Question about Maytag 24 in. MDB8600AWS Jetclean II Built-in Dishwasher
Dishwasher will fill w/water but will shut off b4 cycle begins
We recently had a power outage and I am not sure if it is related but since the outage my DW is not working properly. It will fill with water just fine but as soon as it is done filling, it shuts down and will not begin the cycle. If I press the start button twice it will pump the water out just fine. Someone told me there was a sequence of buttons you can push to reset the machine and I was hoping this was the case and that this could potentially solve my problem before I have to call in a repairman. Any suggestions?
  • jecarter Dec 28, 2008
    The problem appears to be electronic. I did turn the breaker off for about a half an hour and this did not help. The water that comes in is clean not dirty it has no problem filling with water. The issue is once it fills with water at the beginning of the cycle (approx. 5 minutes in) it them immediatley shuts off completely before continuing with the rest of the cycle. If I press the start button twice it pumps out the water from the tray with no problem. Is there a way to reset the electronic panel, could this be the problem?
    Genius:
  • 1,550 Answers
To Reset dishwasher
  • Make sure dishwasher is empty of water.
  • Turn off Dishwasher
  • Turn back on and within first 3 seconds press black button 4 times
  • Push door closed and let washer go through cycle
Posted on Dec 28, 2008
    Top Expert:
  • Maytag Master
  • 82,285 Answers
A power outage could indeed be the cause of your problem, there may have been a power surge when the power came back on, this can damage the electronic circuits that control the functions of the dishwasher, all public utility companies have claim forms for damages to appliances, TV and what ever else may be hooked up that is sensitive to surges, they are pretty easy to file and in most cases they will repair or replace the appliance with little or no fuss, try it.
  • 837 Answers
Have you unplugged it yet for about 20minutes and tried again?
  • Jay Glendenning
    Jay Glendenning Dec 28, 2008
    All points to the control board in the console .. I do not have the part number for it but it is about $80
  • Jay Glendenning
    I stand corrected but you can find the board here .. its a little more than $80
    President:
  • 2,110 Answers
First try cutting power to the machine for about an hour, and see if it resets.
  • Sibananda Jena
    Sibananda Jena Dec 28, 2008
    first try cutting power to the machine for about an hour, and see if it resets.
  • 100 Answers
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
This is often the fill valve.  You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer.  Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned.
 Most common d/w power is 120 volts, check for 120 volts with a volt meter at the main power harness where it enters into the dishwasher, you will have to remove the lower access panels to get to the power box. Dishwashers also have at least one and most newer dishwashers have two door switches that must be checked. You will find then behind the console at the door latch area. Each manufacture has different designs but this is a picture of what some of the newer dishwasher switches look like.
click the link for more help
http://www.applianceaid.com/dish.html
  • 837 Answers
Have you unplugged it for about 20 minutes yet and tried again?
Won't Fill and will attempt to run wash cycle when turned off and door is closed
Hello ddux97 - I understand your dishwasher has power but will not fill with water. Here are a few simple troubleshooting tips that may help you resolve this issue:
• Make sure water supply is turned on. (First check for shut off valve under the kitchen sink).
• Check the house circuit breaker or fuse box, reset circuit breaker or replace fuse.
• Check inlet hose and make sure it's not twisted.
• Does float overfill protector (mushroom shaped object in tub) move freely? This is located in the bottom left front corner of the dishwasher.
• If this is a new install, then make sure the unit is not pressed up against the cabinet and the fill tube is not squeezed closed.
• Make sure the electrical wires going to the water inlet valve have not come off. It is best to turn off power to the dishwasher before reconnect wires, it doesn't matter which terminal is off both need to be connected.
• Make sure the drain hose is installed correctly. If the drain hose is routed under the floor as the dishwasher fills water can be drawn from the tub and appear to have never filled.
• Some models of Frigidaire dishwashers use a water pressure switch that will shut off the water valve if the tub over fills. These models do not have floats.
I hope these troubleshooting tips help you in some small way.
Jun 20, 2013 | Frigidaire 24 in. PLD2850 Built-in...
Item: Whirlpool Ultra Dishwasher Age: 3 yrs Problem: Not enough water to effectively wash the dishes. State: When the dishwasher is started, the fill valve opens as normal. Only about 1/2 the amount of...
Larry,
The float is generally for overflow conditions and will interrupt power to the fill valve solenoid.
If you are not filling completely in the time allowed by the timer, it is most likely a flow restriction in the water supply. Barring other obvious restrictions, the fill valve has filter screens on the inlet side of the fill valve, which is generally the cause of your symptoms. Be careful if you attempt to clean the screens, as the fill valves are very sensitive to debris, and can become stuck open if sediment gets past the screen. I usually replace the fill valve to avoid future problems.
Hope this helps.
Oct 30, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
GE model GSD600003 repair manual: Before you answer this, please tell me if I will be charged for the answer, in case I'm not interested at this time. Do you have a diagram of the drain area and water...
I'm not sure how mildew can grow in a dishwasher that is working well, but after cleaning it and putting things back together, it does now seem to be working. I thought that the water wasn't filling but I guess the heating element heats up before the water fills the dishwasher. So when I tried again and started the dishwasher from the beginning and waited, it did progress to filling water and going through the whole cycle.
Oct 18, 2009 | GE Dishwashers
Cycle going all the way but very small amount of water
Most likely, the problem is your water inlet valve. Before you go get a new one, check to make sure that the cutoff valve (probably under the sink- it is at the beginning of the water line that goes to the dishwasher) is all the way open. Sometimes it gets bumped by trashcans, or boxes of detergent, or whatever, and can inadvertently be partially closed.
The inlet valve is usually located at the front of the dishwasher, behind the plate at the bottom. Make sure you turn off the power at the breaker, and cut off the water (under the sink). The water lines (in and out) need to be disconnected, and the wires carefully unplugged (its best to use pliers to keep from yanking the cords out of the plugs).
You might just have calcium deposits all over the screen inside the valve. You can clean it with a mix of limescale remover and water. Or it may just be "broke", in which case you need to order a new one. If you have an appliance parts store in town, they will probably have it in stock.
Sep 01, 2009 | Maytag MDB9600A Jetclean II Built-in...
Whirlpool Gold dishwasher water overflowing and will not shut off
There should be a dome shaped float switch on the inside bottom of the washer. Make sure it is free to move up and down, or is able to float (possibly cracked or broken).
Jun 28, 2009 | Whirlpool GU2400XTPS Built-in Dishwasher
I have a GE GSD2230Z00WW dishwasher water will not fill on start no power on the fill valve either. Water will come on quick wash cycle and rinse.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
***If everything checks out ok with the water inlet valve, replace the timer or control board.
Jun 18, 2009 | GE 24 in. GSD2220Z Built-in Dishwasher
Power point dishwasher - not washing dishes
Jun 18, 2009 | Dishwashers
Dishwasher won't fill on start
Check the following to address this issue.
LG LDF6810 Dishwasher Starts filling with water then pumps water
Because you are not getting an error message, I agree that the controller card is malfunctioning. Almost everthing else would triger an error.
Recommend replacing the controller card.
Feb 19, 2009 | LG LDF6810 Built-in Dishwasher
GE Nautilus Dishwasher - NO water coming in at beginning
Normally,if water doesn't come in, cycle should not go on ! Add water by hand to tub and operate the dishwasher. Let us know with your results and we will see how could we assist you.
Aug 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Maytag 24 in. MDB8600AWS Jetclean II Built-in Dishwasher Logo
369 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
