Question about Maytag 24 in. MDB8600AWS Jetclean II Built-in Dishwasher
Dishwasher will fill with water but will turn off b4 cycle starts
We recently had a power surge and I don't know if it's related but ever since our DW is not working properly. I was told there is a series of buttons to push that will reset the machine but am not sure if that is true or will ultimately solve the problem. Anyway the machine will fill up with hot water just fine and then it just shuts down before the washing cycle begins. If I press the start button twice it will pump the water out just fine. Any suggestions?
3 Suggested Answers
crayzeetrayn
  • 837 Answers
SOURCE: Dishwasher will fill w/water but will shut off b4 cycle begins
Have you unplugged it for about 20 minutes yet and tried again?
Posted on Dec 28, 2008
  • 100 Answers
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
This is often the fill valve.  You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer.  Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned.
 Most common d/w power is 120 volts, check for 120 volts with a volt meter at the main power harness where it enters into the dishwasher, you will have to remove the lower access panels to get to the power box. Dishwashers also have at least one and most newer dishwashers have two door switches that must be checked. You will find then behind the console at the door latch area. Each manufacture has different designs but this is a picture of what some of the newer dishwasher switches look like.
click the link for more help
http://www.applianceaid.com/dish.html
My dishwasher is not enough with water at the start of the cleaning cycle
My new DW had the same problem but when I had a tech come to the house he explained that the DW only uses .8 gallons of water and that what I am seeing is normal. Do your dishes come out clean? My did, so I guess he was right. Good Luck...xo
Sep 20, 2014 | Kenwood KDW243A Builtin Dishwasher
Dec 28, 2008 | Maytag 24 in. MDB8600AWS Jetclean II...
Kenmore dishwasher will not fill with water model no 630.1609406. It will run a full cycle but not fill. Water was temp shut off to replace kitchen sink and now dishwasher won't fill with water. No fill...
First, are you sure that the machine is not filling?
I go on calls all the time for this problem and it turns out than the machine fills but the wash motor does not run.This leaves soap in the bottom of the DW so it looks like it did not fill with water. This is a common problem in dishwashers that have not been run for a few months, and is quite common after a remodel. If it IS getting water, the motor is probably stuck. If it is Not getting water the first step is to locate the "over fill" float inside the dishwasher. This will be a round sort of mushroom looking thing on the floor of the machine near the door on the right or left. Make sure it moves freely up and down. It will only move about 1/4 inch but If it is stuck up, the machine will not fill. If float is O.K. then check the water source. Turn of water to DW. Remove the kickplate under DW door and disconnect the waterline from fill valve (should be on front left side of unit). Run waterline into bucket then turn on the water. If you don't get water call your plumber. If you get water then you need to check the fill valve. Connect a volt meter to the 2 wires on the fill valve. Start DW. First the diswasher should start draining, then it will start filling. At this point (a few minutes into the cycle) you should see 120v AC at the fill valve. If you do see 120v Ac, replace the valve. If you don't , then turn off the machine and check the float switch. This is located under the DW right under the mushroom thingy. The switch should have continuity when the DW is empty. If there is no continuity then replace the switch.
Mar 29, 2010 | Dishwashers
The first cycle water is not hot - all other cycles are hot - the water in the sink next to the dishwasher is not???
Where does the dishwasher connect to hot water? If it is connected to cold it must be changed. From your description, the water is coming from a long way off and has to warm the pipes as it travels to the dw. The dw should have a heater to bring the water up to temp after filling before it runs, if this heater is not working, the first run will be cold and the next hot because you have drawn enough water through the pipes to bring hot water to the dw.
1. Change where the dw gets hw.
2. Run hw in the sink before allowing the dw to start (if connected to same line).
3. Fix the dw's water heater.
Three possible fixes. Good luck.
Aug 27, 2009 | Maytag 24 in. DWU7402 Built-in Dishwasher
Bosch SHX46A (6 years old) Selected regular cycle, pressed On and closed door. Cycle did not start normally. Pump runs, but no water is coming into the DW. I confirmed the water supply line is turned on....
From your description, I doubt that the problem is door latch is the cause.
The first thing that a modern dishwasher does before it begins to fill with water is run the drain pump.  It appears that this DW is not progressing to the next cycle (inlet water) and because the pump runs even when the door is open, I agree that the controller card may have failed.
If possible, inspect all the wire connections (remove main power before you do this) ... if there is a loose connection, the controller could do odd things.
Good Luck!  Please report back what you find, OK?
