Question about Microwave Ovens
Short in start button
At about 12 months after install it started making a loud electrical popping or shoring sound when you push the start button. It does it about once every 15 days. after the first time we had a tech come out and look at it but of course it would not do anything for him and preformed flawlessly.
It pops and then works fine Im sure this is not safe and I need to remove the oven unless a start switch can be replaced. should i be worried about the unit actually exploding or catching fire?
    President:
  • 2,692 Answers
NO . What will happen is that the contacts on the momentary start switch will wear to the point of no longer making contact at which time the button will no longer work.
Posted on Dec 28, 2008
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Keurig makes loud noise and sounds as it refills
hIi would return this should be under warranty
Jan 22, 2010 | Microwave Ovens
My goldstar above the stove microwave popped and now won't heat. Everything else on the unit still works. Is this a problem that can be repaired? Thanks.
Did it make a loud pop like a firecracker?
Sounds like the High Voltage Diode shorted out and it probably is making a low or loud growling noise now..... ???
Sep 11, 2009 | Microwave Ovens
Not working plmv169dc
HI, the sound you herd was the noise filter and running diode. these important components have failed at this point. you will need to replace these components asap, if possible. this will fix your issue.
The Magnetron Cut-off fuse will need to be replace as well. this will blow if there is a malfunction within the unit.
Jul 22, 2009 | Frigidaire PLMV169DC Microwave Oven
Kenmore microwave loud popping noise when start
That sounds like maybe a high voltage wire or component is running too close to the chassis or one of the components connected to it.
Gruesome as it sounds, sometimes a pest can get inside the works and can move wires around or be killed, then its carcass can conduct electricity and cause arcing.
It may instead be a failing high voltage diode.
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number (66562619200) at the Sears parts site.
Here are some links you or someone you know can use (in order given) for test help, but
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
http://www.gallawa.com/microtech/xformer.html
Jun 14, 2009 | Whirlpool MH7130XE Microwave Oven
Dacor DMT2420s when started makes a loud buzzing sound
The fan could have an obstuction. I have heard of tech sheets getting into the fan and causing a vibration and vibrating sound.
May 12, 2009 | Dacor DMT2420SS Microwave Oven
Intermittant loud "pop" when starting my microwave
Clean well the inside of the oven, if you keep having the problem and the inside is clean, then the magnetron is starting to go.
Jan 28, 2009 | GE Microwave Ovens
Microwave made loud popping noise
The magnetron is bad. Probably cost about $50 or $60 for the part. Not too easy to replace, but it can be done.
Dec 13, 2007 | Whirlpool MH7130XE Microwave Oven
Microwave Ovens Logo
51 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
