Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
How can I fix a light scratch on the plexi screen
I have a Philips projection tv and the plexi- outer screen has a mark from a rubber ball that hit it. The screen does not have a dent scratch but a mark on it. I was wondering if there was anything I can use to rub it out? Or do I need to find a new plexi- outer screen? Thank you!
    President:
  • 1,284 Answers
There is a product for polishing platstic that removes minor scratches. I don't however remember the name of the product and if you do obatin it try it in the corner of the screen first to verify it won't do further damage to the screen.
Posted on Apr 23, 2007
I have a philips magnavox 64" rptv, "99", model 9p644c. The picture is real dim. a friend gave it to me, but don't want to spend a ton of $ if I can buy one cheaper. Doe's it just need a bu
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Jan 21, 2013 | Philips 9P6444C 64" Rear Projection...
Where can I get a replacement plactic screen cover
This set has 3 screens---the outer one is really only for glare--clear plexigalss--no longer available from Sony.
Sony 4-070-602-01
SCREEN, FRESNEL Sony 4-064-343-11
SCREEN, LENTICULAR Sony 4-058-894-11
SCREEN, PROTECTION (CONTRAST)Outer one is (Contrast) the other two inner ones are showing as available and about 180 each.
You would have to either have someone dismantle or do it yourself---most of these sets you have to remove all three screens from the rear of the set---then remove the outer contrast one if it is scratched or cracked--
If you get it out and measure it: It is possible you may be able to find a company who can cut you a plexi-glass piece to replace it with--lots of work to do this and you have to use extreme care when you remove the two inner screens--easy to damage them---Usually the inner two are taped along all the edges to keep dust etc from getting between them and the front one is a short distance forward of them.
The front protective screen is really only there for glare and to protect the inner screens from damage---I have seen people who had a cracked outer one just dismantle and remove that one---put the others back and use the set that way---have to be careful as the inner screens are easy to scratch or damage with the outer one removed.
Also---I have seen several where someone removed the outer one and got a piece of plexi glass big enough to put on the outside of the front of the set---secured all around the edges with velcro--does not look as good as the original but prevents glare and protects the inner screens.
If this told you something you did not know or helped you rate this solution as I do this here for free.
SD TECH
Jan 03, 2010 | Sony KP-53V80 53" Rear Projection...
I have a Mitsubishi WS-A48 TV. The plexi-glass
not personally order them no, mitsubishi will not let private parties order servisable parts, so u will need to order it through a service man, then, take of the back part side part etc... can be done, but before u get to it u will feel like u own a hardware store with all the screws they put in. be carefull not to touch the mirror!!!
Mar 04, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Outer screen gouged on mitsubishi vs-55609
How were you able to remove the plexi glass screen? I have the same problem, but I don't know how to remove it!
Jan 17, 2009 | Mitsubishi VS-55609 55" Rear Projection...
Polaroid FLM-2601 flat screen
It has a protective outer screen and depending on the depth of the scratch you might be able to restore it. You'll need to look on-line at a few aircraft site for a kit that is meant to polish scratches from the plexi in an aircraft windshield. There is a company in Oregon http://www.chiefaircraft.com/airsec/Aircraft/Windshields/ScratchRemoval.html
that sells the kit for 34.95....
It is time consuming but I have restored many this way!
Bill
Mar 27, 2008 | Polaroid FLM-2601 Television
Screen is dented
sure no problem. is the screen damaged or scratched...if the inside screen is not damaged then all you have to do is take the t20 torq screw from around the screen and remove the front plexi. remove the brackets that hold the inner screen and straighten it out carefull it easy to scratch.
Mar 22, 2008 | RCA D52W19 52" Rear Projection Television
How do I remove the outer protective screen on my Mitsubishi WS-55315?
There are trim pieces around the edges that can be removed by sliding a knife underneath and lightly prying. They should remove fairly easily, don't force them as they may break. Use the knife on the cabinet side and pry toward the center of the screen.
The tear on the inner screen may be best left as is.
lexan would be better than plexi as it is tougher, but try to get anti-glare if possible. Anti-glare plexi would be better than regular lexan.
Feb 17, 2008 | Mitsubishi WS-55315 55" Rear Projection...
CRACKED SCREEN
the outer screen on these units easly replaced. RCA #258797 their called supersheilds.. rca charges about 70 dollars for the item...If it is just that i have seen people just use a clear sheet of plexi. removeing the screens requires removein several torx 20 screw around the outer and remove the frame.. then the clear peice of plexi is attache with serval brackets.
Dec 25, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Scratches on the screen
if the screen prot. is damaged,replace with plexi glass..avail thru local home improvement suppliers...good luck...john
May 28, 2007 | Akai PT4298HD Rear Projection Television
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
225 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
