Laptop will notpower on.
Laptop dose not power up,power on button dose not light up when pushed.
    Champion:
  • 254 Answers
Remoe the battery for a half hour then try it again
hope this helps
Posted on Jan 03, 2009
No power button light loops blinking light on caps lock and chrg light
Here is a link to a other forum that has a view links for Toshiba laptop error codes if your laptop is not under these just tel me what your laptop model number is.
http://www.hardwareanalysis.com/content/topic/51345/
Dec 30, 2013 | Toshiba Satellite Computers & Internet
No vga no hard disk light only power on light of samsung mini laptop
hi please try this solution, if it doesnt work could you please just clarify if the power light is coming on when you push the power button or is it just the charge light that is on when connected to a/c adaptor?
1 Removed the battery and power cord from the laptop
2 Press and hold the power button on the laptop for 30-60 seconds ( the longer the better)
3 Connect the powercord to the laptop but leave the battery out
4 Try and power on your laptop - if it turns on you are good to go just reinsert you battery and repeat if it happens again
Jul 25, 2013 | Computers & Internet
I just cleaned the keyboard of my IBM T30 after that it did notpower on anymore ;-(
Try removing the battery and plug in the power adapter and switch on the power. Now try switching on the Laptop and see whether its powering on. if it is , then clean the battery contacts and put it back again.
Apr 18, 2011 | IBM ThinkPad T30 2366 Notebook
Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
Jul 06, 2010 | Motion Computing C5 Tablet PC
Compaq nx5000 PC Notebook: my compaq nx5000 is notpowering up when i power it...
First check to ensure the battery is properly seated. If it's in good, then this is probably a power supply issue or a problem with the motherboard.
May 06, 2010 | HP Compaq nx5000 Notebook
After extended power outage my laptop will not
Try holding down on the power button until the leds stay on ... then release it. Don't just tap or push the power button once.
Feb 06, 2010 | Microsoft Windows XP Professional With...
Nothing happens when you push the power button
i could be static build up . this is common. Try taking the battery out and unplug the power adapter. now with both removed press the power button on the laptop for approx 20 secs. then plug it in and see if it boots up.
Dec 02, 2009 | Compaq Presario 700 470024-192 Notebook
C500 Laptop won't come on power button just flashes
Have you tried attaching an external monitor when the LCD screen is disconnected from the motherboard? this connector is located under the keyboard strip – a piece of plastic just above the keyboard.
If it works, this way, then the video cable isn’t seated properly in the connector on the back of the screen. Plugging the video cable back in should fix the problem.
I don’t know how comfortable you are with taking apart laptops but I think that this information could be useful for you.
Source: http://www.asklaptopfreak.com/laptop-notebook-help/2006/08/08/laptop-powers-on-and-shuts-off-immediately/
Sep 28, 2009 | Compaq Computers & Internet
Laptop has shut down with no power lights
laptop dose not turn on but lights are on
Feb 23, 2009 | Dell Inspiron B130 Notebook
Laptop wont tart
I would like you do reseat (take out and reinstall) the following:
Memory Battery
Next I would like you to verify that the powercord is still working, when you plug the cord into the laptop it should light up on your laptop, and there may also be a power indicator on the powerpack itself.
After you have done the following please post back here and let me know your findings
P.s. Note any beeps and sequence when/if they do.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/thomas_b78b4251cd160cd2
Jan 19, 2009 | Toshiba Satellite M60 Notebook
Computers & Internet Logo
37 people viewed this question
Alun Cox
David Payne
David Payne
