Question about Plumbing
Leaking tub spout single handle volumne/thermostat
Just started yesterday, leaking tub faucet. Shower head is Grohe> cannot get the handle off, no screws visible and no cover? not sure want to pull it off and fine out the replacement part.
  • 9 more comments
  • kenster_24 Dec 27, 2008
    trying to get pictures uploaded. The Shower head is Grohe, and not sure about the rest of the fixtures. No brand on Handle or Faucet. Main problem is leaking faucet. other problem is figuring out the brand and how to get handle off of fixture. thanks and working on pictures
    here is an overhead of the unit
  • kenster_24 Dec 28, 2008
    head on view, sorry was trying to load this, had some problems. Grohe or Kohler? either way i can't get the head off.
    Excellent Help, will give it a try, but secondary questions is what brand is this fixture, so i can get a replacement part for it? any ideas? and again, great help.
    sanray, man i must say this is my first time on this site and you are extremely insightful. anyways, i'll work on getting it off today, i have 2 kids so shutting water off needs to be timely. Also i am guessing, but the valve is about 6 yrs old. and i'll start looking for a good plumbing outlet.
    i had to reduce the photo size while saving to get it under the 150kb threshold. and it is the only handle, it controls both on off and temp control. thanks for all the help. Now i just need to know what is wrong with it and what part i need to stop the dripping as it is getting worse, i need to shut the water off and remove the pieces. i found a Grohe dealer nearby, but they are not open until tomorrow.
    so i was able to remove the chrome piece, but the handle did not back off with it?
  • kenster_24 Dec 29, 2008
    cool, thanks sanray, and i just hit save as and was able to hit a specific file size when saving.
  • kenster_24 Dec 31, 2008
    yes, i got to a grohe dealer and got a new cartridge. thanks a ton.
  • Ray Coon May 11, 2010
    Is it just the showerhead that is Grohe or is the whole valve assembly Grohe?
    Can you take a digital picture of the valve?
    sanray
  • Anonymous Mar 15, 2014
    bathroom sink faucet leaking
    Problem Solver:
  • 14 Answers
See if you can give me a head on picture.
From the top it looks like it could be a Kohler or Grohe.
Thanks,
sanray
Posted on Dec 28, 2008
  • 4 more comments
  • Ray Coon Dec 28, 2008
    Kenster,
    Be sure and turn the water off before attempting to make any repairs to the valve.
    By grasping the handle you should be able to take hold of the chrome piece between the handle and the off indicator and by turning the chrome piece counter clockwise it should unscrew and the handle should back off as you are unscrewing the chrome piece and release itself from the valve splines. Be sure when placing the assembly back together that you get all of the pieces lined up in the same order that they came apart in,
    Depending on how hard your water is, you may need to use a strap wrench and some penetrating oil before trying to disassemble.
    Hope this helps.
    sanray
    Once you have the handle off take another picture with the handle in place it is difficult to be sure what make it could be.
    If I am not able to identify it I will take the Picture to a friend of mine who may be able to identify it. If you have a good plumbing outlet such as Grovers or Standard Supply they may be able to identify the fixture.
    By the way how old is this valve?
    sanray
    In looking through my catalogs. This valve looks like the Grohe Seabury trim.
    Is this the only valve, as Grohe has different set-ups where there is a valve that controls the off and on of the water and a seperate valve that controlls the temperature.
    And this one appears fro the pictures to do the off & on plus Temperature. Turning the lever counter clockwise the Temp would get hotter.
    If that is the case one valve I would venture to say it is the Grohe "Grohsafe valve"
    I hope the picture that I tried to include goes through.
    Sorry I am not able to get the picture to post. Says I can only post 150kb and the pictures are over 400kb
    sanray
    How were you able to post your pictures?
    Here is what I would do.
    Take the pictures that you have, including one with it competely assembled.
    And one with a good shot of the valve itself and take it to the Grohe Dealer.
    You will want to ask for a complete cartridge replacement.
    I would not attempt to remove the valve cartridge until I had the replacement in hand.
    When you are ready to repair the valve, make sure that all of the pieces from the cartridge come out when removing the old cartridge and when installing the new cartridge use a little silicone grease on all of the rubber parts and inside the valve body.
    Take note on how everything comes apart and reverse the process when reassembling the valve.
    These are excellant valves and fairly easy to replace the cartridge on.
    You may want to take the Valve trim with you to make the valve easier to identify for the dealer.
    I hope this helps.
    I need to get a little more savy on how to get pictures to the size they need to be in order to accomodate the file size.
    sanray
  • Ray Coon Dec 30, 2008
    Kenster
    Where you able to get your problem solved? I hope I was able to assist.
    sanray
How do I repair a Danze single handle tub and shower faucet which leaks benind wall when water is on but does not leak when is off?
this is caused because its not in the value...its either in the shower head seal or pipe or the tub spout...you have to turn it on and some how watch and see where it is coming from....sometimes you can pull back escushion from shower arm and look with flashlight when it is running and if you see leak where arm is screwed into pipe...unscrew and reseal with teflon tape and tighten...if not you will have to cut wall behind system and watch for area of leak...good luck
May 02, 2012 | Danze & Single Handle Tub And Shower...
We have Delta brand tub/shower fixtures, the one handle kind. The problem is that water comes out of both the tub faucet and the shower head, even though the shower is not turned on. This happens every...
You need to replace the tub diverter/spout. There are two kinds, I hope you have the kind with
an allen head set screw on the bottom side of the spout near the shower wall. These are super
easy to replace ! Loosen the set screw, twist the spout a little and it should slide off. When installing
the new spout, smear some vaseline on the copper pipe sticking out, this will help seal the new O rings in the spout.
The other kind of spout has pipe threads in it. They can be a little more tricky. I got called to a
house one time. The plastic female threads on the spout cracked when the plumber installed it.
The water ran down the inside of the wall and did damage down stairs. The leak could not be seen
until the sheet rock down stairs fell down from being soaked. You need to put some pipe dope on the threads, then tighten the spout on by hand, so as not to scratch it with a pump pliers.
I hope this helps !
Nov 03, 2010 | Delta & Single Handle Shower Faucet
I have a moen fawcett. single knob, it is leaking
the spout is the end piece where the water comes out. where is it leaking ?.
when you put it back together i would suggest you use some teflon tape often called plumbers tape on all the theaded fittings as that will prevent any leaks as well.
Nov 27, 2009 | Moen & One Handle Tub & Shower Faucet
Dripping shower head
If it is dripping from the connection where it goes to the water spout you can unscrew the connection and wrap teflon tape or Pipe Joint Compound on the Threads. Now you can Thread the Shower Head Back on, with No Leak. IF..... It is leaking from the Shower Head Itself There May Be a Problem with the diverter handle/lever. If it has a Pull Type Lever, sometimes you can screw the Lever up or down for the proper water restriction to the Shower Head. However if the Hot and Cold Handle/Lever is OFF, There should not be any Water coming out from anywhere! If water is coming out off the Tub Spout, with the Shower Off, then you will have to replace some washers or Cartridges in the faucet(s) to stop the dripping. You can do this easily....Just Ask) Remember though, that some shower Heads may Drip for a Few Minutes After they are Turned off. There is still water in the Supply neck and needs to escape, either though the tub Spout or Shower Head.......Hope this Solution Helps you with your Drips.....Joe
Jan 25, 2009 | Grohe Aquatower 3000 Shower Tower...
Plumbing Logo
374 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
