I would like to know the steps to setting up an internet connection using a linksys wrt54g ver.6 using the provider comcast . It is intended for 2 laptops, and a desktop.
  • 1 more comment
  • wjpaulk May 11, 2010
    Have you tried the instructions at the Linksys web site below?
    http://linksys.custhelp.com/cgi-bin/link...
  • Jim Kirk May 11, 2010
    Are the three computers hooking up wireless or wired or a combination?
  • sthomas13 May 11, 2010
    Is this a brand new linksys straight out of the box?
  • 24 Answers
If u have the cd that came with your router it will give u step by step dierections. it is very iis to install.just put it inthe drive and do what it says.
Posted on Jan 01, 2009
Forgot user id for router
Look on the back of your router for a url (numerical Web address) that is the format of 123.456.7.8 In your PC Internet browser put said url in address bar and connect to your router. Your user id should be on the first page. If you have forgotten your password contact your service provider to reset.
However your user ID and preset password should be on the sticker on the back of your router. If none of this works contact your service provider.
Sep 25, 2011 | Linksys Wireless-G WRT54G Router
Internet connection from the linksys wireless-G WRT54G Ver-2 not connecting. when I connect directly from the router modem then the internet works
while u confiuring make sure u had pud the correct WAN ip and also enable dhcp for your local clients, make sure u put the right DNS ip address and also check the cablees at WAN and LAN port
Sep 21, 2011 | Linksys Wireless-G WRT54G Router
How do i know if my router is hard reset
1. Step 1
Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
Jun 14, 2010 | Linksys Wireless-G WRT54G Router
How to fix wrt54g
Set up a Linksys Wireless Router
Configure the Router 1. Step 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
May 03, 2010 | Linksys Wireless-G WRT54G Router
Moved router to connect directly to the Comcast modem that also provides VOIP. Comcast activated modem and internet works when computer is connected directly to Comcast modem. Router does not connect to...
Your ISP should have given you the following information...
Static IP, Internet IP Address, Subnet Mask, Gateway, Static DNS 1-3.
With that information at hand, follow tis link to the router user manual and go to Page 11 of the manual to go through the step by step process of setting the router up for an internet connection.
http://downloads.linksysbycisco.com/downloads/WRT54GX2v2_ug,1.pdf
Nov 26, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Dhcp error using linksys wireless g wrt54g router to comcast
Try to call linksys and they will guide you through trobleshooting steps
Jun 15, 2009 | Linksys Wireless-G WRT54G Router
Need to add Linksys WRT54G-TM wireless router with Linksys SPA 2102 phone adapter
your SPA2102-R seems to have one ethernet connection and one internet connection.
your WRT54G-TM seems to have one internet connection and 4 ethernet connections.
What you are trying to achive is; plug a ethernet cable into the ethernet connection on your SPA2102-R then plug the other end into the internet port of the WRT54G-TM
hope this helps, I have assumed that you intend to use a DSL broadband supplier not ADSL.
if you are changing service from DSL to ADSL then your WRT54G-TM needs to be first in line configured and working. then plug the internet port from the SPA2102-R into any of the WRT54G-TM ethernet ports.
Nov 06, 2008 | Linksys Wireless-G WRT54G Router
No connection
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
May 12, 2008 | Linksys Wireless-G WRT54G Router
Dificulty in configuring wrtg4g
There are three major steps to setting up a wireless router.
First set up WAN side access to the internet. For this you need information about your internet service provider. Please respond with your internet service provider's name or better yet a link to their help/support website.
I assume you already have access to configure the router at 192.168.1.1 if not please do the following. Open Internet explorer and enter 192.168.1.1 where you would enter fixya.com and press enter -- do web pages appear in your screen from the wired computer. If so we have manual access to configure the router. If not let me know.
Please reply with a response to this message.
Second we will test wireless connections to the router
Third we will secure the tested wireless connections to the router.
This process will require interaction and several iterations of instructions to complete. Please add a comment to this request with the necessary information if you with to proceed in this fashion.
Jan 01, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
