Question about Sony Cameras
Sony cybershot S600 sticking lens cover mechanism
Sony cyber-Shot S600 has a sticking lens cover mechanism. It will not open when the camera is switched on. The lens tries to extend out of the camera but the lens cover stops it from completing the operation. If the lens cover is carefully manually opened then the lens and camera are able to function correctly
SOURCE: Sony Cybershot DSC S650 Memory stick not formatting
Well I have the same camera.
And mine won't turn on.
Suggestion dont trust this camera.
Or maybe it just can't hold that much memory.
Posted on Mar 21, 2008
SOURCE: lens cover wont close
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Posted on May 22, 2008
  • 40 Answers
SOURCE: The opening for the batteries is broken.
The 4 latches that the battery door locks onto is broke, you will need a different back cover and front cover.
Posted on Apr 04, 2009
  • 11967 Answers
SOURCE: Got a cyber Shot H-10 says lens cap is on but it isn't?
Go into the setup menu and try to find an entry for "reset". If you find it, reset your camera.
Posted on Aug 14, 2009
  • 9 Answers
SOURCE: lens will not retract completly on sony cyber shot
I have experience this unfortunately the drive mechanics
motor and more so the gears are plastic when mine dropped it broke a tooth on the gear off the drive motor that drives the worm gear that extends and retracts the lens assembly. this sad to say but the units are not repairable and the assembly has to be replaced owen to the fact that it really is cheaper to replace the assembly than try and repair it.
Posted on Nov 28, 2009
Testimonial: "thank you. i had heard this before. after wiggling the lens it will go in and out now."
Power button stuck down on my sony cyber shot dsc s600
Possible that this is a mechanical failure and the switch is broken or out of place. Remove the battery and check the charge, if this seems fine then replace and tap the camera upside to see if the buttons resets.
If not the camera must be taken out, try to open ONLY if you have the correct tools and do not try to open otherwise to damage the unit.
Best option is to take an opinion from Sony for estimation.
Jun 25, 2011 | Sony Cyber-shot DSC-S600 Digital Camera
HOW CAN I REMOVE MEMORY CARD?
Hi There and Welcome to Fixya.
To remove/insert the memory stick pro duo from your Cybershot DSCW55, follow these steps :
  • Open the battery/memory stick duo cover
  • Remove the battery pack
  • Remove/insert the memory stick duo (insert with the terminal facing the camera lens)
  • Insert the battery pack and close the battery/memory stick duo cover
For more helpful information and details regarding usage and maintenance of this camera, please follow the below link :
Sony CyberShot
Pull up the website and simply click the "Instruction Manual".
Enjoy, and Thanks for using Fixya.
Apr 12, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
Lense cover sticking on my sony cybershot w170
Most likely what is wrong is that the lens cover has become sticky, or clogged. Have you spilled a soda, etc. on it recently?
The best thing to fix this would be to aim a canister of compressed air directly in-between the lens fover and the lens, blowing anything out. If this doesnt work, then manually push the cover back with your fingernail and try again with the compressed air.
Mar 01, 2011 | Sony Cyber-shot DSC-W170 Digital Camera
Problem for Sony Cyber-shot DSC-S600 Digital Camera Error code E:61:20 on Sony DSC-S600
Its Lens Block Assy is faulty. Below is part no of Lens
yey4u7iqvnoaaaaasuvork5cyii=
Problem will solved after replacing Lens assy
Kind regards.
Nov 02, 2009 | Sony Cyber-shot DSC-S600 Digital Camera
Stuck power button on my Sony cybershot dsc-s600
Hi!
Yes, power buttons do break on these cameras. Contact your local Sony service center and see how much will it cost to replace the top panel. If they ask too much, feel free to contact me at toms.safranovs@gmail.com
I work in a Sony service center.
Tom
Jul 19, 2009 | Sony Cyber-shot DSC-S600 Digital Camera
Feb 26, 2009 | Sony Cyber-shot DSC-S600 Digital Camera
Lens wont open
Lens mechanism isn't good to work properly so camera shut down the power. Try to tap the lens/ camera while power up.
If you have a memory card in the camera, take it out before turning the camera on
Aug 28, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Lens cover wont close
Oct 17, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Cameras Logo
107 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
