Question about Weber Q Grill
I have the Weber Q300. Only used 6 times,30 minutes each time, and gas bottle is almost empty ( 7.8 Kilo or 17lb bottle). Are you supposed to turn bottle off after each use and disconnect lead ??? I have not done this. Everything I have read about Weber Q says it is supposed to be very gas efficient. Regards Jim.
  • Weber Master
  • 14,189 Answers
I would just always turn the bottle off.
Posted on Oct 26, 2017
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: Weber Q300 - Gas bottle runs out very quickly
Yes turn the valve off at the tank so you do not loose gas. You do not have to disconnect the tank from the BBQ though.
Good Luck and Please Rate FixYa!
Posted on Dec 28, 2008
Gas flow too high
indicates a gas jet/control valve problem
Take it to a gas fitter shop for repair
Oct 13, 2017 | Weber Q300 Grill
Need to convert our Q300 propane grill to natural gas. Do you sell conversion kits?
Unfortunately, Weber grills are not convertible from one gas type to another. There are no conversion kits available for your model or any Weber model gas grill.
To confirm this, go to the following link and on page 2 under Warnings, last paragraph, left hand column, you can confirm this, if you like.
http://help.weber.com/manuals/pdf_files_2011/Gas/Weber%20Q/Q300320_OwnersGuide_41060_021011.pdf
The only advantage to converting it to Natural Gas is not having to refill the grill tank. The downside, is that you will loose the heating capability that Propane has. It burns cleaner and hotter than Natural gas, in an outdoor environment.
Hope this helped you. Happy Grilling!!
Jul 13, 2011 | Weber Q300 Grill
When I try to light my brand new Q300, it won't ignite. I can hear that the tank is on and gas is being sent to the grill. However, it doesn't light. When I shut the grill off and the gas tank...
What you have is delayed ignition. It's being caused by the gas regulator. It is solvable, though.
Turn the gas tank valve OFF and disconnect the hose from the tank.
Wait 5 minutes and reconnect the hose to the tank.
Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
Once the valve is fully open, light 1 burner and turn it to HIGH. Did the burner light and does th eflame height look correct? If so, light the remaining burner the identical same way. Now, to both flame heights look correct? If so, you solved the problem. Remember to always open the tank valve Very, Very Slowly. And always light the burners with the Lid/Hood Open.
If the above did not solve the problem, you will need to replace the Hose/Regulator Assembly. Since your grill is brand new, the Hose/Regulator Assembly will be covered under Warranty. Have your Proof of Purchase handy and call Weber 1-800-446-1071. Also, if you haven't done so already, register your grill before calling http://help.weber.com/register/ even if you don't need a new Hose/Regulator Assembly.
Hope this helped you troubleshoot & solve the problem.
Jul 06, 2011 | Weber Q300 Grill
Won't light entirely
The most obvious reason is that the grill may need a thorough cleaning.
The second is the is the OPD Valve on the gas tank. Turn off the tank, disconnect the hose from the tank, and wait 5 minutes. Reconnect the hose to the tank and turn it on very, very slowly, until it's fully open. If you have more than one burner, light each one at a time and turn them up to high. If this didn't solve your problem, it's back to the obvious ... the grill including the burners and their ports need a thorough cleaning. Also scheck for a rusted out portion of the burner(s).
Feb 14, 2011 | Weber Q300 Grill
Very little gas getting to burners Full bottle of propane Acts the same way as when the propane bottle is getting empty This grill is only about 6 months old
You either have clogged burners and they need to be cleaned. Clogged inlet line to the burners. (This can come from trash, spiderwebs etc in the connection, kinked line etc.) or the regulator is malfunctioning.
Aug 24, 2009 | Weber Genesis E-310 Gas Grill
Weber grill will not heat up, reaches 200F and no higher
Also, it has to shut down the same way every time you use your grill.
Here is a Tip to fix a grill that not getting hot:
1. Turn the gas valve knob off. then close LP tank valve knob.
2. Unscrew the plastic hose coupling knob from the LP tank. You may hear a slight "hissing" sound as pressure is released this is normal.
3.Wait a minute then screw the coupling knob back on to LP Tank.
4.With lid open.slowly open LP tank valve.
5.Relight the grill the proper way by turning gas valve knob to ON position while turning the igniter knob at the same time.
6.After you are sure the grill is lit preheat the grill for 30 minutes.
This was called purging the line or releasing the air out of the line.
Another thing your orifice could be clogged with spiders or dirt. If it is LP gas check to make sure your hose is not kinked.
Jun 28, 2009 | Weber Genesis Silver C Grill
Dec 27, 2008 | Weber Q Grill
Weber Q Grill Logo
425 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Weber Grilling Expert? Answer questions, earn points and help others
