Question about Garmin Forerunner 305 GPS Receiver
Wont turn on
How did you find the button if it was hidden?
Same problem...completely dead...said it was charging...took it out...it went dead...put it back in the charger and nothing...no indication...
  • Anonymous Jan 12, 2009
    Exactly the same problem
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 84 Answers
These units seem to be suffering from a bad connection on the inside of the unit. My wife's did the same thing. There was a connection inside that wasn't making contact. First try cleaning the 4 brass connection tabs on the watch and check your charger to make sure the tabs are raised and not squished. Second try to reset the unit. Hit mode reset and power buttons all at the same time. Hold these for 3 seconds and then release. If these do not work here is what I did. There are no screws holding the unit together. I used a exacto blade to very carefully pry the unit apart along the side seam. It's not easy to do. Be very cautious and gentle. Work the thickness of the blade into the joint to gently wedge apart. You are not trying to remove material! Once apart you will see some fingers that make a connection between the upper and lower part of the unit. This is where the problem was with my wife's 305. I gently raised these tabs to make a better connection, It's been working ever since. I didn't try it before but try pressing very hard on the unit where it says Forerunner 305. The case is very hard so it might not work. But if it powers up when pushing you found your problem. Hope this helps. Here is a link I found on opening a 205 (Same process) http://ctorunner.googlepages.com/dismantleforerunner205 To put the unit back together use Automotive silicon/gasket maker. Use a tooth pick to put a VERY small amount of silicon around the entire seam. Put the two half's together and wrap tightly with electrical tape. Test the unit immediately to see if it powers on and off. If it does not open it back up and raise the small prongs that make the connection from the bottom half to the top half. If any silicon squishes out the sides wipe with water and a rag. Let the unit sit over night. In the morning remove the tape.
Posted on Nov 13, 2009
I have not used my tablet for about 3 months . It has always been plugged after every use. I went to turn it on this morning completely dead. It just wont turn on. I have tried a quick fix of power...
Give it some time. charge it, unplug it and start it. Then when it is empty, charge it again unplug and switch on.
repeat this several times,. If it does not change, could be the battery is charged to dead. or a strange spike on the power line killed the tablet.
Mar 15, 2015 | Samsung Galaxy Tab 10.1 - 16GB
Battery went dead
boost your battery.put it in sellphone.then charge your phone?
Feb 28, 2013 | LG Lucid VS840 4G Verizon
It wont turn on
When a tablet is completely dead you will need to charge it from a wall plug and not a computer. Also try holding the power button for 20 seconds, it is possibly frozen.
Feb 01, 2013 | Velocity Micro Cruz Reader R101 Tablet PC
Phone went dead. charged it. charge complete. wont
try taking battery out for 30 seconds,then put back in!?
Oct 18, 2009 | Cell Phones
Wont turn on charged it it still wont turn on ,
Try holding the power button while plugging it in. Also try holding the power button while wiggling a mini screwdriver in the reset hole
Oct 15, 2009 | Navigon 7100 GPS Navigator GPS Receiver
Wont charge, dead battery
make sure that your charger is not bent, i had the samd roblem sometimes you just have to get a new charger or just get that one to position right so that it will charge the phone
Apr 05, 2009 | LG VOYAGER VX10000 Cellular Phone
Garmin 305 wont power on, wont charge on cradle
Same thing happened to mine. Put the unit in the cradle (just like you are going to recharge it) and press the reset and mode button at the same time for 3 seconds. This will "wake" the unit up.
Mar 30, 2009 | Garmin Forerunner 305 GPS Receiver
My sansa e260 wont turn on or charge
I had the same problem. Place the device into hold and press the menu and mic buttons at the same time. The first time I tried it, I had no response and then I pressed the same buttons again and my e260 came back to life.
After getting my e260 to come on, I updated the firmware and everything has been working.
Jan 27, 2008 | SanDisk Sansa e200 MP3 Player
Battery problem or camera problem?
A new battery should help you to solve this problem.
Aug 07, 2007 | Casio Exilim EX-Z57 Digital Camera
My lyra wont turn on
Take the battery out and then put it in again and it should work again
Aug 15, 2006 | RCA Lyra RD2820 20 GB MP3 Player
Garmin Forerunner 305 GPS Receiver Logo
109 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
