Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
How do you get the top console of whirlpool washingmachine model # LSR8233EQ1
  • gwalker164 Feb 23, 2009
    The knob won't turn to move to next job. I can push in a turn manually, but it doesn't perform this task automatically
  • 640 Answers
Behind the console ,on the right and left ends thres a recess with 1 phillips head screw ,,losen dont take out then flip console back
Posted on Dec 27, 2008
Whirlpool LSR8233EQ1 Overflows
I would check the water height sensor. It is a tube rising from the bottom rear of the tub and has a sensor on the end. Probably full of washing powder/soap.
Nov 30, 2017 | Washing Machines
How do I change the dog agits in the ultimate care whirlpool topload washer model lsr8233eq1
Remove number one then 23 then number 2
Then remove the agitator. Set it on the floor and yank it apart. Install the new part being careful not to break the retention tabs on the base of the agitator. Here is a nice video which shows how it is done:
More videos and a service manual are HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 19, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Where do I find the model number of my Whirlpool washingmachine?
There are several places to look. One is on top of console in the back. Open the lid and look at the back lip. Down near the bottom on front panel.
Jun 17, 2010 | Whirlpool GSW9559LW Top Load Washer
Washingmachine shuts off at spin and will not drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26292690&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Jul 09, 2010 | Kenmore 24032\24036 Top Load Washer
Agitator is not rotating properly
use flat screwdriver in slot in cap to see dawgs(4)replace them
Aug 31, 2009 | Washing Machines
I hae a Whirlpool LSR8233EQ1 Top loading washer.
If you can catch it running while in the spin cycle but not spinning ( put a butter knife or screwdriver in the lid switch hole ) and wiggle the timer knob . If it starts spinning during this process , the timer needs replaced . Sometimes though , when a washer does everything BUT spin and you hear the motor running , the transmission is the problem .
Aug 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Agitator does not agitate unless I add presser downward on the to
There are 3 plastic dogs that have teeth. They become worn smooth and will not engage the agitator. Change these for about $12 and you will be back in business.
Jun 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer
hi thanks for the question. the cabinet has to come off.to do this. 2 screws 1 each corner of the console. remove. lift the console. 2 brass clips on top. remove. disconnect the wiring for lid switch. pull cabinet off. put washer on a block to raise it . its easier. . remove the clips that hold the pump on the motor. remove the motor. 2 screws 2 clips. replace coupling thanks the appliance doc
Oct 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
139 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
