Question about Bosch 24 in. SHU53 Built-in Dishwasher
My SHU53 only starts on 2Hr Delay and water is not getting hot
What ever cycle I put on the clean the dishes, when I press start, the dishwasher will display the 2Hr screen and will fill with water and begin to wash the dishes. This continues all during the 2 hour delay. It then continues to wash for what ever cycle I have it on. The dish detergent releases during the 2Hr delay. The water does not seem to get hot enough and the dishes are not coming out clean.....HELP
  • 2 more comments
  • lpkita Jan 02, 2009
    I have the exact same problem. Mine also will not fully drain. Where can I find a manual for the dishwasher, so I can repair it?
  • lkessler Mar 14, 2009
    Hi, I'm having the exact same problem - what have you done to fix it?
  • Anonymous Mar 23, 2009
    No solution, but reporting the exact same problem.
    A complete deag and repairs cost hundreds
  • persecus Apr 29, 2009
    Same problem; is this a diy project? If so, how do I repair this myself?
Hello- Same problem I had- It turns out that my control board (fixed once already- the solder trace on one of the three relays burned open) was junk again, but the solder trace which was fixed before was still ok, so I replaced all three relays on the board (relays are available from Digi-Key) and that fixed it!! The relays cost all of $11.00 INCLUDING SHIPPING - So if you're on a tight budget, this may work for you. Bill
Posted on May 06, 2009
  • 76 Answers
Bosch dishwashers run the heating element directly from the control module, which usually causes the solder joint to go bad.....solution, replace the control module, or take the old one out, and repair solder joint
Posted on Dec 30, 2008
How do you get the child lock off on a Haier dishwasher?
Just consult the manual. :>)
English
Changing the Wash Program / Cycle:
If at any time during the washing process you would like to change the
selected wash program /cycle;
1. Press and hold the START / RESET button for approximately 3 seconds.
(The START / RESET indicator light will be ON indicating that the unit is
in PAUSE mode.)
2. Select the desired wash program / cycle by pressing the program
button.
3. Press the START / RESET button again, the dishwasher will resume
operation using the newly selected wash program / cycle.
NOTE: If you change the wash program / cycle after the detergent
has been dispensed or the dishwasher has already drained the
water, you will need to refill the detergent dispenser for the newly
selected program / cycle accordingly.
At the End of the Wash Cycle Once the dishwasher has completed the selected wash cycle / program,
there will be a buzzer sound for 8 seconds indicating the end of the cycle.
1. Shut off the water supply.
2. Turn the dishwasher OFF by pressing the ON/OFF button.
3. Open the door slightly with caution to allow any residual steam to
escape.
4. Wait a few minutes (approximately 15 minutes) before unloading the
dishwasher as the dishes and cutlery will be hot. This also aids in the
drying process.
5. The interior of the dishwasher will be wet, this is normal and will dry
naturally.
WARNING: It is dangerous to open the door when dishwasher in
Checking the Water Temperature
For the most effective cleaning and to prevent damage to the dishes being
cleaned, the water supplied to the dishwasher should be at a temperature
of at least 120?F (49?C) and no more than 150?F (66?C).
Child Lock Function
The child lock function will prevent the unit from functioning and the door from being able to open if it is in the fully closed position.
To engage the function, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will illuminate in the display when the child lock function is activated.
To disengage, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will go off in the display when the child lock function is deactivated.
Haier HDC2406TW User Manual At The End Of The Wash Cycle Child Lock...
Jan 31, 2017 | Haier Dishwashers
Fridgedaire dishwasher will not start a cycle. The green "clean: light stays lighted up and it will not reset the system. I have to turn off the breaker and then turn it back on. then the...
Hello
Ensure the Frigidaire dishwashing machine is fully connected to a power supply. Shut the dishwasher door firmly and select a wash cycle. Press "Start" to begin. Check that the "delay start" option was not selected.
  • 2 Verify that dishwashing detergent is placed in the dispenser and choose a longer washing cycle for heavily soiled items. Do not overload the dishwasher, as this may prevent proper cleaning.
  • 3 Check the household water pressure, which should be between 20 and 120 PSI (pounds per square inch). A water pressure gauge can be obtained at most home repair stores or hardware stores.
  • 4 Turn on the hot water at the sink closest to the dishwasher prior to starting the dishwasher to raise the water temperature inside the dishwasher. Check the hot water temperature, which should be at least 120 degrees Fahrenheit for proper cleaning.
  • 5 Check the spray arms in the dishwasher and move dishes that may be blocking the water spray or preventing the spray arms from rotating properly.
  • Read more: Frigidaire Dishwasher Wash Cycle is Not Working ' eHow.com http://www.ehow.com/how_7877923_frigidaire-wash-cycle-not-working.html#ixzz1Xow3qbbv
    Sep 13, 2011 | Dishwashers
    Dryer is running, but rotating very slowly. it generates heat, but makes a very loud noise. it's a GE Adora Dryer
    Instructions
    1. Wait approximately 90 seconds for the light to turn off if the "Start/Reset" indicator light flashes. Press the "Start/Reset" button to restart the wash cycle.
