Question about Williams 2509612 Ceramic Mid-Size Heater
Wall heater pilot light
Even after changing out the thermo coupler the pilot light still won't stay on...
  • lkwdnancy Jan 08, 2009
    pilot will not stay lit.
As it turns out there is an emergency shut-off valve connected to the vent that was triggered by high winds. The reset button is hidden on the upper left hand corner of the unit (as you are facing it) behind a small grill on the side of the outer casing. Logic tells me that it's there so in the event of a clogged vent you don't fill your house up with carbon monoxide. One push on the reset button allowed the pilot to stay on and therefore the heater to fire up.
Posted on Dec 28, 2008
Why does my water heat keeps going out if a put a new thermo coupler
That guy at home depot was not completely correct. If the pilot is not keeping the thermocouple warm, the pilot will not stay lit. Figure out why the cycle is being broken or call in a service tech to fix the unit. water heater
Feb 15, 2015 | Water Water Heaters
I changed the thermo coupler and the pilot light does stay lit but the burners won't light
If you are referring to a gas fireplace:
  • Make sure the pilot knob is turned from "pilot" to "ON" or it will never run.
  • If the pilot knob is "ON", and the pilot is lit, but the burner won't light, it could be a bad Thermopile. The thermopile is the other safety mechanism in the pilot assembly that controls the burner.
Dec 19, 2012 | Heating & Cooling
Cant get the pilot light to stay on, I have changed the pilot assembly
change the thermo coupler it tells the unit when the pilot is lit hope this helps bob
Apr 27, 2011 | Reliance Natural Gas Water Heater Control
Williams debonair wall heater + pilot light problems
THE flame from the pilot should shoot past the thermo-couple and heat this up and make a small amount of mili- amps to prove the pilot light is lit. ..So if the flame doesn,t go past the thermo-couple it won, make mili-amps or its tme to change out the thermo-couple, They only cost lest than $8:00 and you can change it!
Dec 22, 2009 | Williams 3003622 Ceramic Wall Mounted...
I have universal 350,000 propane heater. Fan runs, but switch will not turn on to allow propane to burner.
The thermo coupler is at fault. If pilot won't stay lit thermo coupler keeps gas off. So, Unless it is a bbQ , make sure the pilot is on or the thermocoupler stays hot while the gas is on.
May 25, 2009 | Heating & Cooling
No hot water, pilot light lights but no burner ignition
Thermo coupler may be defective. it controls the main gas valve by closing main if pilot is out. make sure thermo coupler bulb is positioned over and near tip of pilot flame, but not in the flame. Thermo couplers are inexpensive and easy to change out.
May 05, 2009 | Bosch & Tankless LP Hot Water Heater
Williams 2509612 Ceramic Mid-Size Heater Logo
272 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
