Question about Acer Aspire 3610 Notebook
Acer aspire 4930G
Hi,can u help me with my problem..when i try to d2d recover it only blank black screen appers,i already do the needed troubleshooting,such as enabling the d2d in the bios..and now it doesnt boot anymore..
thanks for your help in advance...
Startup repair your computer was unable to start ....what`s going on some one help me plz.
Ok.
Possible causes:
  • Virus/spyware/malware
  • Something has corrupted your boot
Have you tried safe mode?
Aug 20, 2012 | Acer Aspire 4710 4920 4935 4930G 4930...
Hi, I'm trying to fix my friends Acer Aspire 5553.
try turning it on while pressing F8 to go to safe mode that might be one option
recovery disks are always a good thing to have on hand
May 22, 2012 | Acer Computers & Internet
Acer Aspire 7520 black screen wont boot
Turn off notebook. Remove the battery. Press Power button. Notebook should start working. Wait for 15 secs. If the screen still blank press Power button and hold it for approx. 4 seconds until notebook is powered off. Then press power button again. Bingo, problem should be solved.
Dec 19, 2009 | Acer Aspire 7520-5185 Laptop
Aspire one notebook's screen was blank
Seems that it lost BIOS. There is a way to recover it - go to macles.blogspot.com/2008/08/acer-aspire-one-bios-recovery.html
Sep 24, 2009 | Acer Aspire One PC Notebook
Acer 5315 will not start up windows
check the BIOS setup screen, when you get the ACER screen press F2 or F10 or the DEL or END or ESC key one of those will get you into the bIOS SETUP. Once there revise the boot order, make sure the CD is first to boot then HDD. Also review to see if the BIOS recosgnized the HDD. the symptom you are describing may be a bad HDD.
Jun 02, 2009 | Acer Aspire 5315 Notebook
Acer aspire 4930g,charging, at first 1% to 95% the
yes you labtop battary driver may be currepted. so install fresh battary driver
Apr 29, 2009 | Acer Aspire 4930-6862 Laptop
D2d recovery
Hi there
You want to restore your computer to its original settings without
recovery CDs?
This recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook. Follow the steps below to rebuild your C: drive. (Your C: drive will be reformatted and all data will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1 To activate the BIOS utility, press <F2> during boot up.
2 Check to see if Acer disk-to-disk recovery is enabled or not.
3 Make sure the D2D Recovery setting in Main is Enabled.
4 Exit the BIOS utility and save changes. The system will reboot.
To start the recovery process:
1 Restart the system.
2 While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3 Refer to the onscreen instructions to perform system recovery.
Good luck and Merry Christams
Dec 24, 2008 | Acer Aspire 5630 Notebook
Acer D2D Recovery
mr panther21,
what do you mean your friend got a d2d disc? you mean the dvd? what i want is a partition that came from a harddisk. if anyone is kind to image the pqservice partition using rdrive image software. just PM me if you can help. thanks a lot..
Aug 03, 2008 | Acer Aspire 5610-4648 Notebook
D2d recovery
you can not use erecovery and d2d if your don't have the hidden d21 partition on your harddisk. and since you have replaced your harddisk you don't have it anymore.
mail to compurepair and see if he can fix it..
rate me if you want.
CS.
Apr 08, 2008 | Acer Aspire 5630 Notebook
D2d recovery
Is the d2d erecovery function enabled in the bios?
To check, activate the BIOS utility, press <F2> during the POST; while the notebook PC logo is being displayed.
To enable D2D recovery ard disk recovery), select Main from the categories listed at the top of the screen.
Find D2D Recovery at the bottom of the screen and use the <F5> and <F6> keys to set this value to Enabled.
That should allow you to use the F10 function key to activate D2D.
* Note: D2D e-recovery is not in Acer Empowering Management.
AEM is a power management utility that supports ACPI (advanced configuration and power interface) which allows for maximum power conservation and maximum performance. (Managed by the windows OS)
Jan 04, 2008 | Computers & Internet
Acer Aspire 3610 Notebook Logo
167 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
