Question about Whirlpool LER4634J Electric Dryer
Loose dryer belt
I bought a new belt that is the same length as the one that broke. We only have one pulley that is on the dryer motor. The belt is loose and there is no where else to attach it to.
    Problem Solver:
  • 4 Answers
There should be a belt tensioning pulley or the motor should move in order to tighten the belt.
Posted on Jan 03, 2009
The interior tub is not rotating
You either have a loose or broke drum belt, idler pulley or tension spring are broke, or a loose or broke motor pulley. If you want to check yourself you need to remove screws below lint trap door, remove screws from bhind control panel on the outerback, take a flathead screwdriver or putty knife to the bottom front corners of the lid to loosen clips, and lift shell to view drum and belt.
Apr 11, 2011 | Dryers
Loud sqeeling noises when running. Sounded like a belt slipping. Dryer died all together and smells of burning rubber. Suspect a loose or broken belt. How do I change it?? --Dave
Check and see if the belt slipped off the motor pulley broke or wrapped around motor pulley. Check the idler pulley (large white wheel end of motor) Loose?
Oct 16, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Need to install drive belt- lady kenmore dryer..loop designation
The belt probably broke first, which caused the idler pulley to come loose. This is normal. With no tension on the pulley it will commonly fall over. To re-install, follow these steps:
1. Loop the new drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. If this is a Kenmore dryer, it will be manufactured by Whirlpool. Refer to diagram H. If you still have questions, please let me know. I hope this helps you.
Jun 25, 2009 | Dryers
Belt broke
Buy a new belt. Insert the idler pulley into the slots under the motor pulley. The wheel should be on the left side of the motor as you face it.
Put the belt around the drum, then through the idler roller. Then over the motor pulley.
Mar 11, 2009 | Kenmore 63942 Dryer
I have a kenmore 90 series dryer, the drum belt broke, bought a new one, but cant figure out how to get it on, too much slack in the belt, not sure where it goes on
REMEMBER BELT GOES AROUND IDLER PULLEY AND ATTACHES TO MOTOR SHAFT ,PULL BELT W/ HANDRUN BETWEEN ROLLER, AND PULL BACK AND ATTACH ON MOTOR PULLEY AND THAT ITS
Jan 02, 2009 | Kenmore 64952 Electric Dryer
Dryer belt snapped bought new one and will not reach the pulley by a 1/2 inch this is a maytag dryer thought these belts were all the same length are they not ....
make sure the belt is in the groove on back of drum for belt then run belt from left side of drum over and around pulley on motor shaft going clockwise then continue around pulley and run belt toward belt tension pulley the one with the spring on it go counterclockwise around it at this point you will have to pull up on tension pulley to get belt on then realease that should take care of it ed
Nov 01, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Good afternoon I'm a bit confused???? I'm knee deep with a dryer repair, (Sears Kenmore model # 110 97292100 gas front loading dryer) and everything is disassembled in my garage. The belt broke - that...
Its a bit frustrating to say the least just trying to explain this one,so I'll give you my best and with patience you'll get the belt on.Follow the picture below closely to get the idea of how the slack is made up. Please Rate This !!10ff711.jpg
Jun 22, 2008 | Dryers
Fitting tumble dryer drive belt
Looking from rear of dryer,one spring on motor is for tension,therefore put belt around drum(groove to the drum surface).Then rotate the motor firmly clockwise tensioning the spring,take belt from right of drum over tension wheel then put grooves of belt on shaft of motor.Release motor to tension spring,job done !!!!!
Mar 28, 2008 | Dryers
Replacing maytag dryer belt
looking at the back of the motor where the belt pulley is you would grasp belt coming down from the left side of drum then come across the top of belt pulley that is on motor shaft going clockwise around that pulley then continue back to your left and over the top of belt tension pulley going counterclockwise around that pulley this is when you will have to raise pulley against spring pressure to get belt on then release belt tension pulley make sure that belt is still in belt groove on the drum hope this helps ed
Feb 28, 2008 | Dryers
Fixing a belt to a Zanussi Condenser Dryer
when you say "only one pulley...", are you counting the motor as one? there should also be a tensioner pulley...look for it somewhere near the motor.
Oct 31, 2007 | Amana ALW480DA Top Load Washer
Whirlpool LER4634J Electric Dryer Logo
165 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
