Question about Xerox WorkCentre PE16 All-In-One Laser Printer
I can print, but I cannot scan using Xerox WorkCentre PE 16
I installed OmniPage SE software for PE 16 WorkCentre on my new Dell computer. Printer works fine. When trying to scan, message says "Scanner Error" with no details. I've installed all drivers, so why can't I scan? I had no problem with scanning through previous computer on PE 16.
  • 1 more comment
  • 4052 Mar 09, 2009
    Please telle me how to scan with the PE 16
  • diamantr Apr 14, 2009
    same problem for me :(
  • Anonymous Apr 20, 2009
    Same problem, f**k!
3 Suggested Answers
  • 2072 Answers
SOURCE: We have a Xerox M20
To scan a document to file (Scan to File), the WorkCentre must be directly connected to the workstation using a USB or parallel connection. Scan to File is not supported over an Ethernet connection.
Posted on Sep 22, 2008
  • 17 Answers
SOURCE: unlock scanner
under the scanner where you retrieve you printed papers on the left side twords the front there is a slide lever (which is the lock for the scanner).
Posted on Apr 30, 2010
Buna ziua, Am o mica problema. Am un echipament Xerox Workcentre 128 Pro, am instalat un sistem de operare Windows 7 pe x64. Problema este ca nu reusesc sa setez imprimanta sa imi scoata fata verso....
In Windows 7 - Duplex printing in Xerox Workcenter 128:
Go to the printer in your printer folder in control panel. Double-click on it then select menu option named "Printer" and click "Properties". Hope it helps you. It worked for me.
Sep 06, 2011 | Xerox WorkCentre Pro 123/128 Printer
I want to scan a paper and i want to save it as word so that i modify it. How can i do it?
It depends on if you have the full software installed. The MP160 documentation indicates it came wth ScanSoft OmniPage SE. Open MP Navigator and choose this program, you can output the scan as a text file. If you did a custom install, you may or may not have installed the program. If you omitted the program, do a new custom install.
OmniPage is an OCR program and will output to a number of formats (you will choose File, Save as) after scanning. Word can import RTF and most other choices as well as .doc files.
If you don't have the software disc, the software can be obtained from this URL:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=13368
Alternatively, there is a free OCR program (simpleOCR.com) that will do the same thing. However it doesn't handle text in columns (newspaper or magazines) very well.
I hope this helps.
Feb 18, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Is there a Mac workaround driver for the Xerox WorkCentre PE16
Recently I had to configure a 17" Aluminum PowerBook and a Xerox Workcentre PE 16. That multifunction laser monochrome printer is not supported by MacOS X, but I tried all the same.... and no glue for that, until I went on the Samsung webpage and noticed their SCX-4216F printer. This machine is the same as the PE 16.
So I downloaded the lastest drivers from Samsung's download centre (drivers for Tiger too), installed the drivers on the PowerBook (running 10.3.4), connected the printer and when I selected the printer ... tada! It automatically selected the Samsung driver, so I clicked on OK and started printing. Everything was OK!
But it doesn't end here: even the Lexmark X215 MPF has the same chassis as the Xerox and Samsung. Yet, on Lexmark's website there are no Mac OS X drivers, but Samsung's drivers work just the same. I hope this hint will help others...
Jan 15, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
How to scan using canon pixma mp150
Acquire Text The following instructions will give you the basic instructions to acquire text from a scanned document in Office Word 2007 using OmniPage SE.
  1. Ensure the Canon scanner driver and OmniPage SE are installed and that your scanner has been setup.
    Note: If OmniPage SE is not installed, the required Add-in for Office Word 2007 will not be installed
  2. Place the document(s) to scan on the platen or on the Automatic Document Feeder (ADF) (if applicable).
  3. Open Office Word 2007.
  4. From the ribbon menu, select the 'Add-Ins' tab.
  5. In the Add-Ins tab, click 'OmniPage' and then select 'Acquire Text Settings (OmniPage SE)'.
    The Options window will open.
  6. On the Direct OCR tab, click the 'Image Source' drop-down to select 'Scan'.
  7. Confirm 'Scan' is shown in Image Source section and then click 'OK'.
    The Options window will close and you'll return to Office Word 2007.
  8. Click 'OmniPage' and select 'Acquire Text (OmniPage SE)' to scan your document.
  9. After the document(s) is scanned, make corrections to the text items as appropriate.
I hoe it helps!!!
Dec 01, 2008 | Canon imageCLASS MF7480 Laser Printer
I can not scan in xerox pe 220
I found the solution today. First you go to Autralia Fuji Xerox website at http://www.fujixeroxprinters.com.au then select Driver - Xerox WorkCentre PE220. Download the Control Centre and Scan to PC together with WHQL_PE220_2K_Vista_SCAN (scan Driver) and WHQL_PE220_2K_Vista_GDI.zip (GDI Driver). Setup files are in Control Centre and Scan to PC folder. The rest will pop up new hardware found and browse to two other files dor perfect driver.
Hope this help because it's help me today. Thanks to Miss Chin from Pineaple Computer Store One Utama Malaysia.
Nov 01, 2008 | Office Equipment & Supplies
We have a Xerox M20 Copier/Scanner/Fax/Email which we have always used strictly as a copier. We need to use it as a scanner, to reduce paper in the office and access/share documents electronically. I...
Sep 22, 2008 | Xerox Office Equipment & Supplies
Xerox WorkCentre PE16 All-In-One Laser Printer Logo
1,422 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
quennie732
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
