The player can read the card, but it is not going to add more memory space to the player. The function of the card reader is to enable your player to play songs that you otherwise couldn't play because the hard drive is full.
Hi,when you purchase a new micro SD card before use, youwill need to format the memory card so that you will be able to know the actual size of the Micro SD card by checking the details after formatting it.
After formatting the micro SD card and checking the details, if you still do not see the accurate size which is about 1.88mb or the about, that means the micro SD card you bought needs to be replaced. Not a good one.
Inserting a microSD card into the Sansa does nto magically expand its internal memory. The card is a separate chunk of memory. You can move some songs from the internal memory to the card to free up some internal memory. Or you can add the new song to the card.
No, the Sansa m250 is one of the few Sansa lines that does NOT have a microSD card slot. If it did, you would have been able to use a microSD card to expand the memory by an additional 2GB. (The later Sansa models can support microSDHC, or "high capacity" cards up to 16GB or 32GB.)
You have a v1 unit and the maximum is 2GB MicroSD unless you install a different firmware called Rockbox. Then you can load the MicroSDHC cards in your computer and play them in the Sansa.
The e260 works with microSD cards. Your 4GB card is actually a microSDHC card and won't work in the Sansa. With a microSD card, simply put music tracks into a folder called "MUSIC". When the card is installed, the Sansa will see the additional tracks.
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
You have the newest version, indicated by a V2 on the back of the unit. You do not have the MODE option on your device.
The memory card shows up as part of the total memory, you cannot access it separately.
If you mean on the PC, it does not show up in Windows Media Player 10, but it does in WMP 11. If you are using Rhapsody, it does not show. It also shows up in My Computer as a Sansa e250R, right next to the device.
With most MP3 players, some of the memory is used for system files and software. Just delete all the things you done use (i.e. pictures, playlists, Rhapsody Channels) and whatever space you have free is what you have to work with.
If you want more memory, I highly suggest a microSD card
