Question about Proscan PSVR74 VHS VCR
How come my vcr a video 1 and video 2 cahnnel when it only has 1 video in spot?
My Vcr has Video 1 and Video 2 channels but it only has 1 plug in for in Video audio spots and 1 video audio out spot
  • danny randles Apr 24, 2007
    Thank you. You inspired me to look closely at the vcr. It has a secret compartment on the front. I've had it for 1 year and i have just now found it.Although this is not the same vcr it has the same secret spot.
    Scholar:
  • 135 Answers
This is just a guess (since I can't find a photo of your model), but most VCRs with multiple video inputs have the 2nd input in the front panel of the unit, in order to easily plug in cameras, video games, etc without having to pull the unit out.
Posted on Apr 23, 2007
SOURCE:
How do we hook up VCR to TV
  1. 1
    Turn off all of your components. This will help prevent any accidental damage while connecting.
  2. 2
    Connect the RF/COAX Out port on the VCR to the RF/COAX/ANT In port on your TV. Use a coaxial cable.
  3. 3
    Connect your antenna to the the RF/ANT In port on the back of your VCR (optional). This will allow you to watch over-the-air broadcasts through the VCR.
  4. 4
    Turn on the VCR.
    • Make sure that the VCR is plugged into the power outlet.
  5. 5
    Set the VCR channel to Channel 3 or 4.
  6. 6
    Turn on your television to the same channel that your VCR is set to.
  7. 7
    Start playing your tape.
or check this site:
How to Hook Up VCR to TV
May 19, 2016 | Televison & Video
I connected my VCR to a new Samsung LED TV with the white ,red and yellow audio/video cable connection. The VCR is working but I put the tv and the VCR on Cahnnel 3 and it does not show up on the TV, WHY?
Hi there
To answer your question;
You need to change the input(not channel) on your tv to video input. There should be a button on your remote and/or tv called input.
Otherwise you should find it in the menu under"input source"
Dec 28, 2009 | Toshiba M675 VHS VCR
How do i hookup vcr to tv
The best way to hook up your VCR is to use the AV jacks (Red, White, and yellow). Plug into AV1 or Video 1 on the back of the TV. Then, plug into Red, White, and Yellow output jack on the back of the VCR. After everything is hooked up, turn your TV channel to AV1 or Video 1 to watch from the VCR.
To record, you'll have to plug your cable box or satellite box to the AV inputs ( Red, White, and Yellow) in the back of the VCR. ( The only thing is it wouldn't be in HD )
Nov 04, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Need help to record from a camcore
u need a video audio cabel. on one end plug yellow into video, red (or white ) into audio for camcorder. on the vcr end. if the front of vcr has jacks. plug em in same way. then put vcr channel on av-1, video 1 or whatever, till whatevers on the camera shows up on screen. hope that helps.
Aug 17, 2009 | Televison & Video
How to setup my VCR to record programs from my Panasonic 42 Inch HDTV Plasma TV?
TV doesnt matter, you need to list what kind of VCR your trying to program with.
if you are programming from cable, the cable box, box or not, should be ran thru VCR then VCR to TV.
to record. easiest.
if you are doing cable to tv to vcr. make sure that tv is in one of the AV spots, so when you select input on vcr itll show your tv again. program as accordingly.
Feb 26, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
I can't hook up the vcr
I would strongly suggest connecting a plain, coaxial cable wire from your sat box to the the ANT IN of the VCR. then use another coaxial to run from the ANT OUT of the VCR to the TV. Then you can change your TV to channel 3 or 4 as appropriate.
If you have a newer digital satellite receiver, this setup may not work. In that case, use two sets of red/white/yellow cables - 1 set will run from the out of the satellite receiver to the audio, video IN of the VCR. The second set will run from the audio and video OUT of the VCR to your TV. Then change your television to Aux 1, aux2 or whatever channel that corresponds to the red/white yellow.
Have fun!
-Tha Mp3 Doctor
Dec 31, 2008 | Emerson EWV603 VHS VCR
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
Panasonic NV SJ205 changing RF settings
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
bye.
Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
Recording Sony Handycam video footage to video
You have to tell the vcr which input to record on. Instead of a channel try "Line 1" or "input 1" or "Video 1". you can get there by going to channel 01 and pressing channel down a few times. match whats written above the input jacks with what's on the screen.
Aug 03, 2008 | Televison & Video
Changing the inputs
It might depend on the type of input. VCR often use A/V or component cables. if you are using AV (red, white, yellow) make sure they are plugged into the right input. if plugging in to a component (white, red, green, blue, red) make sure the yellow plug goes into the green input. If plugging in component make sure your red wires are not backwards. There should be a white and red together (these are the audio) and a green blue red together (these are video)
Sep 08, 2017 | Mitsubishi CS-35505 35" TV
Televison & Video Logo
61 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
