Question about Whirlpool MH1150XMQ Microwave Oven
Micowave sparks a fire
The back rack supports started sparking a month ago whenever I had the metal rack in it (the one that came with it). Now this week, it sparks regardless and actually starts a fire. I have flame marks up the side of the microwave. I've tried wiping it down and washing it and nothing works. The tried taking the rack support out and couldn't do that either. Do I just need a new microwave?
  • 1 more comment
  • Persephone78 Jan 25, 2009
    Same exact issue with sparking and flames except mine is happening on the front right rack clip. The clip itself is charred from the small flame and I don't dare use my microwave for fear of my kitchen catching on fire and burning my house down. My microwave was made in April of 2004, so it's not under warranty or anything. It's funny how much we can take something for granted until we just don't have it anymore. Please help.
  • charliered23 Mar 18, 2009
    I had the SAME exact issue on my model number MH1150XMB. The plastic tab on the metal rack caught fire and burned the side panel of my microwave. After searching the web I found that several other consumers had the same issue (extremely dangerous issue might I add). However Whirlpool refused to issue a recall. I think we need to come together on a class action. The sight of the fire alone has me afraid to use my microwave.
  • Heidi Shepard
    Heidi Shepard Apr 05, 2014
    I have the same problem and mine was made in 2012. I had heard the noise for awhile and though the food was splattering until I put my self at an angle where I could see the right front corner.
I had the same exact problem. My clips arced when I ran the unit and I also observed flames which was quite unsetteling. A work around for me, since I don't use the rack was I took it out then removed the clips. All that was required to remove the clips was a pair of plyers grabing each cliip at their base. I pulled firmly and there is alittle resistance but with a firm pull straight out they'll pop out.
But I have to say if you use rack your probably looking for a new mircowave.
Posted on May 03, 2009
Model R-2120JW. Why is it sparking/fire where the rack sits in the rack hook?
Wild guess: Maybe it's making contact with some metalized paper or aluminium foil?
Jul 06, 2015 | Sanyo Microwave Ovens
I have a Sharp Carousel Microwave R-1460A. The disk on the ceiling, opposite the warming plate and about the same size, has severe burn marks (probably from food splatters). Any idea what that part is
see this indication and fix it. God bless you
  1. Waveguide coverSparking and arcing in a microwave can be caused by a damaged waveguide cover. Try removing the waveguide cover to see if the problem persists. Once removed, the waveguide cover can be inspected for burns, which will indicate if this is the issue. If the waveguide cover is burnt or will not stay in the proper spot it will need to be replaced.
  2. Cavity/Rack supportIf sparking or arcing in your microwave is near a rack support, any exposed metallic area can be covered with a microwave cavity support. It is also recommended to replace the rack supports in this situation to ensure the issue is resolved.
  3. Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity pain
Nov 08, 2013 | Sharp R-1460 Microwave Oven
Panasonic genius sensor 1250w
follow this test and fix it. God bless you
  3. Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity paint.
Oct 27, 2013 | Microwave Ovens
Lg combi multiwave
see the troubleshooting section and follow the steps and fix it.
God bless you
Waveguide Cover
If the microwave is sparking or arcing the waveguide cover might be damaged and shorting out. Try removing the waveguide cover and see if the problem goes away. If there are any damaged spots in the microwave ceiling or sidewalls, repair them and paint them with microwave oven paint. Replace the waveguide cover if it is burnt or if it will not stay in place.
Microwave Oven Paint
If the microwave is sparking or arcing on the side walls the paint might have chipped causing pitting in the metal oven wall. Use microwave safe paint to touch up any bare metal spots.
Rack Support
If the microwave is sparking or arcing near one of the rack supports, remove the support, repaint any bare metal, install a new support.
Sep 30, 2013 | Microwave Ovens
Sparking in microwave (aftron make)
test this steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#10#ixzz2aaus0Uj3
Jul 30, 2013 | Microwave Ovens
Oven aftron
follow this steps and fix it. God bless you
Microwave when turn on making a noise and sparks comin from fan area?
Waveguide Cover
Rack Support
Feb 06, 2013 | Turbo Air TMW-1100M Green World 1000 Watt...
Have microwave when i put something in and start it, have a lod popping noise why
You need to clean the heck out of it intenally then see if you can find where the popoping is occuring and come back with your report.
May 09, 2009 | Microwave Ovens
Sparks when in use
Sonja, I'm not sure what hinges you're speaking about. If you are referring to the bumpers on the ends of the wire racks that are used for convection...move the racks away from the wall. Generally, you should not have anything metal in the unit when it is just microwaving....they are for convection use. You will not start a fire but you will shorten the life of the magnetron if you continue to allow the sparking condition.
Dec 05, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool MH1150XMQ Microwave Oven Logo
687 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
