Question about Frigidaire Dryers
Takes a long time for clothes to dry.
The heating element heats up and stays hot for @40 seconds then it cools and stays off for @ 1 min 30 seconds. this goes on over and over is this normal for the element to cycle like this?
  • jonespj151 Dec 28, 2008
    there is no thermistor switch shown in the wiring diagram. there is a control thermostat, a thermal limiter, and a high limit thermostat these switches are all in the circuit for the heat element. which of these would you describe as the thermistor?
  • 405 Answers
You have a bad element, these are fairly cheap and easy to replace.
Posted on Dec 27, 2008
  • David Johnson
    David Johnson Dec 27, 2008
    or I wasn't thinking the thermister switch that controls it, remove coil and inspect you should find a place it is burn into but touching, if there is not check wire connecters and wires for place that look burned, If all that looks good the thermister switch is going bad, and it's a cheap part also!
  • David Johnson
    David Johnson Dec 28, 2008
    I would check the high limit thermostat as the culprit. But the thermal limiter could also do it, I am assuming you have visually inspected your coil and wiring?
Gas dryer works fine for 5 min., then flame goes out, display time goes to 1 min. (cool down mode). I've tested high limit thermostat. It is OK. I put on new gas coils. Error codes 3 and 10 appear on
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
GOD IS GOOD !!!! AND THAT IS WHY MY ADVICE IS FREE
Aug 17, 2014 | Dryers
Dryer overheating on timed dry/no heat settings
Replace the thermostat. A very inexpensive thermocouple that is not sensing the heat anymore and caused the element to overheat. In the UK the part will cost less than five pounds!
If the element had touched the ground, your safety earth leakage breaker in the fuse box would have tripped.
Mar 20, 2014 | Frigidaire Electric Dryer
HOOVER AUTO DRY 5050ED KEEPS STOPPING
hi there, I have repaired many of these dryers. It will be a faulty heater element, most likely. They cost about $40. If you get a tradesman to fit it, they will prob charge you about $200 all up. Maybe its better to buy a new dryer for around $300? Good luck.
Lance in brisbane.
Jun 17, 2012 | Hoover Dryers
No heat/Only works on one setting
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 08, 2012 | Roper Dryers
Dryer is not heating up to dry clothes
The spark ignitor maybe at fault. Listen for the clicking noise upon starting it up the first 30 seconds it runs. If not heard it is in need of a replacement
May 01, 2010 | Amana NED7200TW Electric Dryer
Dryer (electric) seems to heat up initially, then cool off and not get hot enough to dry clothes. What is wrong?
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.(usually located inside the unit on the actual blower housing or inside the vent duct)
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Aug 19, 2009 | Dryers
WHIRLPOOL LER6620PTO DRYER TAKES MORE THAT 40 MIN. TO DRY A LOAD OF CLOTHES. WAY TOO LONG
Hi, you are correct. this drying time is quite long. i recommend checking the following areas on your unit to combat this issue. the most common issue here will be a clogged vent hose or blower housing obstruction.
Check the following---
1. Venting
2. Thermostat
3. Heating element
Jun 17, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore dryer 400series electric not gettin hot enough to dry
you might have a open heating element. ohm out your heating elements.
Feb 20, 2009 | Kenmore 62602 Electric Dryer
Clothes not getting dry
umplug your vent and run dryer see if that will make a different when dryer your clothe if not may be gas coils
Mar 30, 2008 | Dryers
Heating element
this could be a partial faulty heater element, a 2 heat element could only be working on 1 element, this can overload the other one causing it to keep switching on and off at the thermostat, sometimes this can be normal but saying as you think its not hot enough, check you have the settings correct on the heater options, i have seen stranger things happen test element contacts for both circuits unplug machine first
Sep 27, 2007 | Hotpoint TDL14 Electric Dryer
Dryers Logo
96 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
