Question about Braun Cruzer 3 Electric Shaver
Braun 2865 cruzer3 : extendable wide shaper broken the extendable part does not work, rest does can it be fixed?
2 Suggested Answers
  • 3 Answers
SOURCE: Braun Cruzer3 trimmer not working / spring replacement.
Try this out:
Posted on Jul 30, 2012
Is there a braun spare parts distributor in cape town south africa ?
contact braun on line and go to distributors
there will be a list of all distributors world wide
Apr 21, 2015 | Braun Health & Beauty
F5d7132 driver win 7
This is not a router, but a range extender, it does not need a driver just an interface with which to configure it.
Belkin do not say that they support this on W7 but have a bit of software that configures it at http://en-uk-support.belkin.com/app/answers/detail/a_id/2865/kw/F5d7132
Good luck.
Aug 26, 2011 | Computers & Internet
Braun Pulsonic model 9595. Trimmer will not close properly. Can I repair this myself?
The trimmer is replaceable and can be purchased as an assembly http://buyitnow64.stores.yahoo.net/brshrese7pul.html You will T-6 and T-8 torx drivers to take apart the head end of the shaver. Using these tools, remove the swiveling head, the hold down cover over the motor assembly, and then pop off the drive arm for the trimmer. Now the broken trimmer assembly can be slid out of the end of the shaver by carefully prying between the case where the on/off button is located and the black trimmer assembly base with a small flat blade jeweler's screwdriver. The new trimmer assembly can then be slid into the case and the shaver reassembled. Just be sure the ends of the retraction spring on the new trimmer assembly are installed over the little chrome retaining lugs for them or your trimmer will not fully retract (my trimmer assembly arrived with the spring ends loose and not retained by the lugs).
Mar 29, 2010 | Braun Health & Beauty
Braun 7526 trimmer will not move to the up position
The trimmer is extended by the button on the opposite side.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
May 24, 2009 | Braun Syncro 7526 Electric Shaver
Braun 5785 does not charge or auto clean via docking unit ?
HOW TO REFILL BRAUN  SELF CLEAN WITH JUST THE RIGHT BREW. THE MISSING INGREDIENT BRAUN DOES NOT WANT YOU TO KNOW
Mar 26, 2009 | Braun 4775 Electric Shaver
Braun Pulsonic Razor - Pop up trimmer will not retract entirely
I ran into this problem several months ago. I just shook it and forced it until it retracted and never thought anything of it. The trimmer recently broke (still functioned but extended beyond its normal point) and I took it apart. I realized that there were a few broken parts inside (possibly because of my earlier experience). So I removed the few parts and now it still extends to far, but otherwise functions ok if I'm careful.
I would recommend taking yours apart and seeing if you can find any parts floating around which may be causing it to not retract all the way. It may be broken beyond complete repair, but you may be able to get a little more use out of it.
If nothing else, you can order a new casing for it from here
Here are the instructions for taking it apart:
The shaver itself is easy to take apart. The part on the bottom(opposite from the shaver mechanism) pops off with just a slight bit ofprying. Be careful not to break the pins though. Once you have thatoff, the narrow sides pop off pretty easily. Then you can remove the 4screws opening up the interior.
Be careful at this pointbecause there are a lot of parts that may fall out. (Perhaps take apicture as soon as you open it so you know where everything was whenyou opened it). At this point you can try your hand at fixing it (minehad 3 parts broken and loose inside), or you can simply switch it withthe new casing (Which i'm going to do when I get it). Good Luck!
Jan 25, 2009 | Braun Activator 8595 Electric Shaver
My Shaver battery doesn't fully charged
Hi... I have the same problem, I got my shaver 2 days ago, and it is written that you need to charge it for 4 hrs in the first time and then the light willl start blinking as an indication that the batery is ful !!! I noticed the following :
1- After 15 Mintues the light simply turn off without any blinking !!!
2- The shaver is charged and runs for almost 1 hrs !!!!
Is this is a fault ??? shall I bring back ...
Please answer me what was your case ??
Mar 20, 2008 | Braun Cruzer 3 Electric Shaver
Part fell out of cleaner base
It's probably one of the support rubbers that holds the shaver in place, and keeps it from falling too low into the cleaner. It's probably broken, but maybe you could put it back in place. There are two of those rubbers in the cleaner on the side where the trimmer is faced. If they both are broken, the shaver will fall too low, and the electric contacts on the top will also not fit - no charging as a result. My Braun service rep. said that the whole cleaning unit will have to be replaced to fix this. My plan, however, is to try with some small screws before I throw the whole thing in the "broken parts basket"....
Jan 30, 2008 | Braun Syncro 7680 Electric Shaver
Problem shaving
People, never ever buy the Braun body cruzer!!!! It does not mather which version/type you buy, with 'all' versions the big trimmer fails to work after aprox, 18-24 months.
I have bought three version of them, the first one stopped working totally after about a year. With the second one the large trimmer blade did not work anymore, so I bought the newest cruzer version (shaver #3 by then) in the hope Braun would have solved this problem. But NO, the same thing happend. After 18 months the trimmer is broke and I can throw my shaver in the bin because you buy this thing for the trimmer.
Now about 3 years later I have in total bought 3 cruzer shavers from Braun and all are broke (i am also almost broke, those things are pretty expensive here). And of course Braun does not help, they just say you are beyond warranty or did not take good care of the product. But I did, I keeped it clean with the little brushes, I put oil on blades/parts, and when I had shaved in the shower I made dry.... so I wonder what Braun means with "taking good care for your product" but i think they mean something like: buy a new one and give us some more of your money.
I will NEVER buy a Braun product again! And be warned people, don't say you where not warned for this product when you buy one and is goes broke within a year.
Sep 16, 2006 | Braun Cruzer 3 Electric Shaver
Braun Cruzer 3 Electric Shaver Logo
277 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Joseph Hoffmann
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
