Question about HP LaserJet 1018 Printer
Black edge Every page has a black band about 5mm wide at the left-hand edge of the paper, otherwise printing is fine. Is this a faulty cartridge, or is there another possibility?
  • John Howard Apr 23, 2007
    Thanks, Babb. This printer was given to me, and I was a little reluctant to pay out for a replacement cartridge. I should have mentioned that the black line is properly fused, so I guess that makes the fuser film less of a possibility. I will buy a new cartridge.
    Jontie.
    Novelist:
    Scholar:
  • 104 Answers
With other laser printer that problem would be attributed to the drum being faulty. Your model of printer has the toner and drum built into one unit - the "cartridge". You can try a different cartridge and see if that changes your printing results. Another reason, which is less likely, but still possible it that your fuser film sleeve need to be changed. The fuser film is located deep within your printer and requires a technician to replace it. Regards, Babb
Posted on Apr 23, 2007
Black stripe when printing from hp laserjet 2840
Cartridge faulty...
Two ways you can find out the faulty cartridge.
1. Remove each cartridge, just flip the drum shutter & chk for any toner bands appears on drum surface.. if found replace that cartridge..
2. Go to the paint. create four colored page as shown, print & verify which colored print mixed with bads.. replace that cartrdige.. ">
Mar 01, 2014 | HP LaserJet 2840 All-In-One Printer
Broad dark line on right edge of copied papers
If you have the black line on copies and scans but printing from P.C is fine, then your scanner is broken.
Contact your printer manufacturer for a replacement or repair.
May 12, 2010 | Office Equipment & Supplies
Black Ink Faded
Perhaps the print head needs cleaning.
Oct 06, 2017 | Dell 1320c Laser Printer
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Nozzle Clogging & Black Cartridge Leaking
Hi e-margaret. There's a bit of confusion here. Horizontal banding is due to LACK of ink flow to the paper. "Splodging" is due to too much. The former can be due to blocked/faulty print head nozzles or a faulty/empty-ish cartridge, or some less common problem like the waste ink pipe blocked. The latter is usually due to a leaking cartridge.
The first job is to mop up ink slopping around under the print head. Cut some strips of kitchen towel and fold them into 3 layers so you have a strip about 2 cm wide. Place them on the print head track. Turn on the printer, and as soon as the print head moves, pull out the power cord from the back of the printer. Now you should be able to move the print head carefully by hand too and fro over the towels. Repeat this with clean towel strips until most of the surplus ink is cleaned up. Remove the towel strips, replug in the power chord and switch the printer back on. Do a head clean cycle and nozzle check 3 or 4 times. If the nozzle check output looks OK, try a test print of a text document
If things are still not OK, report back on what happens in a new comment. If my instructions are not clear enough, please post a new comment asking for clarification.
Apr 22, 2009 | Epson Stylus C86 InkJet Printer
Is there any debris under the printhead nozzle plate?
Jun 22, 2008 | Epson Stylus Pro 4800 InkJet Printer
Samsung CLP-510 Toner Bleed
The following can cause bands (vertical on a normal page)
Faulty Toner cartridge
Faulty Drum Unit
Faulty Transfer Belt
Contaminated Fuser
Damaged or dirty LSU glass
Jan 09, 2008 | Samsung CLP-510 Laser Printer
Black Streaks on Edges of Paper
This can be one of two
Print cartridge (you can do it, replace toner cartridge)
or Fuser (needs to go to doctors)
stop a print half way threw to confirm that it is print cartridge, good chance it is.
Links to my previous post on this problem below
HERE and HERE
Nov 17, 2007 | HP LaserJet 4L Printer
132 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
