Question about Zenith SY3538RK TV
Zenith SY3538RK takes several tries to turn on
I have a 35" Zenith cabinet tv that has lately been more difficult to turn on. It will click twice in succession, like on/off quickly, when I attempt to turn it on with either the remote or the power button. After many tries, it usually succeeds. Another symptom - when it first comes on, it appears to have not quite enough power - the picture wavers a bit and the colors aren't full. If I attempt to change volume or channel when it's in this state, it gets overwhelmed and shuts off. Within 30 to 60 seconds, it is fully warmed up and these symptoms disappear. Once on and warmed up, it works fine. My question is this - can I remove just the circuit board and bring it to a technician for service? Would they be able to bench test and/or diagnose it? Would sure be easier than lugging a 200 lb. cabinet and picture tube around!
  • 71 Answers
Hi sir tv is not a toy it has hazard high voltage parts and you can't remove boards without discharge it and high voltages if you are familiour with so then do it but for the fault you have it is quiet clear that you got a dried up capacitors in the power suply board you have to cange 3-5 capacitors in it and evry thing exactly will work perfect i did 4 replacement capacitors for a friend same type and it is fine please don't forget to do excelent rate cause i here to help you regards
Posted on May 07, 2007
SOURCE:
I need the remote control codes
Check the following link for all codes for URC7030
http://electro-medical.blogspot.in/2013/12/universal-remote-code-for-urc-7030-sony.html
Mar 12, 2009 | Zenith ZEN350 Remote Control
My wireless lg tv has no signal help
MY late 1980's zenith space command TV clicks "off" everytime I try to turn ot on.
Oct 25, 2008 | Televison & Video
How to reset lamp hours
try holding the enter button on the tv and the mute button on the remote. a reset screen will pop up and then just press the center direction button twice.
Sep 04, 2008 | Zenith D52WLCD 52" Rear Projection...
Zenith 27inch B28A11Z keeps powering itself off
Hi Pswglaw,
From the way you describe the problem, it seems you have a high voltage leak. To check this, make the room dark and look into the back of the TV while turning it on. If you see something like lighting jumping around you have this high voltage problem. The TV will eventually destroy itself under this condition. I would suggest not using it until you get it repaired. The repair cost will be much lower if the TV is still working when you take it in. The high voltage leak will destroy more parts and cause the TV to stop working. Then it will blow a fuse.
MyTvGuy
Jan 23, 2008 | Zenith B27A11Z 27" TV
Zenith E44W46LCD turning off
That would be the first thing I would try as it is probably flakey.
Jul 06, 2007 | Zenith E44W46LCD 44" Rear Projection...
Zenith SY2765S 27" TV
there is a little 100mic 25 volt capacitor in the power supply, it is the start up capacitor. Most likely is your problem.
ladytech
Apr 10, 2007 | Zenith C27A24T 27" TV
Zenith system 3 tv will not turn on
I'd say just get a stereo system (amplifier) or something like that, and hook your cable box, vcr, converter or whatever you have right into that. That's what I've been doing for years. Most cable boxes and satellite boxes will control the main volume that goes to the sound output, or you can get a digital stereo with a remote to control the volume that way.
Oct 26, 2006 | Zenith SY3538RK TV
Zenith model SR3587 Picture too wide
there are a couple of coils that are for pincussion and width that get cold solder connections on them and sometimes will blow out the curcuit. Maybe its not to late to resolder them? Good luck
May 19, 2006 | Zenith Z35X21D 35" TV
Televison & Video Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