Apr 14, 2009 | Bosch Integra® 500 SHX46A0 Dishwasher
Dirty racks
What is the manufacturer and model number of the dishwasher?
Here is the process I would follow to remove the gunk.
Start a short cycle in the dishwasher, without adding detergent powder and after the (hot) water has filled the DW and the wash cycle has begun, open the DW door and add 1/4 cup of household bleach. When the water drains and begins to refill for the 2nd wash cycle, check the dishwasher to see if anything has gotten better and if not, add another 1/4 cup of bleach as soon as the hot water has refilled. Allow the DW to finish the full cycle.
Begin another short wash and as soon as the initial hot water fills and the wash cycle begins, open and add 2 cups (approximatly) of white vinegar. Allow the whole set of cycles to finish and check the insides.
If grease remains, I would use a de-greasing spray (avilable at all hardware stores and most food stores.) Spray on and use paper towels on all surfaces.
Because I do not know the make and model # for your dishwasher, I can not give you a part number for replacement racks.
Good Luck!
Apr 05, 2009 | Dishwashers
Very long cycle time for Bosch DW
There is a recall on the control board of many of these models, butyour problem is likely not related. I have written a guide to help. It is here. Thanks!
Jan 05, 2009 | Bosch SHU3036UC Dishwasher
I have a GE roll around dishwasher, Model GSC3200Z03BL. It worked one night, did not work the next. After hooking intake/discharge hose to faucet and turning to start, no water is pumped in. Only a...
First off.. the pump does not let water in.. it takes water from your sink faucette via the hose and allows it to enter the DW via an inlet electrically operated valve. If that valve is not commanded by the control system to open, then no water will enter the DW and a wash cycle will not start. Please find the informaton shown below that decribes some reasons why your DW may not be filling with water. You should go thru this series of checks to make sure you've set up the DW correctly aqnd it is not in mid cycle.If by chance you are setting it up correctly and are not in mid cycle then you may have a hardware problem with the system. I would be happy to assist you if it comes to that but I am hoping that the information below will get you started,...
Copied directly from the GE website for your refererence..
Dishwasher - No Water Fill
Often the cause of a dishwasher not filling at the start of its cycle is not electrical or mechanical. Often times you may be starting your dishwasher model incorrectly which results in the machine skipping its first water fill period.
There are presently three different types of starting procedures being used:
  1. Pushbutton type. This system is found on all POTSCRUBBER models.
  2. "Turn-to-start" timer type. After latching the dishwasher door, you turn the timer dial until you hear a click. By advancing the timer dial beyond that point, its possible that the first water fill would be skipped. The first fill is necessary for automatic pre-rinsing of the dishes.
    View a short video about turn-to-start timers:
    Play Video
  3. The most common type is a "push-to-start" timer dial. All that is required to initiate the cycle is to push in on the timer dial. It is NOT necessary to turn the dial.
If you are unsure as to the starting procedure used by your model please consult the Owner's Manual. Download a free copy of the Owner's Manual and/or Installation Instructions.
Here is a link to the website too.. http://www.geappliances.com/search/fast/infobase/10001005.htm
Hope this gets you going..
Sep 02, 2008 | GE Dishwashers
Bosch Dishwaher shy56a
Bosch dishwashers have a seperate pump for washing and another for draining. Try making it fill more than once. There is usually a timed fill and the float stops it before it overfills It also might prevent it from washing without enouth water Try defeating the door switch and play with the float during fill. There may be a sensor that won't let it go into wash. Be prepared to get a little wet if it should start up suddenly. A slightly safer way is to fill it with the sprayer from the sink. and see if it will go into wash.
May 08, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch dishwasher SHU66C02UC
You have water in the base of the machine. There is a flood float in the bottom so if any water gets into the base, it will shut off the water and run the drain pump as long as the power button is on. So shut off the breaker, remove the toe kick, and remove any water that is down there. Now start the machine and see if water is leaking into the base. If there isn't any water, an the dw is still running the drain pump, then with a wooden spoon raise the red plastice stick on the left side of the dishwasher up and down. It is possible that the overfil float is stuck. If this makes the dw start filling, then run cooking oil thru the dishwasher on the scrub cycle to remove excessive detergent. If you are in hard water, then the water deposits have caused this. Run citric acid ( Tang orange drink, Dishwasher Magic, or such) thru the dishwasher to remove this.
Jan 21, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Maytag 24 in. MDB8600AWS Jetclean II Built-in Dishwasher Logo
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
