Question about Kitchen Appliances - Others
Danby Wine Cooler
I have the same wine cooler and it just started to exhibit the same symptoms you desribed. I too found that the upper fan is not working and will when placing in a different slot. I acquired it form a friend so I did not have enough histiry to know if the upper fan being off, maybe off at certain times, was normal or not. Did you have any luck in fixing yours. If yes, I would love to know what was wrong.
Thanks, Paul
5 Suggested Answers
  • 6 Answers
SOURCE: danby wine cooler repair
call Danby at 800 263 2629, you can order parts from them
Posted on May 27, 2008
protek480
  • 1730 Answers
SOURCE: wine enthusiast wine cooler stopped cooling, stuck
Check thermostat, if the compressor is not on, that's where to start.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 14, 2009
SOURCE: Wine Cooler not Cooling
I think the compressor of the cooling refrigerator is not working. Otherwise the refrigerant gas has escaped from any leakage. Please check two above mentioned things. Gautam Kr. mandal, Durgapur
Posted on Jan 19, 2010
  • 55 Answers
SOURCE: Noise coming from upper back fan of my danby wine cooler
You'll need to take the defective fan out and take it to some type of hvac distributor in your area. Fan blades generally come off of the shaft of the motor by one or two allen screws.
What type of noise is it making?
You may also consider the motor. If the noise isn't caused by the fan blade hitting something when it spins the noise could be coming from the motor. For that type of unit, the motors are very small and only have two wires to connect them and usually a very small plug. If not you'd only need two wirenuts and some electrical tape. It's just very important when you replace the fan that you match the voltz, hertz, rotation, and hp.
Posted on Mar 18, 2013
Cannot get Danby Silhouette 166 dual wine cooler to change temperature. It stays at 70 (both upper and lower). Can you help. Just bought used brought it home and it won't cool.
I also just brought home a used Danby Silhouette 166-bottle wine fridge and it is not cooling. Did you have someone come look at yours and did you get it fixed?
Jul 13, 2011 | Danby Silhouette® DWC276BLS Wine Cooler
My Danby wine cooler fan is making a horrendous noise - it sounds like it's trying to start up and then it gives up. I hav tried tightening the housing screws but this works for a couple of minutes and...
Where is the noise coming from? Check the fan at the back of the upper compartment. They seem to be defective and die after about 3 years (just outside of warranty... how convenient). I'm dealing with the same issue now. (As search on the internet indicates that we're not alone!) When its making that noise, try pressing the back plate around the little fan and see if it changes the noise.
Apr 11, 2011 | Danby DWC283BLS Wine Cooler
I am looking for the cooling fan for a Danby Silhouette DWC512BL-1 wine cooler. A google link took me to your site but I don't see any links to Danby parts.
As I have worked on a few ELECTROLUX wine coolers and they do not have a cooling fan for the inside of the unit are you speaking of the one under and in back of your cooler if so then it is a condenser fan motor it will be 110v and your local appliance store should be able to order one close enough to work in design and rotation of it. Hope this helps.
Apr 09, 2011 | Danby DWC513BLS Wine Cooler
Noisy Wine Fridge
The problem is likely with one of the two fans. A new fan is available from Danby (1-800-263-2629). My noisy fan is the condensor fan located at the bottom rear of the device. After removing the cooler from under the cabinet, the source of the noise was obvious. You will need to tell them whether it is the upper fan or lower fan. Leave the cooler upright for a few hours before you plug it in so that you do not damage the condenser. Price for the fan from Danby is $20.15 including shipping. Users Manual is available at http://www.danby.com/manuals/DWC512BL.pdf -Ron
Dec 15, 2008 | Danby DWC283BLS Wine Cooler
WINE COOLER NOISE
when the fan comes on so does the compressor,hold the fan with a rag and see which one is making the noise-mike
Nov 11, 2008 | Danby Silhouette DWC512BL Wine Cooler
Danby wine cooler repair
May 10, 2008 | Danby DWC283BLS Wine Cooler
Wine cooler noise
Had same problem. cooling fan was going out.Replaced fan about a year ago and now it is going out again. Am ordering another fan now
Mar 25, 2008 | Danby DWC513BLS Wine Cooler
Wine cooler noise
Dec 30, 2007 | Danby Silhouette DWC512BL Wine Cooler
Kitchen Appliances - Others Logo
43 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
