Question about HP PSC 2210 All-In-One InkJet Printer
At startup it says align i did this and it wont move from this to finish setting up my printer i went into the maintenance menu and reset the factory defaults, hoping this would correct the problem but it still wont go any further than this
  • jsawle Dec 28, 2008
    thank you for your help but replaced cartridges and still wont go beyond align cartridges section my next move is to buy genuon hp cartridges and thern try again.
    Genius:
  • 2,120 Answers
You must replace both ink carts for a sucessful alignment
Posted on Dec 27, 2008
How to reset Oki 720 to factory default
Okidata B710 and B720 Maintenance Reqd. Reset Procedure
To enter the Diagnostics area:
Turn the printer power OFF.
Press and Hold the MENU^ and Enter buttons.
Turn the printer power ON (you can release these buttons as soon as "loading ... '' is displayed.
The Operator Panel reads "Diagnostics"
There is a list of Test Options and settings.
Press the Down Arrow highlight "Maintenance Info." Press the Enter button
The Operator Panel Display reads "Maintenance Info" with setting listed.
Reset Maintenance reqd. is highlighted. Press Enter
Reset Maint. Reqd. is displayed and Execute is highlighted.
Press Enter.
The Display reads - Resetting Maintenance Required.
This completes the process.
Dec 23, 2015 | OKI Office Equipment & Supplies
HOW DO YOU RESET YOUR PRINTER
  1. Press the "Fax Mode" button.
  2. Press the "Menu" button. The "Fax Menu" screen will be displayed.
  3. Press the down arrow button 9 times until the screen displays "Maintenance."
  4. Press the "Select" button. The screen will now display the Maintenance Menu.
  5. Press down arrow button 4 times until the screen displays "Restore Defaults."
  6. Press the "Select" button and a new screen will pop up. "Are you sure
    that you want to reset default settings to their factory settings?
  7. Press 1. A new screen will pop up that says the factory settings have been restored.
Mar 08, 2011 | Lexmark X8350 All-In-One InkJet Printer
I have an HP 6110 all in one printer. I get a continuous error message saying to align printer cartridge although the cartridges seem to be loaded correctly. I have replaced the cartridges even though they...
you need to align your printer cartridge, to align the cartridge go to start button on your computer desktop then click the setting and choose the printer and faxes then right click your installed printer HP 6110 then choose the properties of your printer then you click the maintenance menu then you see an option to align your printer cartridge...just click it and wait until finish aligning your cartridge..
Mar 02, 2011 | HP OfficeJet 6110 All-In-One InkJet...
My printer keeps on saying align cartridges and I do. But once it finishes it just go backs to saying the same thing! And yes it says it passed.
turn printer on/off, unplug, plug in, should reset configs.
take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are stuck.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome web site for trouble shooting problems
hope this helps and good luck
Apr 28, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I reset the eeprom windows wont recognise printer on usb
If the printer is not working or if you're getting an error code, please try the steps below:
* Execute the adjustment program (printer must be ON)
* Choose maintenance ink pad menu
* Click read
* Click initialize
* Read(again) after "0" press finish
* Choose set shipping data (bottom menu)
* Choose set
* Wait for a while (about 1 minute)
* If there is a reaction from the printer (it will load some paper or you hear "glodak" sound), the reset process will be done. turn off the printer and then turn on again. repeat read the EEPROM
* If there is no reaction from the printer, repeat step 1
Apr 07, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Scanner problem
Hi!
Try to reset advanced features to their default settings
RESET=NO [±]
To reset the advanced features:
1. Press {MENU}.
2. Press {#}, then {8}{0}.
3. Press {A} or {B} repeatedly to select “YES”.
4. Press {SET}.
5. Press {SET} again.
6. Press {MENU}.
Thanks
Rylee
Mar 18, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Lexmark 4800 series reset printer to factory wireless settings
i have a lexmark printer its plugged in but dont have a icon to make it print
Oct 07, 2008 | Office Equipment & Supplies
Drum Full of Waste Toner
Try clearning the NVRAM most cases the drum fill count is baised on a setting and not if its really full.
  1. Press Menu.
  2. Press d_bottonb.gif until Configure appears, and then press r_bottona.gif or arrowbutton_sa.gif .
  3. Press d_bottonb.gif until Maintenance appears, and then press r_bottona.gif or arrowbutton_sa.gif .
  4. Press d_bottonb.gif until Init NVRAM appears, and then press r_bottona.gif or arrowbutton_sa.gif .
  5. The Init NVRAM Are you sure? message appears on the operator panel. Press arrowbutton_sa.gif .
  6. Turn off the printer, and then on again.
Nov 16, 2007 | Dell 3000cn Laser Printer
Brother MFC-410CN Ink Jet Problem
Please push menu button then start mono then 4x arrow up. Display should be ||maintenance|| and printer should beep. What error code does the display show up?
Sep 17, 2007 | Brother MFC 420CN All-In-One InkJet...
Wont recieve fax
NVRAM init NVRAM init returns all stored parameters in NVRAM to factory default values or to a default ROM value, depending on the variable, and performs a system reset. Performing NVRAM init can cause the product to violate local telephone regulations. Reset the language and country/region after performing NVRAM init. ENWW Service-mode functions 265 NVRAM init resets the following settings and information: ● All menu settings are reset to factory default values, including fax header and company name. ● Factory settings such as formatter number, page counts, and factory paper settings are reset. ● All faxes in memory are erased. ● All speed-dials, group-dials, and phone book entries are erased. ● All localization settings, including language and country/region, are reset. To perform NVRAM init 1. Turn off the product. 2. Press and hold down the * and MENU/ENTER buttons. 3. Continue to hold down the buttons while you turn on the product. Hold the buttons through the entire power-on sequence. 4. When Permanent Storage Init. appears on the control-panel display, release the buttons. 5. When the message Language appears on the control-panel display, set the correct language and country/region. 6. Allow the product to return to Ready before using the product.
Jul 24, 2007 | HP LaserJet 3050 All-In-One Printer
HP PSC 2210 All-In-One InkJet Printer Logo
63 people viewed this question
Ben Johnson
