight problem with my tv , as i have just brought this tv todAY, i have connected the DVD player to the jvc tv with scart leas into the back. but my tv has E2 in the top of the scrren and i cantt seem to be able make make it disapear.
Any advise on this would be greatly appreciated .
Thanks ;0)
  • cbar300 Apr 04, 2009
    E2 also stays on screen permanently in the corner.My TV is LT-37DA8BJ
Hi
I had the same problem on mine. After ages of struggling with it I found that pressing the "i" button on the remote control made it dissapear.
Posted on May 09, 2009
Can you plug a DVD player into a Grundig P37 - 1010(B)?
Yes, connection via Scart outlet at back of TV set. Just connected mine today, works perfectly.
Feb 22, 2010 | Grundig GF70-600 TV
How do I connect a JVC DVD video player model XV-S302SL to a cable box and a TV
There are several ways in which you can do this.
The first way. If your cable box has two scarts one will be label as tv and the other vcr or something similar. connect your Dvd player via scart to the vcr scart on the back of your cable box. then connect a scart from the cable box to the back of the TV.
That would be you all sorted. when you turn your DVD player on this should override your cable and display the dvd screen.
Second way. If your cable box has not got two scart ports on the back of it. Then you would have to connect both to the back of your TV. If there are not two scart ports at the back of your TV then you can purchase a scart lead splitter. I would imagine the Cheapest you could find would be on Ebay or something similar.
Hope this Helped Clarify things for you.
If this has then please leave a thumbs up
Cheers Little Dish Fitter.
Oct 14, 2009 | Televison & Video
I cannot connect the dvd, freeview and tv wires so that they all work. I only have one scart socket at the back of the tv but have bought a scart adaptor to solve this problem. I cannot get my dvd to work...
If your freeview has two scart sockets,connect a scart from the freeview(marked tv)into the tv,then one from the dvd into the other scart socket on the freeview,the main aerial should go into the freeview and a flylead out into the tv.Hope this helps
Sep 11, 2009 | Sony DVP-NS50P DVD Player
Jvc plasma monitor gmv42e can not get a picture just sond no scart so what do i do
I have just been given one of these, it not a TV, it is a monitor, and so does not have a TV tuner or a scart (it was made for professional use).
You need to plug it in to a DVD player/Freeview/Sky box using alternative means to a scart lead. You can do this by using a scart to 3 BNC lead and plugging this in where it says 'Component/RGB B'. This carries the picture, but not the sound. To get the sound you will need to plug a twin phono lead into the red and white audio plugs.
Alternatively, you can use the 'Video in' yellow socket to connect to connect to a DVD etc. The guy did this in Maplin's and it seemed to work.
JVC professional were really helpful on the phone, ask for their technical department, they can also email you the manual.
Sep 06, 2009 | JVC GM-V42 42 in. Plasma Television
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
CANT GET ANY SOUND AFTER CONNECTING THE DVD PLAYER.
have you plugged the leads to audio in on the tv? if it as front sockets us them they are input only some on the back are output.good luck .farr64
Apr 29, 2009 | JVC TH-C3 System
Suddenly no sound from playiny tv through the dvd
check SCART lead hasn't come out....even a slight amount will disconnect the audio pins
Check the function / to others / setup / connection / AV1 & AV2 settings
Feb 15, 2009 | Panasonic DMRES20D DVD Recorder
Connect jvc combo vhs/dvd recorder to satelite and tv
If your satellite box has two sart outputs. Scart1 should go to the Tv Scart 2 to the input on the Video. Then the output scart socket on the VCr should go to Scart 2 on the TV
Sep 23, 2008 | Televison & Video
I have a weird problem with my Pionreer DVR-420HS DVD Player. Whenever I'm watching a DVD or a programme recorded on the hard disk for some reason it switches back to the tv yet the dvd is still playing. ...
If you have connected the DVD to the TV with a scart lead, the lead could be slightly loose. In this case push all the scart leads in firmly.
Pin 8 of the lead carries a switching signal. When the DVD is powered on it tells the TV to switch to that input. If the switching signal is lost the TV will switch back.
May 05, 2008 | Televison & Video
Wharfedale DVDRHD400 Set up Issue
Hi I had the same problem. The answer is to use a scart lead on the freeview box and connect it to the input/output scart on the DVD. Then connect a scart lead from the TV out on the DVD to the TV. You then press Video source on the DVD remote until 'scart' is displayed to pick the freeview channels. Hope that helps
Jun 25, 2007 | Wharfedale DVD-M3 DVD Player
JVC DT-V20L1U 20 in. LCD TV Logo
448 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
