Question about Nextar MA566 MP3 Player
Locked up when i try to turn on the device it says its LOCKED. but when i plug it into my laptop it will allow me to view and listen to the music.
  • Anonymous Feb 25, 2009
    I have the same problem.
Move the "Hold" switch back to the left and then turn it on. Moving the hold switch the right locks all other buttons.
Posted on Mar 23, 2009
My fm transmitter is locked and not allowing me to listen to iPod audio books and music on the radio. I plug it into the iphone and it displays 188.8 but is locked on that.
First, 188.8 is not a valid FM frequency. Those digits represent the illumination of every segment of the display; and to me, indicates a processor fault. The fact that other buttons are unresponsive only bolsters my suspicions.
Remove power from the radio - not merely powering off - but remove power from the power leads. You can do this by pulling the fuse for the radio or disconnecting it. Do not remove the battery cable from the battery as some vehicle factory radios will go into anti-theft mode and no longer operate.
Allow the radio to remain unpowered for a several minutes and then reconnect. Try the radio again. If it still does not work, please provide the make and model radio you have.
Oct 19, 2015 | Audio Players & Recorders
Tip
To connect a music player or other audio device to your laptop
<br />If your laptop has a line-in jack, follow the instructions above for connecting a music player to a desktop computer. But to connect a music player or other audio device to most laptops, you'll have to plug it into a microphone jack. To do so, follow these steps:<br /><br />Click to open Sound. <br /><br />Click the Recording tab, click Microphone, and then click Properties.<br /><br />Click the Listen tab, click the Listen to this device check box, and then click Apply.<br /><br />Click the Levels tab and make sure the Mute button looks like this . If the button looks like this , click it to turn on sound for this connection, and then click Apply.<br /><br />Play some music or other sounds on your device to test the volume coming through your computer speakers. Select the slider under Microphone, drag it right or left to increase or decrease the volume of your audio device, and then click OK. You might also want to adjust the volume on your device.<br /><br />Note<br />If you hear noise coming out of your speakers, try reducing the volume on both the music player and in the Levels tab. The microphone jack is designed to receive sound from a microphone, which is different than sound coming from a music player
on Dec 14, 2010 | Computers & Internet
I think mine is the e260 - 2 gig sansa. The last time I turned it on, it resumed playing the album that had been playing the previous time I used it - as normal. When the album finished and I tried to...
Resetting the device:
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
Jan 09, 2010 | SanDisk Sansa e250 MP3 Player
Earphone plug is not working
do your speakers have their own volume knob? sounds like its turned way down,master volume in control panel under audio devices,also volume controll in the sound card software ,nvidia,realtek,maestro,ect. whitch ever one you have,if they are all turned up ,try turning it up useing your hotkeys on your keyboard,if none of that works,uninstall all of your audio drivers,and reinstall them from the support web site at hp.com,the wires that go to that headphone jack inside are very small,doesnt take much to damage them,droping it a couple times is enough,reinstalling the software is the best chance,if that doesnt do anything ,you will have to go inside,if this only happens when your using the optical drive then disregard everything i just said,and replace it.make sure its locked in securely
Sep 02, 2009 | HP Pavilion DV2910US Laptop
Not enough space for music db Please free 30 MG
Had this same problem. You need to lock turn off the player. put it into the locked mode and hold down the middle button before plugging it in. Then back up and reformat.
Detailed instructions I found were here:
Frozen sansa clip
Dec 26, 2008 | SanDisk Sansa Clip MP3 Player
My ipod is locked
The way to unlock is to load up Itunes.  Plug you Ipod into the computer and select restore Ipod back to factory settings.
You will have to reload your music as well.
Nov 10, 2008 | Apple iPod nano
Unable to power down my Sansa Fuze
sounds like its locked mine did that once i dont have the fuze i have the view but i held the off switch AFTER i unlocked the device over and over for as long as i could.....it eventually turned off or let it die then recharge it and attempt to turn it on again but i think you have it locked
Oct 26, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Polardoid mpa-200115 Digital Media Player
On the top is a switch. This switch goes left for lock. Make sure it is not locked. Once it is unlocked, you can touch any switch, button, or dial, and it "wakes up" the device. Now you should have the screen available.
This may not answer your question. Please provide more details if not.
As a note, in case you didn't discover it like I did, if you want to turn off the device to save power when you are not plugged in to USB and you aren't using it for a while...turn the device off by holding it in the "on" position for about 2 seconds. The device will shut down. Place the top switch back into lock position so it will be harder to accidentally turn it back on.
Good luck.
Something unrelated. If you don't have Windows Media Player 10 you may have problems getting music to sync to your device the way you want. Then again, you may have problems even with WMP10. See how it goes.
Sep 13, 2008 | Polaroid MPA-20011S Digital Media Player
Krazor Music
yes you can. ebay search a mini usb to 3.5 mm adapter. plug it into your krazr,razr, etc. then any FM transmiter with a 3.5 mm plug can be used to listen to the music
Jan 11, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Music keeps "disappearing" from memory card
You have to go on Sandisk.com and thay will let you
download music.
Dec 24, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Nextar MA566 MP3 Player Logo
Top Nextar Audio Players & Recorders Experts
Robert Graf
 Grubhead
Grubhead
topcat7736
Level 1 Expert
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