    2. Close the dishwasher door and move the latch to the locked position if you hear a beep once every 30 seconds when the dishwasher should be operating. The dishwasher will not operate if the door is open.
    3. Turn on the hot water faucet and feel the water to check if it is hot. Wait for the water to warm up before running the dishwasher if the water is not hot. Check that you have proper water pressure and wait for the pressure to return to normal if it is low. Your dishes may not come out clean if the water is not the correct temperature or if you have low water pressure.
    4. Move the dishes on the racks so that they do not block the detergent dispenser or washer arms on the bottom of the machine. The dishes will not come out clean if they block the detergent dispenser or the washer arms.
    5. Load the proper amount of detergent in the dishwasher if you find spots or film form on your glasses. If you have hard water, use a rinsing product such as Jet-Dry in the dishwasher to clean the spots or film. If the problem persists, wash smaller loads of dishes.
    6. Add only automatic dishwasher detergent to the dishwasher if you find excessive suds in the tub after running a cycle. Measure out the proper amount of detergent.
    7. Press the "Heated Dry," "Hot Start," "Hot Wash" and "Added Heat" buttons, if you find that your dishes are not fully dry after a wash cycle completes.
    8. Press and hold the "Heated Dry" button on the dishwasher for approximately three seconds if the control pad does not respond to button presses. This is the child lock that prevents unwanted use of the dishwasher.
    Feb 24, 2011 | GE Dryers
    The water does not get hot enough. I think it's the reason why dishes are not coming out clean. In normal conditions do I need to wash the dishes (like the manager of this apt. complex suggests) before I...
    No you need not wash the dishes but just cleaning of the debris and then putting it in the dishwasher for proper cleaning will help you to prevent the drain from getting blocked.
    First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
    There are many probable causes of failure .
    To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
    Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
    Feb 22, 2011 | Whirlpool Dishwashers
    Have bosch SHE45 EVOLUTION PUSH BUTTON ON RIGHT FRONT PANEL. MY WASHER WILL NOT RINSE ALL THE SUDS OFF THE DISHES OR DOWN THE DRAIN AND HAD BAD SOAP RESIDUE BUILD UP. i HAVE USED LEMISHINE ONE TIME AND...
    I started running the Hot water faucet till I got really Hot water then I started the dishwasher with No dishes in it and let it fill with hot water till it was almost full then I added a half a gallon of white vineagar to the water and let the dishwasher go through its cycle. It cleaned up the inside of my dishwasher then I put the dishes that didn't get clean and that had a soap film on and rewashed them with plain hot water and poured the other half a gallon of vineagar in the dishwasher and let them wash the complete cycle. It cleaned the dishes very well. I don't know if you will have the same results but it worked for me..... Hope this helps, your welcome to give it a try vineagar is pretty cheap... and it won't hurt anything inside the dishwasher or dishes.
    Feb 12, 2011 | Dishwashers
    Dish soap is leaving a build up on the interior of the dishwasher
    Hi. Run your hottest and longest cycle with no soap, no dishes and 2 cups of white vinegar. Also, run the hot water into the sink before starting the dishwasher. Once the sink water is as hot as it gets, then push the start on the dishwasher. J.
    Jun 23, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
    Dishwasher Soap scum left on dishes
    the problem is hard water. There is a new product out called The Dishwasher Filtration System. It filters the water going into your dishwasher leaving your dishes spot free with every load. It is very affordable and fits right under the sink. You will be amazed how sparkling your dishes look just after one load. You will love this product. Get it at www.dishwasherfilter.com.
    Nov 01, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
    Not starting
    Getting Started
    1. Load dishwasher (See Preparing and Loading Dishes).
    2. Add detergent (See Dishwasher Dispenser & Detergents).
    3. Add rinse aid, if needed (See Rinse Aid).
    4. Close door to latch.
    5. Select desired CYCLE (See Cycle Chart).
    6. Select desired OPTIONS (See Energy Options). The indicator light above the pad will glow when selected.
    7. Run hot water faucet nearest dishwasher until water is hot. Turn water off.
    8. To start, press START/CANCEL pad.
    ftp://ftp.electrolux-na.com/ProdInfo_PDF/Kinston/154575401.pdf
    Jul 14, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
    Dishes are not coming out fully clean
    first if the pump is running and you can hear it washing it should clean now hot water cleans dishes not the washer the hotter the better at least 130-135 degrees modern dish washers use less water than older models so if you don't get the water as hot as you can stand it at the sink before you turn the washer on you can fill it with cold water second its important that you use jet dry and if your dishes aren't dry at the end of the cycle then on most washers you can turn the disp up for more hope that helps let me know
    Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
    Bosch 24 in. SHU53 Built-in Dishwasher Logo
    493 people viewed this question
    Top Bosch Dishwashers Experts
    Gerry Harvey
    Gerry Harvey
    Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
