Question about Samsung 710N 17 in. Flat Panel LCD Monitor
71on Monitor - Blanks out with resolution error
Screen will almost come up when loading then just blanks out with message that Resolution is wrong and offers recommended figures of 1280 x 1024. This is in a box which bounces around the screen. Option on Monitor for Menu and Reset don't work and as you can't access PC you can't check settings via Control Panel.
  • robert walton Apr 23, 2007
    Good advise but didn't appear to work - Now it'll not boot in Safe without losing the screen with message "Not Optimum mode recommend..."
Nearly there - Just need the screen to stay up long enough to accept the commands. The time period before it fails seems to shorten and will not get past the Windows startup before locking out.
Posted on May 15, 2007
    Scholar:
  • 113 Answers
This is what we can do here - 1. Restart the computer in safe mode. 2. Reinstall the drivers for the graphics card. 3. Restart the computer in normal mode good luck
Posted on Apr 23, 2007
  • Sandeep Bakshi
    Sandeep Bakshi Apr 24, 2007
    If I understand something about this error message, it comes up after a minute when the PC is completely booted up. And it is within this minute that we need to make those changes. Please try the following steps again:
    1. Start the PC in normal mode
    2. Right-click on an open space of your desktop and select properties.
    3. Select the settings tab towards the top of the screen.
    4. Click the Advanced button on the bottom right and then select the Adapter tab at the top of this new window.
    5. At the bottom of the window there will be a "List All Modes" button. Click this and select 1280 by 1024, True Color (32 bit), 60 Hertz.
    This should work.
    Good Luck!
I have a Samsung SuncMaster 940BW 19'' LCD Monitor. It's a geat Monitor in my humble opinion in everything, except that since i got it i have one problem with it, and it wasnt possible for me...
This is a common problem with monitors when changing resolution. What probably happened is you may have tried to change the resolution, or an application changed the resolution, to an incompatible resolution.
For example, if you have a tiny little screen it can't display that huge resolution that a 32 inch monitor has. So, your monitor is stuck in that wrong resolution.
To fix this problem, you need to boot into Safe Mode. Restart your computer, and as it is booting up tap F8 a bunch of times, and then select Boot into Safe Mode.
When it boots up, right click on the desktop, click Properties (Windows XP) or Screen Resolution (Windows 7). When the window pops up, click Settings (if on Windows XP, if on Windows 7 skip to next step). From this window, change the resolution back to the basic 800 x 600 screen resolution.
Now, reboot your computer normally. You should be able to see the desktop. Now, you can do the same thing that you did in safe mode and turn up your resolution. BUT, when you change it, if the screen goes BLANK again, DO NOT press anything. After 15 seconds it should go back, and you can try a lower resolution.
Hope this helps! Thanks for using FixYa.
Aug 27, 2011 | Samsung Syncmaster 940BW LCD Monitor
I TRIED TO RESET THE RESOLUTION. THE SCREEN WENT BLANK AND THE MESSAGE ON THE SCREEN SAYS IMPUT SIGNAL OUT OF RANGE
I believe the max resolution this LCD can support is 1440 x 900 / 75 Hz. If you set your display resolution higher then that, you will receive the input signal out of range error. Your LDC turns off to protect it self from the invalid settings. If you can not change it back once your PC boots to windows, you may have to do it in save mode by pressing F8 once you power on your PC and before the windows loading screen starts.
Regards, Chris
Jun 29, 2011 | Hannspree 19" Widescreen LCD Flat Panel...
Screen Resolution Error Message
go to control panel look up display adjust it ok;
Apr 30, 2010 | Envision 19" Widescreen Flat Panel LCD...
After 5 years with no problems, my Samsung SyncMaster 915N monitor is blank with the exception of an error message that says something about needing optimum resolution. At first we thought it might be the...
The optimum resolution for this monitor is 1280x1,024 @60Hz.
The resolution setting is done at the PC not at the monitor.
After 5 years, more likely components failure will be the filter caps in the power supply section, that will be the first thing to look for inside. You can see failed SAMSUNG monitors here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 27, 2010 | Samsung SyncMaster 915N 19" Flat Panel LCD...
The monitor keeps going blank with a message ''no signal'' or ''out of range''.
Probably you are out of the resolution range for this monitor. Try to boot you computer in safe mode (for low resolution) using F8 just before the windows start screen, step down the resolution, restart and try step by step to upgrade the screen resolution.
Stelios.
Feb 21, 2010 | Computers & Internet
Video problem on my Dell Dimension 4600 PC, HELP ASAP.
the resolution set by default when you load your graphics driver is outside the range of your monitors capability.
try starting in safe mode then adjust your resolution to 640 by 480 then restart.
if this works, adjust upwards to 1024 by 768
then up again till the screen blanks.
when it does, dont panic, wait 20 seconds and the settings will restore - you then have the optimum settings for your monitor.
good luck
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
Viewsonic va720 monitor
is it that whatever u try the screen does not come alive???????
was there a voltage spurge or something maybe an IC blew up..
could u tell me when did this happen
Oct 22, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
ViewSonic VG900 and Raritan Paragon KVM won't play.
hi there, yes, go to safe mode first, then adjust the resolution to the lowest and restrat the unit. then you will boot up for a lower resolution and adjust it to your desire resolution. note that don't set it to higher resolution it will go blank again. ty
Feb 18, 2008 | ViewSonic VG900 19" Flat Panel LCD Monitor
Input not supported
You may have a video resolution selected on your computer that the screen doesn't support.
The reason you see the the initial startup message is because that is loaded from the bios, prior to the settings for the graphic card output being loaded.
Try booting the computer in safe mode and adjusting the display resolution.
Dec 29, 2007 | Acer AL1916W 19" LCD Monitor
Samsung 710N 17 in. Flat Panel LCD Monitor Logo
151 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
